How to build LinuxCNC on OpenBSD?
  • landoneilers
  • landoneilers's Avatar Topic Author
  • Visitor
  • Visitor
15 Feb 2026 18:27 #343032 by landoneilers
How to build LinuxCNC on OpenBSD? was created by landoneilers
I have grown to like OpenBSD with its well thought through update commands and all.
Additionally, the absurdly high security makes using an outdated system less of an issue.
OpenBSD also comes with 3 (admittedly highly primitive) GUI options, which is a plus.
I managed to get the ./configure script to run with the attached script.
Due to a lack of the
pidof
command on OpenBSD, I got AI to make a script to emulate it using
pgrep
(see attached file for details).
However, there are currently 4 issues:
1. Lack of tclx package (ostensibly a runtime dependency of LinuxCNC) on OpenBSD for some reason.
2. Lack of a libmodbus package on OpenBSD for some reason (functionality likely is reduced).
3.
make
refuses to work.
4. No idea about realtime on OpenBSD.
BTW:
On OpenBSD,
/bin/sh
KSH
  • Moderator
  • Moderator
15 Feb 2026 18:52 #343036 by tommylight
Replied by tommylight on topic How to build LinuxCNC on OpenBSD?
Do not make me regret this.
  • landoneilers
  • Visitor
  • Visitor
16 Feb 2026 08:53 - 16 Feb 2026 09:45 #343050 by landoneilers
Replied by landoneilers on topic How to build LinuxCNC on OpenBSD?
First run the installdeps script.
Then run:
export AUTOMAKE_VERSION=1.18
export AUTOCONF_VERSION=2.72
./autogen.sh
export CPPFLAGS="-I/usr/X11R6/include"
export LDFLAGS="-L/usr/X11R6/lib"
./configure --without-libmodbus --with-tclConfig=/usr/local/lib/tcl/tcl8.6/tclConfig.sh --with-tkConfig=/usr/local/lib/tcl/tk8.6/tkConfig.sh --disable-check-runtime-deps
This all works fine.
However, when I try to run gmake or remake (which is apparently just gmake with better debug output), it fails with an error partway.
Does anyone know why?
Does anyone know how to fix it and get it to compile?
Last edit: 16 Feb 2026 09:45 by landoneilers. Reason: The editor broke all my code formatting the first time.
Time to create page: 0.071 seconds
