no linuxcnc start scripts after new installation
16 May 2012 15:06 #20146
by schuhmann
Replied by schuhmann on topic Re:no linuxcnc start scripts after new installation
Nice shot! Ext2 worked.
And suddenly all the little linuxcnc start scrips are where they belong.
Thank You very much!
Regards
Regards
16 May 2012 15:10 - 16 May 2012 15:18 #20147
by ArcEye
Replied by ArcEye on topic Resolved :no linuxcnc after new installation
Hi
Glad you got that sorted - leaves a BIG question as to why ubiquity, which was running on a 2.6.32-122-rtai kernel at the time and quite happily playing with a
ext4 partition, thought it needed the stock kernel.
I will have to look at the modules and try to get hold of the kernel .config file
This probably needs flagging up until resolved
Last edit: 16 May 2012 15:18 by ArcEye.
16 May 2012 16:35 #20151
by ArcEye
Replied by ArcEye on topic LinuxCNC install onto ext4 partition
Post Script
Checked /lib/modules/2.6.32-122-rtai/_modules-builtin and sure enough ext4 support is built into the rtai kernel
So the installer should not have changed kernels, if that was the reason behind it, rather than some more subtle knock on effect.
The root of the problem is most likely to be the fiendishly complicated install scripting process for Ubuntu, onto which LinuxCNC has been grafted as
an extra few packages.
It may well have hard coded kernel choices for that file system when detected.
The bottom line is probably that ext4 is still being developed, breaks backwards compatibility and why would you need 16TB disk and
2TB file addressing capability for a CNC system that will install and run on < 2GB !?
Probably best to use ext2, or ext3 if you must, and avoid ext4 on LinuxCNC for now.
17 May 2012 16:46 #20185
by schuhmann
It’s me again,
so, cancel my last. It had nothing to do with file system. At the last try I removed the network connection so the installation is a little faster. That was the reason that it worked. If I do the installation with removed network and ext4 it works as well. I tried it too, just to make sure that it’s not the file system.
But now I’m pretty happy. I finally got a system below 20000ns at the latency test. And the SSD increases the start up speed incredibly.
Regards,
Schuhmann
Regards,
Schuhmann
18 May 2012 08:31 #20195
by ArcEye
Replied by ArcEye on topic Re:no linuxcnc start scripts after new installation
Hi
Glad you got usable latency, yes SSD's are great, silent and fast.
I think I preferred the previous installation problem hypothesis.
It was undesirable but at least understandable - sort of.
Can you post your new installer logs and I will attempt to find some factor which will give a proper install without a network connection, but which deletes LinuxCNC when you have one!
Don't hold your breath though, have a feeling this is going into the 'weird ubuntu s**t' file.
It must be some strange interaction with the specific hardware, or it would be coming up all the time.
- FloppyDisk
- Thank you received: 3
27 Jul 2012 14:38 - 27 Jul 2012 14:44 #22522
by FloppyDisk
Replied by FloppyDisk on topic Re:no linuxcnc start scripts after new installation
schuhmann wrote:
I had the SAME ISSUE and resolved it by disconnecting the Ethernet on install! Sure glad I found it here!
My newly minted system:
D525MW (Bought based on recommendations on the forum - thank you, it's a cool board!)
4gb Ram (went w/ recommended kingston from the intel website, didn't want any issues)
Corsair Nova Series 2 30GB SSD (wanted smaller, but couldn't really find it, was nervous on the other recommendations)
ASUS DVD-RW
I also went w/ the 5i25/7i77 combo, but yet to get it configured and working.
To reiterate the issue:
When I ran off the CD everything worked great. Latency was good, was happy.
I installed, first from the desktop, when I rebooted and went to the applications menu, I didn't have a LinuxCNC folder like I had before when booting from the disk, but did have an Other folder, which had the LinuxCNC install manuals, but no LinuxCNC programs. Then re-installed from boot up, same thing.
From there I re-downloaded the install ISO and burned a new disk, thinking that might be the issue (but why??). Did the md5sum checking. Obviously same thing.
So, I tried to install LinuxCNC manually. The programs showed in the applications menu, but when I ran the latency test, nothing happened. Not even an error. So I ran LinuxCNC and I forget at what point, but rec'd an error:[/color]
"select kernel 2.6.32-122-rtai to run
choose kernel at boot menu."
After opening the boot menu, I ahve the following:
GNU GRUB version 1.98-1ubuntu13
Ubuntu, with Linux 2.6.32-41-generic pae
Ubuntu, with Linux 2.6.32-41-generic pae (recovery mode)
Memory test (memtest86+)
Memory test (memtest86+, serial console 115200)
Oh, then I monkeyed around w/ trying to install on ext2 about 3 or 4 times, didn't know where to mount the drive and was highly confused and I could not get it to work. I think one time the system was really slow....
Then I actually finished reading this thread, installed w/ out the ethernet attached - and viola! It ran like biscuits all night w/ latency around 10us (not stressed) and this morning I stressed it more to about 16/17us.
Next step is on to the 5i25/7i77. I'll remember to get power to the 7i77 to see the I/O, among other things like isocpus for the D525DW.
Thanks a Ton!
Mark
[color=]Noob here.so, cancel my last. It had nothing to do with file system. At the last try I removed the network connection so the installation is a little faster. That was the reason that it worked. If I do the installation with removed network and ext4 it works as well. I tried it too, just to make sure that it’s not the file system.
ASUS DVD-RW
Thanks a Ton!
Mark
Last edit: 27 Jul 2012 14:44 by FloppyDisk.
27 Jul 2012 15:13 - 27 Jul 2012 15:14 #22530
by ArcEye
Hi
There was an update on this, thought it was on this thread and now I can't find it.
JT had the same problem on a new install and one of the developers came up with the answer, which was just a weird, the tipping point was memory over 3 GB.
In theory a 32 bit system should be able to use 4.xxGB but in practice it sees only 3.25GB
If you took one of your memory sticks out, you should find that the install would go through as it should, whether you had a network connection or not.
Last edit: 27 Jul 2012 15:14 by ArcEye.
Time to create page: 0.129 seconds
