StepConf 2nd parallel port direction
25 Feb 2012 01:42 #18056
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
StepConf 2nd parallel port direction was created by RayJr
I have noticed that when using StepConf to set up the second parallel port, when you set it for "in", the entry in the HAL file is set to "OUT". If you set it in stepconf for "out", it is in the HAL file as "in". The logic is inverted!
I have seen this behavior on V2.4.6, 2.4.7, and now on LinuxCNC 2.5.0-pre2-890.
Is there somewhere else I should report this bug?
Ray
Ray
Albert Einstein
25 Feb 2012 13:54 #18077
by BigJohnT
Replied by BigJohnT on topic Re:StepConf 2nd parallel port direction
Normally the bug tracker is the place to report bugs... if you can reproduce them. This sounds like a bug to me.
linuxcnc.org/index.php/english/community
26 Feb 2012 16:53 #18099
by BigJohnT
Ray,
This has been fixed, thanks for letting us know.
26 Feb 2012 18:39 #18102
by RayJr
Albert Einstein
Replied by RayJr on topic Re:StepConf 2nd parallel port direction
Is there a new build?
FYI
I tried the "Information about submitting bug reports" link on the documentation page and it gave me a 404 page not found error.
Ray
FYI
Ray
Albert Einstein
26 Feb 2012 18:43 #18103
by BigJohnT
If your using the buildbot 2.5 a new build comes out within and hour or so of the commit. If your using 2.4 installed from the LiveCD then you have to wait for an official release.
Thanks I'll pass on the 404 error... and I thought we had them all fixed.
26 Feb 2012 19:02 #18105
by BigJohnT
And it seems that I was able to fix that one... so it must have been simple.
27 Feb 2012 06:56 #18114
by RayJr
Albert Einstein
Cool
Working now!
Ray
Working now!
Ray
Albert Einstein
