Problems after installing 2.1.5 (from 2.4.3)
27 Dec 2012 02:54 #28057
by pferrick
Problems after installing 2.1.5 (from 2.4.3) was created by pferrick
Hello all,
Wanting to jump into Glade/Pyvcp etc. and not finding everything in the 2.4 release I was running, I decided to upgrade to 2.5.1 using these instructions. All went fine.
However, startup give me the following:
Starting LinuxCNC...
custom_postgui.hal:22: Pin 'input.0.btn-trigger' does not exist
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/pferrick/linuxcnc/configs/1029/1029.ini
PARAMETER_FILE=emc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=3145
Killing task milltask, PID=3194
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
3145
PID TTY STAT TIME COMMAND
3194
Stopping realtime threads
Unloading hal components
So something is definately amiss...! Seems like a problem with the .ini file, as there were a couple of complaints near the end about the lack of a reference to a splash screen image / dwell time, which went away when I replaced these in the .ini file. Not sure what the EMC, LINUXCNC sections are all about though.
I'd appreciate any suggestions. Thanks,
Pat
ps - linuxcnc runs fine in simulation, by the way....
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
TASK=milltask
HALUI=halui
DISPLAY=axis
3145
3194
Pat
27 Dec 2012 21:24 - 28 Dec 2012 00:07 #28091
by ArcEye
Replied by ArcEye on topic Problems after installing 2.1.5 (from 2.4.3)
Hi
This is the problem. Either this named pin does not exist, or it is being called before it is created.
I suspect that this is a gamepad and that this button should now be called input.0.btn-joystick, as per this thread
www.linuxcnc.org/index.php/english/forum...roblem?start=6#27611
Last edit: 28 Dec 2012 00:07 by ArcEye.
Time to create page: 0.109 seconds
