isolcpu line: where to locate it ?
11 Jan 2013 18:54 - 11 Jan 2013 18:54 #28582 by bigalex
Hello people
I'm running LinuxCNC 2.5.1 on Ubuntu 8.04 with a dual core cpu.
I would like to know where I should insert the line isolcpu=1 into the grub boot file .
Regards
bigalex :blink:
Last edit: 11 Jan 2013 18:54 by bigalex.
11 Jan 2013 19:53 - 11 Jan 2013 19:54 #28584 by BigJohnT
After much googling I finally found some information on grub and note that on 8.04 your using grub not grub2.
Last edit: 11 Jan 2013 19:54 by BigJohnT.
11 Jan 2013 21:35 #28588 by bigalex
Thank you BigJohnT.
I follow also the instruction in the LinuxCNC wiki HERE .
For computers using classic GRUB as the boot manager, this is accomplished by editing the file /boot/grub/menu.lst to include the boot parameter "isolcpus=1" (for example) at the end of appropriate kernel lines.
My question is where is this ?
.....at the end of appropriate kernel lines.
bigalex :blink:
11 Jan 2013 21:42 #28589 by BigJohnT
I see it now...
That's a big help! I'm assuming that it goes after everything else... can you attach the file? I don't have 8.04 running anywhere.
11 Jan 2013 21:54 - 11 Jan 2013 21:59 #28591 by bigalex
Sure ..... see attached file.
I can't attach any file.
I send to you the file content :
# menu.lst - See: grub(8), info grub, update-grub(8)
#            grub-install(8), grub-floppy(8),
#            grub-md5-crypt, /usr/share/doc/grub
#            and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default		0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout		10
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
#hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
#      password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title		Windows 95/98/NT/2000
# root		(hd0,0)
# makeactive
# chainloader	+1
# title		Linux
# root		(hd0,1)
# kernel	/vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
##      kopt_2_6_8=root=/dev/hdc1 ro
##      kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=4473c932-391f-4ae4-a782-857cff4c2d80 ro
## Setup crashdump menu entries
## e.g. crashdump=1
# crashdump=0
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,4)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##      alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##      lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
##      lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##      altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##      howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##      memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title		Ubuntu 8.04.2, kernel 2.6.24-16-rtai
root		(hd0,4)
kernel		/boot/vmlinuz-2.6.24-16-rtai root=UUID=4473c932-391f-4ae4-a782-857cff4c2d80 ro quiet splash
initrd		/boot/initrd.img-2.6.24-16-rtai
quiet
title		Ubuntu 8.04.2, kernel 2.6.24-16-rtai (recovery mode)
root		(hd0,4)
kernel		/boot/vmlinuz-2.6.24-16-rtai root=UUID=4473c932-391f-4ae4-a782-857cff4c2d80 ro single
title		Ubuntu 8.04.2, memtest86+
root		(hd0,4)
kernel		/boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title		Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sda1
title		Windows NT/2000/XP
root		(hd0,0)
savedefault
makeactive
chainloader	+1
bigalex :blink:
Last edit: 11 Jan 2013 21:59 by bigalex.
11 Jan 2013 21:57 #28592 by BigJohnT
You will have to use one of the approved file extensions like .txt or it won't attach. So just change the name to menu.lst.txt and attach.
11 Jan 2013 23:56 - 11 Jan 2013 23:56 #28594 by ArcEye
Hi
It is a kernel parameter, so you add it to the kernel boot line.
The example below isolates CPU1 and puts all the load on CPU0
title           EMC2 - rtai kernel isolcpu noirq Ubuntu 10.04 (on /dev/sdb7)
uuid            42d5e8ad-507d-41ea-8ad6-868e87be2ed6
kernel          /boot/vmlinuz-2.6.32-122-rtai root=UUID=42d5e8ad-507d-41ea-8ad6-868e87be2ed6 ro isolcpus=1
initrd          /boot/initrd.img-2.6.32-122-rtai
quiet
Last edit: 11 Jan 2013 23:56 by ArcEye.
The following user(s) said Thank You: BigJohnT
11 Jan 2013 23:59 #28595 by bigalex
Thanks a lot .
I will try in few minutes.
12 Jan 2013 00:27 #28597 by BigJohnT
I'm glad someone came along that knows what they are talking about :) Do you add it to both kernel lines?
12 Jan 2013 00:46 - 13 Jan 2013 20:57 #28598 by ArcEye
Just the one which starts 'kernel'.
(EDIT: OK I see what you mean now - there is no point putting on the kernel line for the recovery option, you won't be running Linuxcnc from that )
The kernel parameters at the end usually just consist of something like ro quiet splash
If you change that to ro single you will get a single user system with a root shell, very useful for getting out of trouble.
There can be lots of kernel parameters eg
ro isolcpus=1,2,3 acpi_irq_nobalance noirqbalance which was from playing about with preventing interrupts from being spread across the CPUs when just using CPU0
This is a mind blowing list
www.kernel.org/doc/Documentation/kernel-parameters.txt
Last edit: 13 Jan 2013 20:57 by ArcEye.
Time to create page: 0.203 seconds
