Realtime system did not load...
08 Sep 2012 12:40 #24066
by BigJohnT
Replied by BigJohnT on topic Re:Realtime system did not load...
The only thing that happened to EMC was a name change and you can read about it in the manual.
linuxcnc.org/docs/html/common/emc-history.html
10 Sep 2012 13:59 #24125
by JBottoms
Replied by JBottoms on topic Re:Realtime system did not load...
YES...!! (Sorry for the delay, I had a few other projects working.)
8.04 is now running. That saves me a lot of heartburn because I have several systems that I'm starting up and I didn't want to buy more PC's.
Now I'm on to the next problem. My steppers are 1.4V and the controller board (HY-TB3DV-M) specifies 12V minimum for the motors. I'll post elsewhere for this one.
Thanks ArcEye and BigJohnT..!!
-JBottoms
Concord, MA
-JBottoms
Concord, MA
10 Sep 2012 14:18 #24126
Replied by PCW on topic Re:Realtime system did not load...
Step motors are current operated devices with high inductance which means they need higher voltage supplied to change the current than when stopped. That is, the 1.4V rating is a DC rating (voltage for full current when the step motor is stopped).
To move the stepmotor, you need to apply AC voltages to the coils with a frequency that varies with the step rate. Because of the step motor coil inductance the higher the steprate, the higher the voltage you need to get the same current. Step drives accommodate this characteristic by effectively varying the motor voltage depending on the speed (simple drives do this via sensing the motor current and "chopping" the applied voltage)
So to actually run the stepmotor you need much more voltage than the 1.4v
typically step drives have a 20-50x motor voltage power supply
12 Sep 2012 14:36 #24194
by JBottoms
PCW,
Thanks, I think I understand the basics. What I would like to do is control the motors with a a TB6560 controller at 5 Volts rather than the recommended 12-36 Volts.
It seems that if the current is right (1.3A) and the voltage is right (1.4V) on the motor then the controller shouldn't care. This assumes that the voltages are above the silicon threshold. I think it's something like 1.3 Volts. Any reason why this wouldn't work?
Tnx
Tnx
12 Sep 2012 15:06 #24198
Replied by andypugh on topic Re:Realtime system did not load...
JBottoms wrote:
If you think that is what you want to do, then I don't think you do understand the basics.
There is no disadvantage in running the steppers on the highest voltage that you have a supply for, and that the stepper amp can handle.
1.4V motors at 5V will be very slow indeed.
www.servo-drive.com/pictures/custom_step..._speeds___higher.jpg
Shows a fairly typical set of curves, and note that it only goes as low as 24V. I doubt that your motors would manage more than 150rpm at 5V, even unloaded.
It is the job of the drive (such as the TB6560) to control the voltage/current through the motor, not the PSU.
12 Sep 2012 16:33 #24200
by JBottoms
Agreed,
I don't understand the basics. It just seems intuitive that if the motor is rated at 1.4V and I supply it 1.4 volts it should operate as specified.
From Wikipedia: "However, it is winding current, not voltage that applies torque to the stepper motor shaft. "
What am I missing? Is the problem that the controller is not a perfect current source?
And I also found this at the same page: "The rated voltage will produce the rated winding current at DC: but this is mostly a meaningless rating, as all modern drivers are current limiting and the drive voltages greatly exceed the motor rated voltage."
It sounds like the stepper voltage can be ignored as long as the current requirement is satisfied. If that is the case could it be satisfied using 5V?
12 Sep 2012 16:56 - 12 Sep 2012 18:00 #24202
The problem is that the current requirement _cannot_ be satisfied with 5V once the step motor is moving at a decent speed so the torque will drop off very quickly. At Andy's 150 RPM example the two motor phases now have 125 Hz AC waveforms (sine waves in a perfect drive) instead of DC
At DC the current is determined entirely by the wire resistance (about 1 Ohm in your case) and 1.4V is enough but with the motor in motion and with AC signals two other things come into play. One is that the inductive reactance of the motor at the AC drive frequency makes the total motor impedance higher than the ~1 Ohm DC resistance so for example with a 10 mH motor winding inductance at 125 Hz you now have a ~8 Ohm impedance so you need ~10V now to get your 1.3A through the winding.
But wait, it gets worse... In addition to the motor inductance, the step motor acts as a generator when it is moving. The voltage it generates opposes the applied voltage so you need to supply enough AC voltage to counteract the inductance but also oppose the motors generated voltage (Back EMF)
This is why some high performance step drives for 2-4V motors are line operated (165VDC)!
Last edit: 12 Sep 2012 18:00 by PCW.
13 Sep 2012 02:16 #24222
by JBottoms
Thanks PCW,
Excellent reply..!! I interpret this to mean the constant current source is not (welcome to the real world).
So, now, given that my motor is allegedly 1.4V, 1.3A, what is the recommended supply current. The TB6560 is rated at 12 - 36 Volts I believe. And how is the current limiting resistor selected?
Speed is not real important and I was looking at a lower voltage to reduce the losses in the current limiting resistor.
I'll be using "Morgan's recommended configuration" or something similar.
13 Sep 2012 10:55 #24232
by BigJohnT
There is info on calculating the voltage for a stepper drive on the wiki page.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Stepper_Formulas
Time to create page: 0.167 seconds
