Mesa Products in North America
10 years 8 months ago #70020 by rubes
Thanx JT...
10 years 8 months ago #70048 by 5axisormore
How extensive of the line are you going to handle? I just bought back my old Hardinge HNC and will be trying to use the original resolver/tach combo, so I was wondering if you will be handling the resolver boards as well. The previous owner had sawed through the cables and got rid of the GE550T control cabinet, so I will replacing the HIACK drives with AMC's and using an AnTek Inc 500 watt torroidal power supply, but otherwise all the original parts including the parts catcher and cutoff slide. Possibly even attempting a PathPilot system on it at some point.
Fred
10 years 8 months ago - 10 years 8 months ago #70049 by BigJohnT
5axisormore wrote: How extensive of the line are you going to handle? I just bought back my old Hardinge HNC and will be trying to use the original resolver/tach combo, so I was wondering if you will be handling the resolver boards as well. The previous owner had sawed through the cables and got rid of the GE550T control cabinet, so I will replacing the HIACK drives with AMC's and using an AnTek Inc 500 watt toroidal power supply, but otherwise all the original parts including the parts catcher and cutoff slide. Possibly even attempting a PathPilot system on it at some point.
Fred
Hi Fred,
Yes, I'll be getting them on my next stock order. I really like the Antek power supplies. I plan on carrying everything I need to supply the CNC market.
JT
Last edit: 10 years 8 months ago by BigJohnT.
10 years 7 months ago #71064 by B.Reilly01
Do you think you'll be getting DIN RAIL mounts in? I've just discovered I have a nice spot on a din rail for my 7i77 if I can find a mount.
10 years 7 months ago - 10 years 7 months ago #71065 by BigJohnT
B.Reilly01 wrote: Do you think you'll be getting DIN RAIL mounts in? I've just discovered I have a nice spot on a din rail for my 7i77 if I can find a mount.
Yes, the components are on the way already. All I have to do is machine the aluminum bars on my VMC. I'm making mounts for both the daughter cards and the THCAD cards.
JT
Last edit: 10 years 7 months ago by BigJohnT.
10 years 7 months ago #71219 by BigJohnT
I have another stocking order due in Friday that will add THCAD-10's, THCAD-300's and 7i80HD-16's to the cards already in stock.
In stock now.
5i24-16
5i25
6i25
7i37TA
7i76
7i76E
7i77
7i77ISOL
7i90HD
7i92
I also have 5vdc and 24vdc power supplies in stock.
JT
Time to create page: 0.059 seconds
