Looking for a freelancer to assist in drawing schematics for cnc plasma table
16 Nov 2025 14:48 #338536 by tcbmetalworks
Hello. I am looking for a free lancer who would be interested in drawing schematics for a cnc plasma table i am building and assisting in choosing the correct parts etc. My goals for the table is for it to be reliable against tough environments and have strength against interference. If someone is interested I can get them up to speed on the project. If someone is interested please reply here and we can exchange information.
  • Moderator
  • Moderator
16 Nov 2025 14:59 #338537 by tommylight
Does it include an NDA?
17 Nov 2025 19:28 #338596 by tcbmetalworks
If you want me to sign a nda I can. Im not building tables to make money. I just want the one im retrofitting for myself to be safe and reliable. I dont expect any nda from anyone. Im open to sharing all work on the forum. Or keeping it secret if you dont want to give out ur secrets. I dont really think its super crazy complex or anything to put this together but I would like to have the components properly sized and interference to be accounted for. Just need some help finishing my project. Its alot of planning and to have someone more exp who can reference me in the right direction would save me many hours of planning and potential down time.
17 Nov 2025 19:39 #338597 by tcbmetalworks
I really want to have it documented with a print so 10 yesrs down the line its easy to fix. Correct components selected. I can work alongside you tell you what components I already have. You make a wiring diagram that is easy to follow that includes the components and wire size/grade. Make suggestions for bulk head connectors etc that are high qaulity for a reasonable price. I know you were watching my build on the forum. I make a list of the parts I have at my disposal. Anything I missing tell me what to buy. I build it and help me with trouble shooting if I need any, but shouldn't need much help with that. I got linux cnc to work on my band saw project so im not a absolute beginner, but im not a electrical engineer either. The machine will never need to pass any sort of code inspection or be sold to the public.
  • Moderator
  • Moderator
17 Nov 2025 20:12 #338598 by tommylight
I asked because i do not do NDA, ever.
Make a list of what you need and post it here, i am pretty sure someone somehow will help with it.
18 Nov 2025 17:44 #338670 by tcbmetalworks
I wrote this up in chat gpt pretty quickly I think it just about covers all of the bases here of the project.
CNC Plasma Table – Electrical & Wiring Requirements
Project: Remote design of electrical system + wiring documentation for LinuxCNC plasma table
Client: TCB Metal Works
1. Project Overview
You will remotely design the complete electrical and control system for a custom CNC plasma cutting table powered by LinuxCNC.
You will create:
Complete wiring diagram set (schematic + physical routing)
Full Bill of Materials (BOM) with real part numbers
Wire gauge, shielding, grounding, and EMI mitigation plan
Bulkhead connector list + panel layout
Mesa board selection + full LinuxCNC I/O map
Integration notes for all components
Testing & commissioning checklist
This is a 100% remote engineering job — no physical inspection of hardware is required.
2. Available Power Sources
Near the machine:
220 VAC available
460 VAC available
No dedicated 110/120 VAC, which must be generated using a control transformer if needed
Engineer must design the incoming power strategy and transformer selection.
3. Motion Hardware
3.1 X & Y Axis – AC Servos (Provided)
3× A6 Series 1000W RS485 AC Servo Motor Kits
3000 rpm
3.18 Nm
17-bit absolute encoder
IP67 motors
Axis layout:
Y axis: 2 servos (dual-drive gantry)
X axis: 1 servo
Notes:
Motor-to-drive cables are already supplied by the manufacturer.
You do not need to design or evaluate those cables.
Engineer must:
Design AC mains wiring to each servo drive
Design control, enable, alarm, and ESTOP signal wiring between drives and Mesa
Include needed fuses, breakers, filters, and terminals
Provide cabinet layout and routing plan
Include proper grounding and shielding recommendations
3.2 Z Axis – Stepper Motor (Needs Driver + Cable)
PV267-D2.8AA stepper motor — Oriental Motor
Stepper driver not provided
Stepper motor cable not provided
Engineer must:
Select a compatible stepper driver suitable for PV267-D2.8AA + LinuxCNC step/dir
Define driver voltage supply requirements
Design:
Step/Dir wiring from Mesa
Motor wiring from driver to Z motor
Required cable shielding, gauge, and insulation
Connector type and strain relief
4. Control Electronics (Mesa + Power)
Engineer must select Mesa hardware capable of supporting:
3× servo axes
1× stepper axis
THC-AD
Ohmic sensing
All limit/floating switches
Plasma start / Arc OK
E-stop & safety I/O
Deliverables:
Recommended Mesa board combination (e.g., 7i76E, 7i96S, 7i85, THCAD, etc.)
Justification for chosen hardware
Complete LinuxCNC I/O mapping
Required DC power supplies (24V / 5V / others)
Proper AC distribution, fuses, breakers, and protection devices
5. Torch Height & Ohmic Sensing
5.1 THC-AD Integration
Engineer must design:
Raw arc voltage wiring from Hypertherm HT2000 to THC-AD
THC-AD signal wiring to Mesa
Required shielding and filtering
Scaling notes for LinuxCNC
5.2 Ohmic Sensing (Planned)
Engineer must:
Recommend a compatible ohmic board
Provide wiring diagram for torch → ohmic board → Mesa
Specify cable type and shielding
Document signal polarity & behavior
6. Hypertherm HT2000 Integration
Engineer must design wiring for:
Required signals
Torch start / trigger
Arc OK
Raw arc voltage (+/–) into THC-AD
Required protection
Isolation (if needed)
Surge suppression
Filtering
EMI protection
Routing rules
Arc voltage wiring must be kept separate from low-voltage control wiring
7. Limit Switches & Floating Head
X Axis
2 limit switches:
X-min
X-max
Y Axis (Dual Gantry Drive)
2 limit switches:
Y-min
Y-max
Engineer must propose a reliable gantry squaring / homing method for the two Y motors.
Z Axis
2 end-of-travel limit switches:
Z-min
Z-max
1 floating-head switch (touch-off)
Engineer must:
Select appropriate switch type (mechanical or prox)
Provide wiring diagrams to Mesa
Specify wire gauge, shielding, and cable routing
Provide LinuxCNC input mapping
Include any debouncing/filtering requirements
8. Wiring, Shielding, & EMI
Engineer must specify:
Wire gauges for:
AC mains
Servo drive feeds
Stepper driver feeds
Stepper motor wiring
Limit/floating/ohmic wires
Plasma signals
DC supply lines
Shielding requirements for:
Step/dir
Limits/floating/ohmic
Arc voltage
THC-AD lines
EMI considerations
Cable separation
Ferrite locations
Filtering recommendations
9. Grounding & Bonding
The engineer must design the grounding/bonding approach.
Important physical detail:
The water table, gantry, and control cabinet are three separate physical assemblies.
The engineer must account for this when designing:
Grounding/bonding layout
EMC/EMI mitigation
Plasma return path considerations
Ohmic sensing grounding
No grounding method (star, bus, single-point, etc.) is mandated — the engineer chooses the correct approach.
10. Control Cabinet & Bulkheads
Cabinet Layout
AC distribution, transformers, PSUs
Mesa boards
Servo drives
Stepper driver
Fuses, breakers, contactors
DIN rail layout
Ventilation/fans
Bulkhead Connectors
Used wherever practical for:
Servo cables (using glands or pass-throughs)
Z stepper cable
Limit/floating switches
Ohmic sensing
E-stop / operator controls
Ethernet access
Connector type
Pinout
Panel cutout style
Labeling
11. Documentation Package
Engineer must deliver:
11.1 Wiring Diagram Set
Full schematic
Cabinet wiring
Field wiring
Power distribution
Grounding/bonding
Bulkhead connector pinouts
11.2 BOM
Complete list of:
Mesa hardware
Stepper driver
Transformers / PSUs
Switches
Connectors
Wire/cable
Protection devices
Cabinet hardware
11.3 I/O Map
All LinuxCNC inputs/outputs
Axis definitions
THC/ohmic mappings
E-stop & safety signals
11.4 Commissioning Checklist
Power-up verification
Servo enable/jog
Stepper test
Homing / gantry squaring
Z floating-head test
THC test
Ohmic test
EMI/noise checks
  • Moderator
  • Moderator
18 Nov 2025 17:57 #338674 by tommylight
That is a looooong list ! :)
Yet no machine dimensions, weight of moving parts, drive train, reduction, materials used, etc...
And just putting it out there, 1KW servo motors for a plasma machine is utter overkill, no matter how big or heavy. The biggest i have seen on old industrial machines were 400W, with reduction two of those could fling a probably 200KG heavy gantry at 18m/m!
18 Nov 2025 21:37 #338698 by tcbmetalworks
Here is a link to the thread of me documenting the process of building the table to get to where it is right now. Yes the motors are overkill but they are not really too big of a form factor and the gantry estimated weight is 400-800lbs. I have the machine geared to run 700ipm rapid if I remember correctly. Alot of force required to rapidly change directions at fast cut speeds on a gantry this large. And yes the list is long. Really I need help documenting and planning this project to speed things up. Draw a wiring diagram and point me in the right direction for parts. I want a diagram so its easy to fix for the next guy, and I can make sure then that everything is properly grounded/bonded and resistant to interfearence. The only thing I forgot on that list is a circuit for e stop maybe using a saftey relay and I may add in a lube pump to pump oil into the tracks and rollers.
  • Moderator
  • Moderator
06 Dec 2025 02:17 #339788 by tommylight
Anyone? :)
Probably got terrified of the long (and not very useful) list.
The list should be something like:
-e-stop chain
-limit and home switches (with sensor input relays for full isolation)
-extreme limit switches for DC brushed motor machines (to prevent mayhem in case of runaway)
-Mesa boards wiring to drives, input relays, output relays, and maybe MPG
-power section
-list of connectors and pinouts
Thing is, we can not make a schematics for you without having every exact detail about your machine setup and wiring, that is something you have to provide.
Or do you want us to come up with the wiring and base your machine on that?
Personally, i write things on paper and take pictures of those papers for archiving, while the papers go with the machine.
Time to create page: 0.721 seconds
