problem with my LinuxCNC
11 Dec 2012 15:55 #27560
by elhaouri
problem with my LinuxCNC was created by elhaouri
Hello I have a problem with my LinuxCNC
I run the "LinuxCNC Stepper" I complete my setup and I test each axis separately, it works very well,
Once I finish the configuration and I run the shortcut created on the desktop, I can no longer control my axes.
Another note: when I launch the shortened engine is released, as if I hit the power
Someone has already experienced this problem?
thank you for helping me
11 Dec 2012 16:03 #27561
by Rick G
Replied by Rick G on topic problem with my LinuxCNC
Does your system require a "charge pump" signal? Is it inverted?
Rick G
Rick G
11 Dec 2012 16:29 #27562
by elhaouri
Replied by elhaouri on topic problem with my LinuxCNC
I'm testing phase, my system is composed of a interface card (HY-JK02-M 5)and driver of three stepper motor WAINTAIMOTOR
11 Dec 2012 18:02 #27567
by ArcEye
Replied by ArcEye on topic problem with my LinuxCNC
Hi
I suspect Rick is in the correct area, stepconf can produce configs that do not work with a charge pump
(although normally the 'test axis' bit of stepconf does not work either)
See this post
www.linuxcnc.org/index.php/english/forum...m-running-axis#13886
Either that or you have a specific enable pin on your drives which is not hooked up
If unable to figure it out, post your .hal and .ini files
See this post
Time to create page: 0.075 seconds
