Compiling from source errors
08 Nov 2011 11:06 #14670
by stevec
Compiling from source errors was created by stevec
I have been compiling EMC --enable-simulation, from the git repositories on a Debian6 system without problems until recently.
I manged to break the Debian system by faffing around with the testing repositories, that is now fixed, but I can't compile EMC any more.
I have changed the kernel to linux-image-3.0.0-1-amd64, can somebody give me a clue what else might have changed?
The relevant bit of the compile/link process seems to be
/usr/bin/ld: objects/emc/task/taskclass.o: undefined reference to symbol 'PythonPlugin::configure(char const*, char const*, _inittab*, Interp*)'
/usr/bin/ld: note: 'PythonPlugin::configure(char const*, char const*, _inittab*, Interp*)' is defined in DSO /home/steve/storage/emc2-dev/lib/libpyplugin.so.0 so try adding it to the linker command line
/home/steve/storage/emc2-dev/lib/libpyplugin.so.0: could not read symbols: Invalid operation
08 Nov 2011 11:19 #14671
Replied by andypugh on topic Re:Compiling from source errors
There is a new dependency (libboost-python-dev) and you probably need to make clean after installing it.
08 Nov 2011 20:40 #14699
by stevec
Replied by stevec on topic Re:Compiling from source errors
Thanks, I tried reinstalling the libboost-python-dev package but it made no difference.
Whatever is wrong has affected heekscad/heekscnc as well.
I will continue poking around and if I find out what it is I will post details back here.
11 Nov 2011 06:15 #14754
by mhaberler
Replied by mhaberler on topic Re:Compiling from source errors
could you do the following:
cd src
make clean
make V=1
and post the output to pastebin.com or upload it somewhere so I can have a look?
-Michael
cd src
make clean
make V=1
-Michael
11 Nov 2011 08:10 - 11 Nov 2011 08:14 #14756
by stevec
I have posted the tail end of the process to pastebin.com/3912AbUv
I can now get heekscad to compile, but EMC stops at exactly the same place still.
Edit : it was on pastebin I will update the link above when I find it again
Last edit: 11 Nov 2011 08:14 by stevec.
11 Nov 2011 08:40 #14758
by mhaberler
thanks
it seems to me that src/emc/pythonplugin/Submakefile has an error, but I dont understand why
it throws on your platform but not on 8.04 and 10.04
could you try the following:
change src/emc/pythonplugin/Submakefile:
../lib/libpyplugin.so.0: $(patsubst %.cc,objects/%.o,$(LIBPPSRCS)) ../lib/libemcini.so
to read
and try to recompile?
-Michael
to read
-Michael
11 Nov 2011 08:58 #14759
by stevec
It brings up a new error
Compiling emc/rs274ngc/rs274ngc_pre.cc
/usr/bin/g++ -c -I. -Ilibnml/linklist -Ilibnml/cms -Ilibnml/rcs -Ilibnml/inifile -Ilibnml/os_intf -Ilibnml/nml -Ilibnml/buffer -Ilibnml/posemath -Irtapi -Ihal -Iemc/nml_intf -Iemc/kinematics -Iemc/motion -Iemc/ini -Iemc/rs274ngc -Iemc/pythonplugin -I/home/steve/storage/emc2-dev/src/include -I/usr/include/python2.7 -Os -g -Wall -DULAPI -fPIC emc/rs274ngc/rs274ngc_pre.cc -o objects/emc/rs274ngc/rs274ngc_pre.o
emc/rs274ngc/rs274ngc_pre.cc: In member function ‘int Interp::remap_finished(int)’:
emc/rs274ngc/rs274ngc_pre.cc:543:6: warning: format ‘%d’ expects argument of type ‘int’, but argument 8 has type ‘std::set<int>::size_type {aka long unsigned int}’ [-Wformat]
make: *** No rule to make target `../lib/libpyplugin.so', needed by `../lib/librs274.so.0'. Stop.
make: Leaving directory `/home/steve/storage/emc2-dev/src'
It is strange that this has only happened since I tried Gnome3 (now removed) from testing . There are a few google results about the original linker errors but they are beyond my understanding.
11 Nov 2011 11:27 #14762
by cncbasher
Replied by cncbasher on topic Re:Compiling from source errors
you may find reverting python to version 2.6 instead of the latest 2.7 fixes ...
their are i belive some parts of EMC which are hardcoded or linked to python 2.6 , you could try searching the makefile and changing entrys etc , just a thought
upgrading to latest versions is alway fraught with danger ! , you never know whats left behind
11 Nov 2011 12:17 #14763
by mhaberler
strange. what does 'ls -l lib' say?
this is what I have in lib, and that looks ok:
lrwxrwxrwx 1 mah mah 16 2011-11-10 08:16 libpyplugin.so -> libpyplugin.so.0
-rwxr-xr-x 1 mah mah 312532 2011-11-10 08:16 libpyplugin.so.0
-mah
-mah
11 Nov 2011 12:18 #14764
by mhaberler
re Python 2.6 path: not with a recent master, this is now autoconfig-derived
-mah
-mah
Time to create page: 0.480 seconds
