LinuxCNC Pure Simulator in 10.04
26 Sep 2012 06:30 #24629
by gandalf69
LinuxCNC Pure Simulator in 10.04 was created by gandalf69
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_Pure_Simulator says it's very easy so it must be:)
But I'm clueless so maybe not for me.
wget www.linuxcnc.org/lucid/dists/lucid/linux...c-sim_2.5.1_i386.deb
Results in:
--2012-09-26 15:51:49-- www.linuxcnc.org/lucid/dists/lucid/linux...c-sim_2.5.1_i386.deb
Resolving www.linuxcnc.org... 69.163.251.58
Connecting to www.linuxcnc.org|69.163.251.58|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3787554 (3.6M) [application/x-debian-package]
Saving to: `linuxcnc-sim_2.5.1_i386.deb.1'
100%[======================================>] 3,787,554 158K/s in 24s
2012-09-26 15:52:14 (156 KB/s) - `linuxcnc-sim_2.5.1_i386.deb.1' saved [3787554/3787554]
But:
sudo dpkg -i linuxcnc-sim*.deb
Results in:
dpkg: regarding linuxcnc-sim_2.5.1_i386.deb containing linuxcnc-sim:
linuxcnc-sim conflicts with emc2
linuxcnc provides emc2 and is present and installed.
dpkg: error processing linuxcnc-sim_2.5.1_i386.deb (--install):
conflicting packages - not installing linuxcnc-sim
Errors were encountered while processing:
And just in case the * is meant to be changed:
sudo dpkg -i linuxcnc-sim_2.5.1_i386.deb
Results in:
Now I'm stuck.
Results in:
But:
Results in:
Results in:
Now I'm stuck.
26 Sep 2012 09:27 #24630
by ArcEye
Replied by ArcEye on topic Re:LinuxCNC Pure Simulator in 10.04
Hi
I think you are getting caught between two stools and the emc2 re-branding.
If you actually want to run a pure simulator on 10.04 ( no reason to do so, the sim configs all work under the rt version ) you need to remove the rt version emc2
sudo dpkg -r emc2
then install as you previously tried.
The alternative might be to download the source and build the sim as a RIP (run in place) and it will not clash with existing system.
I use the 10.04 rt system on a computer with no parport in the house as a development machine, running all sorts of homebrew sim configs as well as the provided ones.
No real need for a sim package, if the rt one will run.
It is mostly people with such new hardware that only > 12.xx will run on it, that go for the sim only ( and maybe laptops)
sudo dpkg -r emc2
26 Sep 2012 10:14 #24631
by gandalf69
Replied by gandalf69 on topic Re:LinuxCNC Pure Simulator in 10.04
ArcEye,
thanks, so are you saying that the sim is superfluous for software simulation?
I installed LinuxCNC per the live cd.
All I want to do is test and mess around with the software without having to have servos and encoders attached.
Obviously I don't expect input from non-existant hardware.
26 Sep 2012 10:26 #24632
by BigJohnT
Replied by BigJohnT on topic Re:LinuxCNC Pure Simulator in 10.04
If you have installed from the LiveCD simply go to Applications > CNC > LinuxCNC and navigate down to sim > axis > and pick one. They will all work without any hardware.
26 Sep 2012 11:01 #24634
by gandalf69
BJT,
thanks, isn't that just running through a G code routine?
I was more interested in having something that would simulate the machine using dummy I/Os.
I may be missing something here.
26 Sep 2012 11:25 #24637
by BigJohnT
The sim examples are fully working configurations with simulated home switches and in the case of the lathe a simulated spindle feed back. So you could add other things to the sim like I/O controlled by some PyVCP buttons.
26 Sep 2012 11:42 #24639
by gandalf69
BJT,
thanks, better I do some serious study before trying to add stuff that may be redundant.
26 Sep 2012 11:44 #24640
by ArcEye
In the past I have got around this by writing a component that simulated the hardware.
For instance, I was developing a toolchange component that worked an ATC on a lathe.
It obviously relied upon feedback from the ATC which it was not going to get, so I wrote another component that simulated the ATC and connected this to it.
This sent back a series of positional signals and 'tripped switches' as the real one would do and enabled me to test through a complete tool change cycle.
You can do whatever you want in a sim, except that you don't have the usual input.I was more interested in having something that would simulate the machine using dummy I/Os.
26 Sep 2012 12:15 #24643
by gandalf69
ArcEye,
thanks, that is what I would expect I would need to do. If I can do this with LinuxCNC as installed then all I need to do is learn how to use it.
26 Sep 2012 13:21 #24646
by BigJohnT
Time to create page: 0.129 seconds
