OpenGL
07 Jan 2012 19:14 - 07 Jan 2012 19:19 #16420
by BigJohnT
A black circle or square when trying to start a gl dependent program is a classic error.
www.linuxcnc.org/index.php/english/compo...tid=9&id=15939#15974
The error regards xorg -configure is the same from your previous post, you cannot run the command with an active xserver running.
It has to be done from a non-graphic terminal, or else manually create the file and re-boot to run and test it
www.linuxcnc.org/index.php/english/compo...tid=9&id=15936#15958
Thanks to ArcEye for keeping us on the ball.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Tro...oftware_based_OpenGL
Last edit: 07 Jan 2012 19:19 by BigJohnT.
Time to create page: 0.177 seconds
