Upgrading 2.4.3 to 2.4.6
- TarHeelTom
I have two of them, one is earmarked for my BP Discovery 308 VMC... I still like mine.
What kind of jitter rate do you get?
Tom
- TarHeelTom
Also, how much memory do you need on this board to run emc2? This will be a dedicated machine, won't be playing games or internet or music or videos or whatever.
Tom
1 GB and an 8GB SATA DOM flash drive is plenty. In fact you can probably use a 4GB drive, I actually do EMC development in 8GB…
- TarHeelTom
Thanks for the reply, Andy.
Just gutted my old case, with a new motherboard in it, at the max jitter was up aroung 70,000. On the recommendation on this board, bought a D510MO board from newegg, and the 2G of memory and the 160 Meg hard drive that they recommend with the D510MO. Had about a dozen failed installs last night, and am getting ready to download the LiveCD again and start over, this time checking the checksum. Interesting that the LiveCD loaded up just fine on my Windows 7 computer, but not on the D510MO. One thing the newegg ad doesn't mention is that although there is support for a parallel port built into the card, there is no DB25 socket, so need to order a cable tonight inorder the use the built-in parallel port. Already have a second parallel port in the only PCI slot.
This one part of the process is getting a little bit frustrating.
Tom
- TarHeelTom
I ask Ubuntu to install itself, then answer all the questions. it shows two partitions, but not the partition containing Ubuntu.
I get the Ubuntu welcome screen but before I can read it all, I get this error message:
(process:296): GLib WARNING**: failed due to unknown user id(0)
I've made several different LiveCD disc, and on the last one check the md5checksum before burning the disc. Also, the last disc loaded up well on my Windows 7 computer, but I certainly don't want it to install over Window 7.
Any ideas?
![:S :S](/media/kunena/emoticons/dizzy.png)
![:( :(](/media/kunena/emoticons/sad.png)
However, that pin header is perfect for a simple ribbon-cable connection to a Mesa 7i43.One thing the newegg ad doesn't mention is that although there is support for a parallel port built into the card, there is no DB25 socket
The cable required is the standard one that comes with dual-port PCI cards, and you should be able to find one very cheaply.
As for the installation issues, I don't know what the problem is, but I would be tempted to try installing from a USB stick. That is what I did, and it worked fine. I did it because I don't have a CD drive that can connect to the motherboard.
As I recall, I did it using utils from pendrivelinux.com using the EMC2 live-CD .iso.
- TarHeelTom
Thanks, Andy. I'll try using the USB stick today. Just bought a fresh one Friday. Seems like I've seen instructions somewhere on using a USB stick.
Unfortunately, I'd already bought a PMDX-132 bob about a year ago, and it was working. Hadn't heard of the mesa boards until recently. Wonder if mesa will be at the CNC Seminar in Ann Arbor next week? Anyway, I've ordered this cable from newegg:
www.newegg.com/Product/Product.aspx?Item...200833&Tpk=plate25fb
Thanks again.
Tom
- TarHeelTom
I've had problems in the past if I didn't burn the liveCD at the slowest speed. The fact that it boots up in your win machine kinda tells me it is ok... is the CD drive in the D510MO machine a new one?
Yes, the CD drive is new to me, although I think it is a used unit. But it's a SATA drive, and I didn't have any SATA units on hand, so bought one from the local computer shop.
Since I didn't have any SATA units of any kind on hand, everything but the POS case and the power supply in the case is new.
Tom
