Segmentation fault $EMCDISPLAY -ini ......
21 Jun 2011 09:31 #10695
by michel45
Segmentation fault $EMCDISPLAY -ini ...... was created by michel45
hello,
The launch of emc2 I have a problem opening the window emc2. (see file attached).
In the ini file: axis with the interface it works (DISPLAY = axis), but with our specific interface (in qt4) does not work.
With an ini file in simulation mode (without hosmot2) we have no problem whatsoever with the interaction axis or our interface.
Our configuration:
Ubuntu 10.10
emc 2.4.5
rtai 3.8
If someone has an idea, thank you in advance.
Our configuration:
Ubuntu 10.10
emc 2.4.5
rtai 3.8
21 Jun 2011 12:33 #10700
Replied by andypugh on topic Re:Segmentation fault $EMCDISPLAY -ini ......
You might find that this helps you track down the offending program line:
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...4b9387abd24a7ac6d707
22 Jun 2011 09:21 #10754
by michel45
Replied by michel45 on topic Re:Segmentation fault $EMCDISPLAY -ini ......
thank you for the info.
I think I have found, I have trouble with the compilation of our interface and liaison with the library libnml.
Michel
Michel
22 Jun 2011 15:45 #10773
by michel45
Le 22.06.2011 12:28, David Armstrong a écrit :
This is a message from David Armstrong at LinuxCNC.org ( www.linuxcnc.org ) to you:
> are you able to share your project ?
> i am looking for a initial starter project for emc in qt4
> i would also be able to assist in fault finding with you
> kind regards
> David
NOTES:
> This user did not see your email address. If you reply the recipient will have your email address.
> LinuxCNC.org owners cannot accept any responsibility for the contents of the email and of user email addresses.
Hello,
Thank you for your offer of assistance. We discuss a possible setting for a free license of all, some or not the project.
Probably we will present the project at the beginning of September.
best regards
Michel
> kind regards
> David
NOTES:
Hello,
best regards
Michel
Time to create page: 0.202 seconds
