Problem Update to 2.5 from 2.3 with Hardy 8.04
12 Apr 2012 12:33 #19142
by bigalex
Problem Update to 2.5 from 2.3 with Hardy 8.04 was created by bigalex
Hello people
I updated the system to EMC2 (linuxcnc) v2.5 from v2.3 on Hardy 8.04 following the wiki specification .
I moved my machine configuration into the appropriate directory and change the root for the ngc file folder.
I started the machine configuration but after a while I had the stop of the configuration loading and the Log appears as below :
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.4
LINUXCNC - 2.5.0
Machine configuration directory is '/home/cnc/linuxcnc/configs/robomill'
Machine configuration file is 'robomill.ini'
INIFILE=/home/cnc/linuxcnc/configs/robomill/robomill.ini
PARAMETER_FILE=emc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
libnml/buffer/physmem.cc 143: PHYSMEM_HANDLE: Can't write 11592 bytes at offset 60 from buffer of size 10208.
libnml/cms/cms_in.cc 1373: CMS:(emcStatus) Error writing 11592 bytes to global memory at offset 0x82fcd18
(See libnml/cms/cms_in.cc line 1376.)
* Current Directory = /home/cnc/linuxcnc/configs/robomill
* BufferName = emcStatus
* BufferType = 0
* ProcessName = emc
* Configuration File = emc.nml
* CMS Status = -3 (CMS_INTERNAL_ACCESS_ERROR: An error occured during an internal access function. )
* Recent errors repeated:
(See libnml/cms/cm
* BufferLine: B emcStatus SHMEM localhost 10240 0 0 2 16 1002 TCP=5005 xdr
* ProcessLine: P emc emcStatus LOCAL localhost W 0 1.0 0 0
* error_type = 5 (NML_INTERNAL_CMS_ERROR)
libnml/cms/cms_in.cc 1082: CMS:(emcStatus) Message size of 11592 exceeds maximum of 10180
* BufferType = 0
* ProcessName = xemc
* ProcessLine: P xemc emcStatus LOCAL localhost R 0 10.0 0 10
Maximum number of errors to print exceeded!
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Killing task linuxcncsvr, PID=7416
Killing task milltask, PID=7553
INFO CLASSICLADDER---I/O modbus master closed!
INFO CLASSICLADDER---I/O modbus master (Ethernet) init ok !
INFO CLASSICLADDER- Modbus I/O module to send: Lgt=21 <- Slave address-0 Function code-1 Data-0 0 0 F 1 10 0 10 0 4 8 0 0 0 0 0 0 0 0
Init socket for I/O module (0)...
Connecting I/O module...
Failed to connect to I/O module
INFO CLASSICLADDER- Modbus I/O module to send: Lgt=21 <- Slave address-0 Function code-2 Data-0 0 0 F 1 10 0 10 0 4 8 0 1D 0 3A 0 57 0 74
ERROR CLASSICLADDER- Error intializing classicladder user module.
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Unrecognized line skipped: POC FMS LEN DIAM COMMENT
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
7416
PID TTY STAT TIME COMMAND
7553
7553 ? Z 0:00 [milltask] <defunct>
Stopping realtime threads
Unloading hal components
ULAPI: WARNING: module 'HAL_classicladder' failed to delete shmem 03
Kernel message information:
[ 7066.831359] I-pipe: Domain RTAI registered.
[ 7066.831365] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 7066.831367] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[ 7066.831371] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7066.831372] PIPELINE layers:
[ 7066.831374] f8b26000 9ac15d93 RTAI 200
[ 7066.831375] c0383180 0 Linux 100
[ 7066.838903] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7066.839180] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 7066.839184] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[ 7066.839187] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 2194554000 hz.
[ 7066.839188] RTAI[sched]: timer setup = 2010 ns, resched latency = 2688 ns.
[ 7066.899164] RTAI[math]: loaded.
[ 7066.957857] config string '0x2430 out '
[ 7066.965887] creating ladder-state
[ 7073.683312] RTAI[math]: unloaded.
[ 7073.734475] SCHED releases registered named ALIEN RTGLBH
[ 7073.747681] RTAI[malloc]: unloaded.
[ 7073.847363] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7073.849041] I-pipe: Domain RTAI unregistered.
[ 7073.849048] RTAI[hal]: unmounted.
Thanks a lot for any advice.
bigalex
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=halui
DISPLAY=axis
* BufferType = 0
* ProcessName = emc
(See libnml/cms/cm
* BufferType = 0
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Cleanup done
7416
7553
bigalex
12 Apr 2012 12:55 - 12 Apr 2012 12:58 #19143
by BigJohnT
Replied by BigJohnT on topic Re:Problem Update to 2.5 from 2.3 with Hardy 8.04
I'm positive you missed a step in changing things from 2.3 to 2.5.
Did you follow the instructions on this page ?
Last edit: 12 Apr 2012 12:58 by BigJohnT.
12 Apr 2012 13:12 #19144
by bigalex
Replied by bigalex on topic Re:Problem Update to 2.5 from 2.3 with Hardy 8.04
No I use this http://http://wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.5
12 Apr 2012 13:18 #19145
by bigalex
Thanks for the link John.
I solved with that :
Thanks again.
bigalex
1.1. emc.nml changes
For configurations that have not customized emc.nml, remove the inifile line NML_FILE = emc.nml. This will cause the most up to date version of emc.nml to be used.
For configurations that have customized emc.nml, a change similar to this one is required.
Failure to do this can cause an error like "libnml/buffer/physmem.cc 143: PHYSMEM_HANDLE: Can't write 10748 bytes at offset 60 from buffer of size 10208."
Thanks again.
bigalex
