Re-Installation
i have to much problems with new installation(s).
i can't say way ... but my machin is not working with all new versions .
i make the "auto-update" and not is going bevor ..
what can i do - to back(install) to the emc2 from the 10.4 ubunto "live-cd" withOUT a full installation
wy the second axis is not more going right - its me a riddle
i would be update to aktual emc/ linuxcnc - 2.5 or what ever
in my "ubunto-software-manager" i must insert the http:.... source" to what ?
only for update emc and NOT ubunto(shit) now i have 4 installations on my harddisk and no with korrekt
WHAT is the right way for future to update ONLY emc2 ?
bigJohn BigThanks
but what is the "must" to update emc2 at 2.5 or 2.6 ?
after reinstallation from 10.4 cd
my gladevcp and other make then problems *g*
*smile*
> X buildbot.linuxcnc.org/ lucid mater-rt
> X buildbot.linuxcnc.org/ lucid mater-rt (Quelltext)
its this the right "place"
ant not archive etc.
Any configuration that worked OK with the old version of EMC2 should work with the 2.5 version of LinuxCNC.i have to much problems with new installation(s).
Are there any clues what is going wrong in dmesg?
i can't back to fine-power for one of my 2 axes (y)
bevor i "gamed"
i come to ~8 ... 12 meters/min and its "fine" with ~ 0.1 mm f.error ...
now i have allways a f.error btw. i come to max 2 meters/ min ...
in the installation 5i20 after live-cd comes:
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.pwm_frequency 40000
... right = 20000
> but have no change in power ...
its this a problem wy 7i29 powering 2 DCmotors (900/800 watt)
but bevor my shit-gaming *g* all was good running so
i can't think to other logigs problems etc.
and i am a big big idiot - and have no imagecd make
my "germanTeacher" -> cnc-ready.at its missing
> by searching for infos the next prob *g* its i must 5 from 10 words translate to german to understand *g*
when i go with my HEAD to wall and after its going ok ... but i think still the same
PS: allways the accelaeration makes the probs
Axis 1 -> bevor its ~ 1200 ! ok
now its begin to strong at ~ 200
at same PID etc. ...
ok .. thanks ... my women is now the PID and i must drive home
the next i make -again- the conection from the 7i29 Axis 0 to 1 and 1 to 0 and look for the probs.
good drive
dmsg:
[21915.382091] I-pipe: Domain RTAI unregistered.
[21915.382117] RTAI[hal]: unmounted.
[22031.924421] I-pipe: Domain RTAI registered.
[22031.924426] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[22031.924428] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[22031.924453] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[22031.924455] PIPELINE layers:
[22031.924457] fd4dde20 9ac15d93 RTAI 200
[22031.924459] c085cb20 0 Linux 100
[22031.938843] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[22031.938979] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[22031.938983] RTAI[sched]: hard timer type/freq = APIC/20832837(Hz); default timing: periodic; linear timed lists.
[22031.938986] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666507000 hz.
[22031.938988] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[22031.939047] RTAI[usi]: enabled.
[22031.965252] RTAI[math]: loaded.
[22032.023458] hm2: loading Mesa HostMot2 driver version 0.15
[22032.025423] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[22032.025450] hm2_pci: discovered 5i20 at 0000:04:00.0
[22032.025495] hm2_5i20.0: firmware: requesting hm2/5i20/SVST8_4.BIT
[22032.152641] hm2/hm2_5i20.0: 72 I/O Pins used:
[22032.152645] hm2/hm2_5i20.0: IO Pin 000 (P2-01): Encoder #1, pin B (Input)
[22032.152648] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Encoder #1, pin A (Input)
[22032.152650] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Encoder #0, pin B (Input)
[22032.152653] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Encoder #0, pin A (Input)
[22032.152655] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Encoder #1, pin Index (Input)
[22032.152657] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Encoder #0, pin Index (Input)
[22032.152660] hm2/hm2_5i20.0: IO Pin 006 (P2-13): PWMGen #1, pin Out0 (PWM or Up) (Output)
[22032.152662] hm2/hm2_5i20.0: IO Pin 007 (P2-15): PWMGen #0, pin Out0 (PWM or Up) (Output)
[22032.152665] hm2/hm2_5i20.0: IO Pin 008 (P2-17): PWMGen #1, pin Out1 (Dir or Down) (Output)
[22032.152667] hm2/hm2_5i20.0: IO Pin 009 (P2-19): PWMGen #0, pin Out1 (Dir or Down) (Output)
[22032.152670] hm2/hm2_5i20.0: IO Pin 010 (P2-21): PWMGen #1, pin Not-Enable (Output)
[22032.152672] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Not-Enable (Output)
[22032.152675] hm2/hm2_5i20.0: IO Pin 012 (P2-25): Encoder #3, pin B (Input)
[22032.152677] hm2/hm2_5i20.0: IO Pin 013 (P2-27): Encoder #3, pin A (Input)
[22032.152679] hm2/hm2_5i20.0: IO Pin 014 (P2-29): Encoder #2, pin B (Input)
[22032.152681] hm2/hm2_5i20.0: IO Pin 015 (P2-31): Encoder #2, pin A (Input)
[22032.152684] hm2/hm2_5i20.0: IO Pin 016 (P2-33): Encoder #3, pin Index (Input)
[22032.152686] hm2/hm2_5i20.0: IO Pin 017 (P2-35): Encoder #2, pin Index (Input)
[22032.152689] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out0 (PWM or Up) (Output)
[22032.152691] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #2, pin Out0 (PWM or Up) (Output)
[22032.152693] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #3, pin Out1 (Dir or Down) (Output)
[22032.152696] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #2, pin Out1 (Dir or Down) (Output)
[22032.152698] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #3, pin Not-Enable (Output)
[22032.152701] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #2, pin Not-Enable (Output)
[22032.152703] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[22032.152705] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[22032.152707] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[22032.152709] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[22032.152711] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[22032.152713] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[22032.152715] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[22032.152716] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[22032.152718] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[22032.152720] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[22032.152722] hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
[22032.152724] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[22032.152726] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[22032.152728] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[22032.152729] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[22032.152731] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[22032.152733] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[22032.152735] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[22032.152737] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[22032.152739] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[22032.152741] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[22032.152743] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[22032.152744] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[22032.152746] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[22032.152748] hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
[22032.152750] hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
[22032.152752] hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
[22032.152754] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[22032.152756] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[22032.152758] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[22032.152760] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[22032.152762] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[22032.152764] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[22032.152765] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[22032.152767] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[22032.152769] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[22032.152771] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[22032.152773] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[22032.152775] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[22032.152777] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[22032.152779] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[22032.152780] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[22032.152782] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[22032.152784] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[22032.152786] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[22032.152788] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[22032.152790] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[22032.152792] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[22032.152854] hm2/hm2_5i20.0: registered
[22032.152856] hm2_5i20.0: initialized AnyIO board at 0000:04:00.0
[22526.873428] hm2_5i20.0: dropping AnyIO board at 0000:04:00.0
[22526.873431] hm2/hm2_5i20.0: unregistered
[22526.873460] hm2_pci: driver unloaded
[22526.874894] hm2: unloading
[22526.899434] RTAI[math]: unloaded.
[22526.921827] SCHED releases registered named ALIEN RTGLBH
[22526.952343] RTAI[malloc]: unloaded.
[22527.052021] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[22527.053822] I-pipe: Domain RTAI unregistered.
[22527.053849] RTAI[hal]: unmounted.
rb1@rb1Laser:~$
i come not back to "good-drive"
Are you using HALScope for tuning? (I would suggest this)
if so can you post a HalScope screenshot here that illustrates you tuning problem?
> with f.error for x and y ? or what its a good HalScope-view ?
at this time i have 100red experiments in the PID
my first problem its: i have in "mind" its going with my "old PID and accelaration"
when i make new configs with pnCConf (verry good programm) i have in 1 from 5 configs
the >feeling< its good . but with a litle more power/speed i hear/listen the Y-axis its <squeak> at start
btw. its <slip trough> at the motor (DC/900 W).
This is that what i think its different to myOldConfiguration:
[Display]
> MAX/MIN _LINEAR_VELOCITY and _ANGULAR_VELOCITY
its that a new optimizing-function ? where not in older configs importand ?
but when yes: and i copy my OLD 5i20.in and start with that
i lie right: when not write in ini then linuxCNC give a standard numbers at this parameters ?
Now i have LINUXCNC updatet (i hope correct:-)
thanks for helping
- and i give a big bottle bear at the < munich octoberfest >
