Error message on fresh install
29 Aug 2012 21:33 #23755
by mpicco
Error message on fresh install was created by mpicco
I'm attempting to install LinuxCNC2 on a piece of hardware it was previously working on (had to give the box a new hard drive), but now LinuxCNC won't run. Instead I get a "LinuxcCNC Errors" window containing the following:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/rcstech/linuxcnc/configs/max'
Machine configuration file is 'max.ini'
INIFILE=/home/rcstech/linuxcnc/configs/max/max.ini
PARAMETER_FILE=max.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
No option 'tto_g11' in section: 'DEFAULT'
No option 'show_program' in section: 'DEFAULT'
No option 'show_rapids' in section: 'DEFAULT'
No option 'program_alpha' in section: 'DEFAULT'
No option 'show_live_plot' in section: 'DEFAULT'
No option 'show_tool' in section: 'DEFAULT'
No option 'show_extents' in section: 'DEFAULT'
No option 'show_offsets' in section: 'DEFAULT'
No option 'show_machine_limits' in section: 'DEFAULT'
No option 'show_machine_speed' in section: 'DEFAULT'
No option 'show_distance_to_go' in section: 'DEFAULT'
No option 'dro_large_font' in section: 'DEFAULT'
No option 'block_delete' in section: 'DEFAULT'
No option 'optional_stop' in section: 'DEFAULT'
No option 'recentfiles' in section: 'DEFAULT'
Killing task linuxcncsvr, PID=1693
Killing task milltask, PID=1740
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
jogwheel.hal:11: signal 'jogscale' not found
1693
PID TTY STAT TIME COMMAND
1740
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 126.619156] I-pipe: Domain RTAI registered.
[ 126.619172] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 126.619177] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 126.619244] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 126.619250] PIPELINE layers:
[ 126.619256] e0e15e20 9ac15d93 RTAI 200
[ 126.619261] c085cb20 0 Linux 100
[ 126.650540] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 126.651199] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 126.651208] RTAI[sched]: hard timer type/freq = APIC/12468670(Hz); default timing: periodic; linear timed lists.
[ 126.651214] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992750000 hz.
[ 126.651218] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 126.651331] RTAI[usi]: enabled.
[ 126.735552] RTAI[math]: loaded.
[ 126.886056] config string '0x0378'
[ 129.978003] RTAI[math]: unloaded.
[ 130.041133] SCHED releases registered named ALIEN RTGLBH
[ 130.072393] RTAI[malloc]: unloaded.
[ 130.172049] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 130.176719] I-pipe: Domain RTAI unregistered.
[ 130.176800] RTAI[hal]: unmounted.
Can anyone tell me what happened and how to remedy it?
Thanks,
Michael
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=
DISPLAY=axis
Cleanup done
1693
1740
Thanks,
Michael
30 Aug 2012 06:33 - 30 Aug 2012 06:37 #23762
by ArcEye
Replied by ArcEye on topic Re:Error message on fresh install
Hi
All the errors that start No option are just because it was the first time ever run with no existing config files, they will disappear next run.
Look into jogwheel.hal:11: signal 'jogscale' not found
11 is the line number it threw an error on, says there is no signal called jogscale.
If you can't see the problem, comment out jogwheel.hal from the [HAL] section of your INI file and try running without it
If it still errors, run linuxcnc from a terminal, I find that more informative, because you just get the error info without the rest of the load / unload verbiage.
Post the errors from there plus your zipped config folder
Last edit: 30 Aug 2012 06:37 by ArcEye.
Time to create page: 0.159 seconds
