12.04 Pure Simulator no longer starts
29 May 2012 16:34 #20485
by Bryan_W
12.04 Pure Simulator no longer starts was created by Bryan_W
Short version -
Followed the wiki for a pure simulator install yesterday and (much to my surprise) was able to at least get to the axis gui after the "linuxcnc 2.6~pre" image popped up and a "manual tool changer" message popped up. However, each attempt at running any gcode left me with a "Program exceeds machine maximum on Z axis" message.
Today, ater googling, I started "playing" with homing and touching off per some suggestions in the forum.
Unfortunately, my computer crashed (gui disappeared and gave me a screen full of text that ended in - "Panic occurred- switching back to text console" ) while the simulator was running and I ended up having to power down to get out of it.
After restarting the computer the simulator will show startup image and "tool changer" message, but then shuts down.
So, (me) being a wiz at git and compiling after one day, I tried each of the following but the program still shuts down:
ran dpkg-checkbuilddeps (which came back clean)
ran "make clean" in git/linuxcnc/src.terminal
ran make
My question is, can I get the simulator back without a fresh install of 12.04?
Thanks in advance,
Bryan
ran make
Thanks in advance,
Bryan
29 May 2012 19:46 #20494
by Bryan_W
Replied by Bryan_W on topic Re:12.04 Pure Simulator no longer starts
Just thought I'd report that I have the simulator running again - I re-cloned the git and recompiled.
Now I'm just back to working on the "Program exceeds machine maximum on z axis" message problem.
29 May 2012 20:57 #20495
by BigJohnT
Replied by BigJohnT on topic Re:12.04 Pure Simulator no longer starts
That's not a problem... it's telling you your trying to move outside your configured boundaries.
31 May 2012 19:39 #20535
by bdugan
Replied by bdugan on topic Re:12.04 Pure Simulator no longer starts
I'm having this same issue (at least it sounds the same).
I'm running 12.04 Ubuntu on a 32 bit machine. A few days ago I succumbed to the repeated notifications from the system that "Updates were available" and click "Oh, OK, go ahead and update the darn thing!"
Before I did that I had a working sim version of EMC 2.5. After updating Ubuntu, it no longer works. The toolchanger screen pops up, and the terminal reports a few "waiting for s.axes" before quitting.
Rather than try to get to the bottom of that, I thought I'd go ahead and load new source, build it, and go from there. I followed the directions here and things seemed to go correctly. But I only get the splash screen (2.6.0~pre), the toolchanger screen, and then a crash.
Here's the terminal output:
And here's what's in linuxcnc_debug.txt:
and, finally, what's in linuxcnc_print.txt:
This is my first post here, so please tell me if I'm posting inappropriately in some way! I've been using EMC (now linuxcnc) for 7 years and it has been a huge help. Normally I can get to the bottom of problems with searchng on these forums or on the wiki. I think my problem this time is trying to use the simulator on a new-ish version of Ubuntu.
Thanks in advance for any pointers!
Ben
bdugan@ben-gateway:scripts$ ./linuxcnc
LINUXCNC - 2.6.0~pre
Machine configuration directory is '/home/bdugan/git/linuxcnc/configs/sim/axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
io started
halcmd loadusr io started
task pid=13919
emcTaskInit: using builtin interpreter
X Error of failed request: BadRequest (invalid request code or no such operation)
Major opcode of failed request: 138 (ATIFGLEXTENSION)
Minor opcode of failed request: 66 ()
Serial number of failed request: 764
Current serial number in output stream: 764
Cleanup done
LinuxCNC terminated with an error. You can find more information in the log:
/home/bdugan/linuxcnc_debug.txt
and
/home/bdugan/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
bdugan@ben-gateway:scripts$ cat ~/linuxcnc_debug.txt
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
13874
PID TTY STAT TIME COMMAND
13919
Stopping realtime threads
Unloading hal components
bdugan@ben-gateway:scripts$ cat ~/linuxcnc_print.txt
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/bdugan/git/linuxcnc/bin
LINUXCNC_TCL_DIR=/home/bdugan/git/linuxcnc/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/bdugan/git/linuxcnc/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/bdugan/git/linuxcnc/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/bdugan/git/linuxcnc/configs/sim/axis/axis.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=13874
Killing task milltask, PID=13919
Ben
01 Jun 2012 12:11 #20556
Replied by andypugh on topic Re:12.04 Pure Simulator no longer starts
bdugan wrote:
This appears to be an OpenGL problem. If it is, then you should find that one of the alternative GUIs works.
Try sim-tklinuxcnc if that works then it is definitely a graphics problem.
01 Jun 2012 15:47 #20570
by bdugan
Thanks, Andy Pugh: Its working now.
I wasn't able to run the tklinuxcnc simulator, either. But your tip about it being related to openGL sent me in the right direction. Synaptic showed me updates related to my AMD graphics hardware and, when I installed those, the axis-sim is again working.
I really appreciate your help.
Ben
Ben
Time to create page: 0.297 seconds
