Mesa Products in North America
10 years 2 months ago #79128 by BigJohnT
mesaus.com/
If I can help in any way just let me know.
JT
The following user(s) said Thank You: chucktilbury
10 years 2 months ago - 10 years 2 months ago #79137 by chucktilbury
I just took a look at your web site. I like it much better than the Mesa site.
I did not know that the 7i92 existed. There are a lot of places that I could have used that in the past.
In an ideal world, I would like to use the 7i92 and connect it to the existing parallel breakout that came with the hardware. I have a few specific questions
  • Do you know for sure that it works with LinuxCNC?
  • I am slowly accumulating parts for a "delta" style 3D printer. It should interface to LinuxCNC for that as well, correct?
  • Is there a pointer on the web about how to get LinuxCNC to talk to the board?
  • What firmware do I need to flavor it as a "normal" parallel port?
Thanks very much. I expect we will be doing some business pretty soon.
Last edit: 10 years 2 months ago by chucktilbury.
10 years 2 months ago - 10 years 2 months ago #79141 by BigJohnT
Yes, just click on the Links at the bottom of my web site and there is a 7i92 guide. Probably the 7i92_G540x2D.bit would work. I only sell Mesa products that work with LinuxCNC as a service to the LinuxCNC community.
Edit: Both output headers on all flavors of 7i92 are the same pinout as a parallel port, the bit files will change as the breakout boards or daughter cards change.
JT
Last edit: 10 years 2 months ago by BigJohnT.
Time to create page: 0.227 seconds
