ubuntu 10.04 + does not show menu after load
18 Oct 2012 18:11 #25417
by viski
ubuntu 10.04 + does not show menu after load was created by viski
I am having problems when i run ubuntu 10.04 on LIve CD or install. When it completely load i see only mouse pointer on screen and CD-rom icon . There are no menu items
Where could be a problem? An older Ubuntu 6.06 runs without problems.
![:( :(](/media/kunena/emoticons/sad.png)
18 Oct 2012 19:03 #25420
by BigJohnT
Replied by BigJohnT on topic Re:ubuntu 10.04 + does not show menu after load
Your computer might be too old to run the latest LiveCD try the 8.08 LiveCD.
09 Dec 2012 16:41 #27444
by ILD
Hello!
Turn off the following virtual machine settings: "Enable 3D Acceleration" and "Enable 2D Video Acceleration".
Replied by ILD on topic ubuntu 10.04 + does not show menu after load
Hello!
09 Dec 2012 16:56 - 09 Dec 2012 16:58 #27445
Replied by cmorley on topic ubuntu 10.04 + does not show menu after load
hmmm aren't they settings in VirtualBox? I assume He is not using virtual box.
In fact i had this very problem when I updated one of my boxes from 8.04 to 10.04.
There was a command to restore the menu then I allowed it to update and it fixed it.
I'm trying to find the command....
try this :
netgator.blogspot.ca/2010/06/taskbar-mis...-in-ubuntu-1004.html
I had to do it each time I restarted until I updated....hope that helps.
Chris M
try this :
Chris M
Last edit: 09 Dec 2012 16:58 by cmorley.
The following user(s) said Thank You: ILD
Time to create page: 0.076 seconds
