Back to the Dell but still have problems.
07 Jan 2012 12:11 #16403
by boldford
Back to the Dell but still have problems. was created by boldford
Whilst I'm waiting for a parallel card to arrive for my little BRO as a self-teaching exercise I thought I'd install EMC on a Dell machine I have knocking around.
To ensure things went smoothly I completely wiped the hard drive using Seagate Diskwizard.
I then installed EMC2 + 10.04 from my live CD. Avoiding doing any updates, all seems OK and I'm able to access the web and run a latency test just fine.
When I try to run any of the sim configurations the mouse pointer changes to a black spot which then prevents any further operations. I can then only get out of this situation by power cycling the machine.
Have I missed a trick?
07 Jan 2012 12:43 #16404
by BigJohnT
Replied by BigJohnT on topic Re:Back to the Dell but still have problems.
If it is an older machine you might try the 8.04 LiveCD.
Also you might have an opengl problem with that machine. Can you run sims other than axis and touchy like tkemc? There is a software opengl but I can't seem to find the link atm.
07 Jan 2012 12:45 #16405
by BigJohnT
Maybe this is the link I was thinking of...
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Tro...oting#Display_Issues
07 Jan 2012 16:50 #16414
by boldford
Replied by boldford on topic Re:Back to the Dell but still have problems.
I checked for a /etc/X11/xorg.conf and there isn't one. Then tried creating xorg.conf as suggested and received the following:-
sudo Xorg -configure
[sudo] password for brian:
Fatal server error:
Server is already active for display 0
If this server is no longer running, remove /tmp/.X0-lock
and start again.
Please consult the The X.Org Foundation support
at wiki.x.org
for help.
ddxSigGiveUp: Closing log
I forgot to mention a straight Ubuntu 10.04 installs fine in this machine too.
From where can I download an 8.04 ISO to create a live CD?
Fatal server error:
and start again.
at wiki.x.org
for help.
07 Jan 2012 17:04 #16415
by BigJohnT
Right here on the download page.
linuxcnc.org/index.php/english/download/21?task=view
you have to scroll down for 8.04
07 Jan 2012 17:45 #16416
by boldford
BigJohnT wrote:
Meanwhile I'm also attacking this on the other front with a circa 30 minute download of 8.04.
I think you may be correct there as the touchy and tkemc sims seem to be OK. I think it's only axis and its variants that are acting up. If you can point me in the direction of that opengl link I'll be gratefulIf it is an older machine you might try the 8.04 LiveCD.
07 Jan 2012 18:08 #16417
by ArcEye
Replied by ArcEye on topic Re:Back to the Dell but still have problems.
Hi once more,
Ref switching to the software open_gl see this previous post for easiest way to do it.
A black circle or square when trying to start a gl dependent program is a classic error.
www.linuxcnc.org/index.php/english/compo...tid=9&id=15939#15974
The error regards xorg -configure is the same from your previous post, you cannot run the command with an active xserver running.
It has to be done from a non-graphic terminal, or else manually create the file and re-boot to run and test it
www.linuxcnc.org/index.php/english/compo...9&id=15936#15958
Keep 10.04 and try switching to software gl before doing anything about vesa, or switching to 8.04, or you will end up chasing your tail!
07 Jan 2012 18:43 - 07 Jan 2012 21:18 #16418
by boldford
I'm glad I held off on the 8.04 at your suggestion..
Once I understood the difference between 1 (one) and l (el) in sudo apt-get install libgl1-mesa-swx11 all became well.
Many thanks.
Many thanks.
Last edit: 07 Jan 2012 21:18 by boldford.
Time to create page: 0.386 seconds
