Question for Building Linuxcnc from scratch
06 Nov 2012 16:08 #26302
by tkamsker
Question for Building Linuxcnc from scratch was created by tkamsker
i do have an development machine where i now want to upgrade to Ubuntu 12.10 i do android and some kernel development there so my question is in your exoerience
would i be able to build an Linuxcnc 2.5 or 2.6 there ?
i do have an Atm board with Parallel and stuff which runs the Live cd fine but installed sucks ,..
it is something with the IDE driver so my sinister plan is to build an perfect kernel for that stuff ,..
2nd i am thinking of and USB Hardware where i also want to use the Demo but thats another story
So my question is does it make sense or should i stay with 10.10 ?
any hint apprechiated.
thx
thomas
thx
thomas
06 Nov 2012 17:34 #26303
by ArcEye
Replied by ArcEye on topic Question for Building Linuxcnc from scratch
Hi
At present the kernel for stock installations is fixed at 2.6.32-122-rtai, ie the kernel that ships with the Ubuntu 10.04 based Live CD
What kernel can be compiled with rtai patches is limited by the magma / rtai development. Last time I looked there were patches for 2.6.38 that worked.
There is certainly not one for the 3.x.x kernels
The push amongst the developers at present is to switch to a RT_PREEMPT or xenomai kernel and several variations are being trialled.
If you want to try building say the 2.6.38 kernel to see if the drivers deal with your hardware better, these instructions will get you started.
code.google.com/p/neo-technical/wiki/emc2ubuntu
They are out of date regards some actual packages, but the principle is the same.
Off the top of my head you need to substitute tcl and tk 8.5 for 8.4 and make sure you remove 8.4.
Also there is a substitute of python-old-doc-tools for python2.5-dev, but I think that is prompted by apt anyway.
Building Linuxcnc of any version is not a problem, you just need a rtai kernel first.
The sim version of Linuxcnc will already run on 12.04, so if you just want to develop and not run a machine, that could be a better option.
06 Nov 2012 19:28 - 06 Nov 2012 19:29 #26306
Whilst not impossible (ariasrobo have done it: youtube with link to their site ) it is non-trivial.
There is a bleeding-edge version of LinuxCNC which works with Xenomai and RT_PREEMPT:
thread.gmane.org/gmane.linux.distributions.emc.devel/8147
Replied by andypugh on topic Question for Building Linuxcnc from scratch
The only way to use USB hardware is to relocate the trajectory planner and motion modules onto the USB hardware.2nd i am thinking of and USB Hardware
Last edit: 06 Nov 2012 19:29 by andypugh.
09 Dec 2012 06:11 #27432
by pfred1
That is really understating it!
Perhaps you could elaborate some on just how non-trivial you mean? I'm also not seeing a link to their site for more information.
Replied by pfred1 on topic Question for Building Linuxcnc from scratch
Whilst not impossible it is non-trivial.
09 Dec 2012 07:24 #27435
I mean I wouldn't even know where to start.Perhaps you could elaborate some on just how non-trivial you mean?
09 Dec 2012 15:36 #27442
Replied by cmorley on topic Question for Building Linuxcnc from scratch
They publish the source code - you can look at it your self if you like.
google search their company name and linuxcnc should turn up a link.
09 Dec 2012 20:36 #27451
by ArcEye
It took a bit of finding, because google keeps 'correcting' your spelling to ARIAS
en.araisrobo.com/linuxcnc
There are links and git repository addresses etc
Time to create page: 0.123 seconds
