Xenomai installation issue
26 Jan 2013 06:32 #29147
by TopherMan
Xenomai installation issue was created by TopherMan
Hi all,
I'm a 3D printer enthusiast who's interested in getting into more general CNC applications. Unfortunately my "messing around" computer died, and so I thought I'd try installing one of the new branches that supports Xenomai on my 64-bit 12.04 installation.
I've got Xenomai up and running, and following the directions at wiki.linuxcnc.org/cgi-bin/wiki.pl?NewRTInstall I am nearly functional. Unfortunately, one test fails at the "runtests" stage, and latency-test fails altogether. The test "halmodule.0" fails (the "result" file is empty), and latency-test gives the following error:
I'm not quite well-versed enough in this to know where to go next. Anyone have some tips?
Warning: Spoiler!
File "/home/chris/gitspace/linuxcnc-rtos/bin/pyvcp", line 41, in <module>
import vcpparse
File "/home/chris/gitspace/linuxcnc-rtos/lib/python/vcpparse.py", line 26, in <module>
import pyvcp_widgets
File "/home/chris/gitspace/linuxcnc-rtos/lib/python/pyvcp_widgets.py", line 49, in <module>
from hal import *
File "/home/chris/gitspace/linuxcnc-rtos/lib/python/hal.py", line 30, in <module>
import _hal
ImportError: libnative.so.3: shared object cannot be dlopen()ed
lat.hal:6: pyvcp exited without becoming ready
RTAPI: ERROR: Unexpected realtime delay on task 1 - 'fast' (1 overruns)
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
RTAPI: (further messages will be suppressed)
26 Jan 2013 15:25 #29157
by ArcEye
Replied by ArcEye on topic Xenomai installation issue
Hi
You need to go onto the developers list, all the discussion regards this is there.
lists.sourceforge.net/lists/listinfo/emc-developers
Until this is mainstream, after the next release probably, there can't really be any support here, very few people are playing with it and there is no guarantee which bits of it will make it through to a stable release.
26 Jan 2013 23:39 #29161
by cncbasher
Replied by cncbasher on topic Xenomai installation issue
check your dependancys , it look like your missing some
or version mismatches somewhere
27 Jan 2013 01:30 #29166
by TopherMan
Replied by TopherMan on topic Xenomai installation issue
Think I found the issue. My dependencies all checked out fine, but it looks like the issue is due to the kernel being compiled without the --enable-dlopen-skins option. Instead of compiling the kernel myself I used the repo listed here wiki.linuxcnc.org/cgi-bin/wiki.pl?XenomaiKernel, so I suspect that kernel was compiled without the proper option.
Regardless, I'll take this over to the dev mailing list. Thanks!
Time to create page: 0.214 seconds
