isolcpu line: where to locate it ?
13 Jan 2013 19:01 #28647
by bigalex
Replied by bigalex on topic isolcpu line: where to locate it ?
As ArcEye suggested I fit the isolcpu=1 line at the end of the main kernel line (not the recovery one).
I'm not so familiar with Linux so I think for the best that should be nice to implement this information into the wiki page that I mentioned before.
I want to notice to you that the isolcpu=1 line don't apparently have a sensible influence on my system.
Thank you .
bigalex
Thank you .
bigalex
13 Jan 2013 20:43 #28649
by ArcEye
Replied by ArcEye on topic isolcpu line: where to locate it ?
Hi
The syntax is isolcpus=1 (ie plural), if you have entered what you show, I am not sure if you will get an error or if it will just be ignored
To see if it is running properly run mpstat -P ALL (you will probably have to install mpstat first)
Gives you a printout like below, which should prove that core 1 has been isolated
I will have a look at the wiki page next week to see what can be added to make it more specific, probably just an example would do.
Linux 2.6.32-122-rtai (INTEL-QUAD) 13/01/2013 _i686_ (2 CPU)
12:36:35 CPU %usr %nice %sys %iowait %irq %soft %steal %guest %idle
12:36:35 all 0.16 0.00 14.27 1.30 0.05 0.02 0.00 0.00 84.20
12:36:35 0 0.65 0.00 58.86 5.38 0.19 0.10 0.00 0.00 34.83
12:36:35 1 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 99.99
13 Jan 2013 21:21 - 13 Jan 2013 21:22 #28651
by bigalex
Hi ArcEye
I will be at office tomorrow and I will check it out .
Maybe I am wrong because of isolcpu instead of isolcpus .
No errors during the boot phase so I supposed I did right .
For the wiki page I'm agreed with you about to make an example on this.
Thank you
bigalex
Thank you
bigalex
![:blink: :blink:](/media/kunena/emoticons/blink.png)
Last edit: 13 Jan 2013 21:22 by bigalex.
13 Jan 2013 21:42 - 13 Jan 2013 21:43 #28652
by BigJohnT
Replied by BigJohnT on topic isolcpu line: where to locate it ?
Last edit: 13 Jan 2013 21:43 by BigJohnT.
14 Jan 2013 18:07 #28678
by ArcEye
Wiki page updated to include an example
wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is..._Parameter_And_GRUB2
14 Jan 2013 18:29 - 14 Jan 2013 18:42 #28679
by bigalex
Hi ArcEye.
Thank you so much for that and for all the informations you gave me.
I tried your tips (mpstat) and the isolcpus=1 considering using only CPU0 .
The latency test is not too bad (about 35000ns for the base thread and about 70000ns for the servo thread).
The mobo has an embedded ATI low end gpu installed.
I'm using this computer for test in the office (stepper configuration) so I don't need extra performance.
I followed also the user info into the wiki for the BIOS setup.
In any case now is better than before.
bigalex
bigalex
Last edit: 14 Jan 2013 18:42 by bigalex.
