A1-SVD 15 Chinese servodrive Full User manul translated to english
  • stefan63
  • stefan63's Avatar Topic Author
  • Senior Member
  • Senior Member
02 Jul 2023 06:35 #274632 by stefan63
I finally got time to figure out how to bet auto translate the manual for the A1-SVD 10, 15, 20, 30 series Servo drive.
I have uploaded it to my personal blog page to be able to share it with my friends.
You find it att the bottom of the page in the link below.
Enjoy!
www.stockholmviews.com/wp/another-bf-30mvl-cnc-conversion/
07 Jul 2023 10:32 #274938 by tommylight
Where did you get those?
  • stefan63
  • Senior Member
  • Senior Member
18 Jul 2023 10:55 #275746 by stefan63
Ali
HLTNC Official Store
06 Dec 2023 11:19 #287369 by vibram
hello stefan, thank you for this !
Quick question, how did you wire the command? step/dir ?
because I don't really understand how it works with PP- and PP+ and same for PD- and PD+
D is for direction, OK but should I put the wire on PD- or PD+ or both?
  • stefan63
  • Senior Member
  • Senior Member
05 Jan 2024 07:00 - 05 Jan 2024 07:14 #289859 by stefan63
Both ways are possible but you get a better setup by connecting both.
linuxcnc.org/docs/html/man/man9/stepgen.9.html
Also settings on the servo drivers must match Hal settings ;)
Last edit: 05 Jan 2024 07:14 by stefan63.
08 Jul 2024 03:02 #304643 by alimumtaz101
hello,
thanks for sharing the manual.
one thing I can't figure out in the driver, the motor is rotating at the rate of 10000 pulse/revolution, is there any way to change it to 1600 pulse revolution in the drive? I tried to find any parameter but unfortunately, they have fixed it to 10000 p/r.
25 Jan 2025 07:59 #319818 by Felx0501
Hello
i have a similar problem. What was the solution ? where connection PUL+ PUL- DIR+ DIR- on the servo drive ?
Time to create page: 1.067 seconds
