Compiling LinuxCNC using a graphic card
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
28 Nov 2022 17:17 #257870 by tommylight
Compiling LinuxCNC using a graphic card was created by tommylight
Not that i compile a lot lately, but it just occured to me that i have not seen the above done, ever, for all software, not just LinuxCNC.
Given the huge amount of procesing power graphic cards have these days, is anyone aware of such a posibility?
19 Dec 2022 12:16 #259885 by TOLP2
Replied by TOLP2 on topic Compiling LinuxCNC using a graphic card
Those GPU's have relative simple processors but a load of them in parallel. It will only be feasible if you have a compiler which uses the GPU (does not exist AFAIK) and a lot of classes which are very similar (so you can benefit from the parallelism).
Compiling is something you do once and use the result often. Therefore it is more beneficial to invest in algorithms which unleash the power of the GPU and not in the tooling to compile those algorithms.
  • Moderator
  • Moderator
19 Dec 2022 12:33 #259886 by tommylight
Replied by tommylight on topic Compiling LinuxCNC using a graphic card
I have several high end graphic cards collecting dust, so it was just an idea to do something with those.
Thank you.
Time to create page: 0.347 seconds
