Latency test - Servo thread or Base thread?
05 Dec 2012 02:26 #27209
by canner
Latency test - Servo thread or Base thread? was created by canner
Hello all,
I am setting up a computer (Dell Optiplex GX620) for Linuxcnc to use on a lathe, I plan on using a cards from mesa and steppers in the set up. My latency numbers, after turning off hyperthreading, are coming back with a max jitter on the base thread of 25,000 and on the servo thread of 55,000. Do I just go with the larger number or the number from the base thread? Any suggestions for getting the latency numbers down?
Thanks,
Russell
Thanks,
Russell
05 Dec 2012 02:54 #27210
Replied by PCW on topic Latency test - Servo thread or Base thread?
When a hardware stepgenerator is used (as with Mesa or Pico Systems cards)
the base thread is not used at all so its jitter is not important.
55 uSec of jitter should be OK for a 1 mS servo thread
If you have a dual core processor you might try the isolcpus option to reduce latency:
wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is..._Parameter_And_GRUB2
05 Dec 2012 03:41 #27212
by canner
Replied by canner on topic Latency test - Servo thread or Base thread?
Thanks for the response on this, it is a single core intel p4 so Isolcpus will not help. I also tried Ubuntu 8 but had even worse latency with that. I will push forward with what I have now and start ordering parts then.
