Problems Running EMC - New Error
01 Dec 2012 09:24 - 01 Dec 2012 09:24 #27110
by paulocgcc
Problems Running EMC - New Error was created by paulocgcc
Hi Everyone,
Suddenly my EMC starts to fail opening. Unfortunately I can't recollect what were last updates.
The error massage is the following. Could anyone help? (I'm new by in linux world)
Pint screen attached also
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.1
Machine configuration directory is '/home/pccabral/linuxcnc/configs/Sherline3Axis'
Machine configuration file is 'Sherline3Axis_mm.ini'
INIFILE=/home/pccabral/linuxcnc/configs/Sherline3Axis/Sherline3Axis_mm.ini
PARAMETER_FILE=stepper.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=1597
Killing task milltask, PID=1644
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
/usr/bin/linuxcnc: linha 687: 1645 Falha de segmentação $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
1597
PID TTY STAT TIME COMMAND
1644
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 32.661882] I-pipe: Domain RTAI registered.
[ 32.661887] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 32.661889] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 32.661909] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 32.661910] PIPELINE layers:
[ 32.661912] facb6e20 9ac15d93 RTAI 200
[ 32.661914] c085cb20 0 Linux 100
[ 32.676437] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 32.676821] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 32.676825] RTAI[sched]: hard timer type/freq = APIC/12556335(Hz); default timing: periodic; linear timed lists.
[ 32.676827] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3013544000 hz.
[ 32.676829] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 32.676898] RTAI[usi]: enabled.
[ 32.709142] RTAI[math]: loaded.
[ 32.889727] config string '0x0378'
[ 34.321703] __ratelimit: 21 callbacks suppressed
[ 34.321707] axis[1645]: segfault at 4 ip 00995ef6 sp bfb41f00 error 4 in libGL.so.1.2[930000+a7000]
[ 34.635408] RTAI[math]: unloaded.
[ 34.651393] SCHED releases registered named ALIEN RTGLBH
[ 34.680271] RTAI[malloc]: unloaded.
[ 34.804528] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 34.837486] I-pipe: Domain RTAI unregistered.
[ 34.837514] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.1
TASK=milltask
HALUI=
DISPLAY=axis
Cleanup done
1597
1644
Last edit: 01 Dec 2012 09:24 by paulocgcc.
01 Dec 2012 15:26 #27113
by ArcEye
Replied by ArcEye on topic Problems Running EMC - New Error
Hi
Without a bit more info hard to know (what updates? )
However this is the root of it, if you have updated libGL you need to roll back to the previous version
This bit tends to confirm because it is an error you get when the actual GUI segfaults on loading, presumably when Axis makes openGL calls
01 Dec 2012 17:43 #27114
by ArcEye
PS
The lib version is the same one I have working on my system
You may have a corrupted file - to eliminate that, unzip the attachment and copy to /usr/lib/mesa/libGL.so.1.2, overwriting the one you have installed
Time to create page: 0.065 seconds
