10.4 install problem
17 Oct 2011 21:08 #13997
by guyver001
10.4 install problem was created by guyver001
Hi guys new to EMC ubuntu
heres my problem i have tryed to install the new version 10.04 & emc but it will not install gets so far and just freezes (cleen install)
dont know why but i have installed the older 8.04 & emc i think. and it works fine no problems at all
seems odd
pentium duocore 2Ghz
2 Gig ram
120G HD
64bit invidia graphics card
i would like to install the new version
tryed different versions of Ubuntu but only version 8.04 works
any ideas
seems odd
2 Gig ram
120G HD
any ideas
18 Oct 2011 09:12 #14007
by ArcEye
Replied by ArcEye on topic Re:10.4 install problem
Hi
This is a Ubuntu issue rather than EMC
A google search will throw up hundreds of people reporting similar issues with 10.04 and probably every release prior to and since.
If you search Ubuntu forum, you may find something relating specifically to your machine and whether anyone has found a way of installing to it.
If you want to try a newer version of EMC, you can download and compile it to run on Ubuntu 8.04
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Installing_EMC2
18 Oct 2011 10:16 #14013
by Rick G
Replied by Rick G on topic Re:10.4 install problem
Are you installing from the emc live CD?
Can you boot from the live CD and run 10.04? or does this also hang?
Did you compare the chesksum?
How far does the install get?
You may want to look at video options on install.
Rick G
Rick G
18 Oct 2011 12:50 #14016
Replied by andypugh on topic Re:10.4 install problem
guyver001 wrote:
All current versions of EMC2 work on 8.04.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?UpdatingTo2.4
Well, the simplest idea would be to use 8.04 and upgrade EMC2 to the latest version while keeping Ubuntu at 8.04.ryed different versions of Ubuntu but only version 8.04 works
any ideas
18 Oct 2011 13:08 #14018
by guyver001
Replied by guyver001 on topic Re:10.4 install problem
yep it runs fine from live cd but it will not install
18 Oct 2011 13:18 #14019
by BigJohnT
Replied by BigJohnT on topic Re:10.4 install problem
Are you using the entire hard disk for the install?
Is it a SATA drive?
Do you have another HD to try?
I've had a HD with windows installed and never could get Ubuntu to install over it so I swapped to a freshly formatted drive and the install went fine.
Is it a SATA drive?
18 Oct 2011 14:31 #14024
by guyver001
tryed upgrading EMC2 useing install.sh file looked like it was doing something but on restart nothing happened
but i did notice in my update manager there is emc2 but it is greyed out so i cant install it
18 Oct 2011 14:52 - 18 Oct 2011 14:54 #14026
guyver001 wrote:
Why did you do that? That script is for something else. (Installing EMC2 onto a standard Ubuntu installation, which doesn't have EMC2).
I gave you a link which explained how to upgrade through the package manager.
Last edit: 18 Oct 2011 14:54 by andypugh.
18 Oct 2011 17:45 #14029
by guyver001
lol yep dont know what i was thinking when i did that anyhow got the upgrade done now thanks for your help
