Problems with the mouse when I upgrade to 2.4.7
- garymcrobertpdx
29 Jan 2012 03:40 - 29 Jan 2012 04:16 #17248
by garymcrobertpdx
Problems with the mouse when I upgrade to 2.4.7 was created by garymcrobertpdx
I upgraded DELL #1 to Ubuntu 8.04 EMC2.4.7 piece of cake! Then I upgraded DELL#2 which drives the mill
for some reason the mouse is lurching about, completely unusable. Any idea as how to fix this problem?
One difference between Dell#1 and Dell#2 Dell#1 has a duel boot with Ubuntu 8.04 and
Ubuntu 10.04 (although I'm not using 10.04) is it possible that this is why Dell #2 works correctly?
Last edit: 29 Jan 2012 04:16 by garymcrobertpdx.
29 Jan 2012 10:53 - 29 Jan 2012 10:54 #17249
by ArcEye
Replied by ArcEye on topic Re:Problems with the mouse when I upgrade to 2.4.7
Hi
Can't tell from what you say if you have just upgraded to LinuxCNC 2.4.7 from a fully functioning installation, which can't have any effect on the mouse, or whether you have installed 8.04 and upgraded together, in which case the problem would be with 8.04 not the LinuxCNC upgrade.
We don't know what type or make of mouse you have, both 8.04 and 10.04 have caused a lot of problems with both PS2 and USB mice, probably in part down to its its generated xorg.conf (8.04) and automatic mouse / keyboard / monitor detection (10.04) respectively.
My USB mouse sometimes ceases working completely with 10.04 but comes back again if I unplug and re-plug it in.
This thread suggests one solution for 8.04,
adventuresinswitching.blogspot.com/2008/...e-on-ubuntu-804.html
and there are other references to the problem you describe specifically,
but you are going to have to search under ubuntu forums with your specific problem, hardware etc to narrow down from there, if that does not assist.
Last edit: 29 Jan 2012 10:54 by ArcEye.
- garymcrobertpdx
29 Jan 2012 18:09 #17265
by garymcrobertpdx
Replied by garymcrobertpdx on topic Re:Problems with the mouse when I upgrade to 2.4.7
Thanks for the info I will try some of the methods in the link
The problem is defiantly associated with the upgrade to 2.4.7
all mice worked before with 2.3. I have several USB mice
Dell, Microsoft and a generic all use to work.
Time to create page: 0.299 seconds
