python build issues when compiling on Fedora 14
10 Oct 2012 19:03 #25219
by wshackle
python build issues when compiling on Fedora 14 was created by wshackle
On a 32-bit Fedora 14 system I get errors whether I enable python support or not.
There are two versions of python available neither works and disabling python support also doesn't work.
./configure --enable-run-in-place --enable-simulator
produces
checking version of python libraries... python2.7
checking match between tk and Tkinter versions... Traceback (most recent call last):
File "<string>", line 1, in <module>
ImportError: No module named _tkinter
TCL mismatch: 8.5 vs
configure: error: Python requires use of Tcl and Tk .
import _tkinter seems to only work in python3 so I tried:
./configure --enable-run-in-place --enable-simulator --with-python python3
checking for Python support... yes
checking python version... /usr/bin/yes: invalid option -- 'c'
Try `/usr/bin/yes --help' for more information.
configure: error: Python version too old (2.4 or newer required)
Finally I tried
./configure --enable-run-in-place --enable-simulator --disable-python
the configure ran fine, but make failed with
Depending emc/rs274ngc/interp_find.cc
/usr/local/include/boost/python/detail/wrap_python.hpp:78:2: error: #error Python 2.2 or higher is required for this version of Boost.Python.
Depending emc/rs274ngc/interp_execute.cc
Depending emc/rs274ngc/interp_cycles.cc
Depending emc/rs274ngc/interp_convert.cc
Depending emc/rs274ngc/interp_check.cc
Depending emc/rs274ngc/interp_array.cc
Depending emc/rs274ngc/interp_arc.cc
Depending emc/rs274ngc/canonmodule.cc
Depending emc/pythonplugin/python_plugin.cc
Depending linuxcnc.1
make: *** No rule to make target `depends/emc/pythonplugin/python_plugin.d', needed by `Makefile'. Stop.
make: Leaving directory `/home/shackle/linuxcnc-dev/src'
produces
Finally I tried
10 Oct 2012 19:36 #25221
by BigJohnT
Replied by BigJohnT on topic Re:python build issues when compiling on Fedora 14
Is there some reason for trying to compile on Fedora instead of using the LiveCD to install LinuxCNC?
If you just like Fedora then continue with your fun...
