A VERY Newbie question.
13 Apr 2013 00:44 - 13 Apr 2013 18:21 #32654
by fishtruk
A VERY Newbie question. was created by fishtruk
Hi all,
I've installed Ubuntu 10.04 / LinuxCNC 2.5 on a Gateway 733Mhz desktop with 512 of ram. When I try to launch, I get the attached logfile and the program does not start.
I'm really new and would appreciate any help. I would imagine it's something simple but I often imagine things...
Thanks,
Nelson
Okay, I couldn't attach it so it follows...
Thanks,
Nelson
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/johnnyianieri/linuxcnc/configs/Sherline3Axis'
Machine configuration file is 'Sherline3Axis_inch.ini'
INIFILE=/home/johnnyianieri/linuxcnc/configs/Sherline3Axis/Sherline3Axis_inch.ini
PARAMETER_FILE=stepper.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Realtime system did not load
Killing task linuxcncsvr, PID=3073
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
3073
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
/usr/bin/linuxcnc: line 428: 3111 Segmentation fault $HALCMD stop
Unloading hal components
/usr/bin/linuxcnc: line 428: 3112 Segmentation fault $HALCMD unload all
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001ffc0000 (usable)
[ 0.000000] BIOS-e820: 000000001ffc0000 - 000000001fff8000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001fff8000 - 0000000020000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ffb80000 - 00000000ffc00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x1ffc0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 020000000 mask FFFF00000 write-back
[ 0.000000] 2 base 020000000 mask FFFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000001ffc0000 (usable)
[ 0.000000] modified: 000000001ffc0000 - 000000001fff8000 (ACPI data)
[ 0.000000] modified: 000000001fff8000 - 0000000020000000 (ACPI NVS)
[ 0.000000] modified: 00000000ffb80000 - 00000000ffc00000 (reserved)
[ 0.000000] modified: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000001ffc0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001fc00000 page 2M
[ 0.000000] 001fc00000 - 001ffc0000 page 4k
[ 0.000000] kernel direct mapping tables up to 1ffc0000 @ 7000-c000
[ 0.000000] RAMDISK: 1733d000 - 1800fdd5
[ 0.000000] ACPI: RSDP 000ff980 00014 (v00 AMI )
[ 0.000000] ACPI: RSDT 1fff0000 0002C (v01 GATEWA EA81510A 20000622 MSFT 00001011)
[ 0.000000] ACPI: FACP 1fff1000 00074 (v01 GATEWA EA81510A 20000622 MSFT 00001011)
[ 0.000000] ACPI: DSDT 1ffe0000 02F8D (v01 GATEWA 9DT-081 00000012 MSFT 0100000B)
[ 0.000000] ACPI: FACS 1fff8000 00040
[ 0.000000] ACPI: BOOT 1fff4000 0002B (v01 GATEWA EA81510A 20000622 MSFT 00001011)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 511MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1ffc0000
[ 0.000000] low ram: 0 - 1ffc0000
[ 0.000000] node 0 low ram: 00000000 - 1ffc0000
[ 0.000000] node 0 bootmap 00008000 - 0000bff8
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 001ffc0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [001733d000 - 001800fdd5] RAMDISK ==> [001733d000 - 001800fdd5]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b41bb] BRK ==> [00008b1000 - 00008b41bb]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000c000] BOOTMAP ==> [0000008000 - 000000c000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001ffc0
[ 0.000000] HighMem 0x0001ffc0 -> 0x0001ffc0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001ffc0
[ 0.000000] On node 0 totalpages: 130907
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 125920 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:dfb80000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129883
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=66C421D5C421A7EF loop=/ubuntu/disks/root.disk ro quiet splash
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2620160 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 494984k/524032k available (4539k kernel code, 28204k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xe07c0000 - 0xff7fe000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdffc0000 ( 511 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 730.901 MHz processor.
[ 0.004013] Calibrating delay loop (skipped), value calculated using timer frequency.. 1461.80 BogoMIPS (lpj=2923604)
[ 0.004074] Security Framework initialized
[ 0.004155] AppArmor: AppArmor initialized
[ 0.004182] Mount-cache hash table entries: 512
[ 0.004571] Initializing cgroup subsys ns
[ 0.004585] Initializing cgroup subsys cpuacct
[ 0.004601] Initializing cgroup subsys memory
[ 0.004632] Initializing cgroup subsys devices
[ 0.004642] Initializing cgroup subsys freezer
[ 0.004651] Initializing cgroup subsys net_cls
[ 0.004716] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 0.004728] CPU: L2 cache: 256K
[ 0.004744] mce: CPU supports 5 MCE banks
[ 0.004787] Performance Events:
[ 0.004796] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.004805] no hardware sampling interrupt available.
[ 0.004814] p6 PMU driver.
[ 0.004859] ... version: 0
[ 0.004867] ... bit width: 32
[ 0.004875] ... generic registers: 2
[ 0.004884] ... value mask: 00000000ffffffff
[ 0.004893] ... max period: 000000007fffffff
[ 0.004901] ... fixed-purpose events: 0
[ 0.004909] ... event mask: 0000000000000003
[ 0.004926] Checking 'hlt' instruction... OK.
[ 0.021649] SMP alternatives: switching to UP code
[ 0.034317] Freeing SMP alternatives: 31k freed
[ 0.034373] ACPI: Core revision 20090903
[ 0.044804] ACPI: setting ELCR to 0200 (from 0e08)
[ 0.046171] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.046194] ftrace: allocating 21003 entries in 42 pages
[ 0.063802] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.063818] weird, boot CPU (#0) not listed by the BIOS.
[ 0.063826] SMP motherboard not detected.
[ 0.063835] Local APIC not detected. Using dummy APIC emulation.
[ 0.063842] SMP disabled
[ 0.064587] Brought up 1 CPUs
[ 0.064603] Total of 1 processors activated (1461.80 BogoMIPS).
[ 0.065444] CPU0 attaching NULL sched-domain.
[ 0.065906] devtmpfs: initialized
[ 0.067166] regulator: core version 0.5
[ 0.067347] NET: Registered protocol family 16
[ 0.067756] EISA bus registered
[ 0.067782] ACPI: bus type pci registered
[ 0.068611] PCI: PCI BIOS revision 2.10 entry at 0xfda95, last bus=2
[ 0.068622] PCI: Using configuration type 1 for base access
[ 0.071592] bio: create slab <bio-0> at 0
[ 0.073342] ACPI: EC: Look up EC in DSDT
[ 0.089884] ACPI: Interpreter enabled
[ 0.089897] ACPI: (supports S0 S5)
[ 0.089933] ACPI: Using PIC for interrupt routing
[ 0.101698] ACPI: Power Resource [URP1] (off)
[ 0.101802] ACPI: Power Resource [URP2] (off)
[ 0.101902] ACPI: Power Resource [FDDP] (off)
[ 0.102002] ACPI: Power Resource [LPTP] (off)
[ 0.102341] ACPI: No dock devices found.
[ 0.104870] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.105007] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xf8000000-0xfbffffff]
[ 0.105274] pci 0000:00:1f.0: quirk: region 0400-047f claimed by ICH4 ACPI/GPIO/TCO
[ 0.105287] pci 0000:00:1f.0: quirk: region 0500-053f claimed by ICH4 GPIO
[ 0.105355] pci 0000:00:1f.1: reg 20 io port: [0xffa0-0xffaf]
[ 0.105441] pci 0000:00:1f.2: reg 20 io port: [0xef40-0xef5f]
[ 0.105526] pci 0000:00:1f.3: reg 20 io port: [0xefa0-0xefaf]
[ 0.105610] pci 0000:00:1f.4: reg 20 io port: [0xef80-0xef9f]
[ 0.105705] pci 0000:02:00.0: reg 10 32bit mmio: [0xfd000000-0xfdffffff]
[ 0.105722] pci 0000:02:00.0: reg 14 32bit mmio pref: [0xe8000000-0xefffffff]
[ 0.105757] pci 0000:02:00.0: reg 30 32bit mmio pref: [0xfeaf0000-0xfeafffff]
[ 0.105849] pci 0000:00:01.0: bridge 32bit mmio: [0xfca00000-0xfeafffff]
[ 0.105863] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe4700000-0xf47fffff]
[ 0.105938] pci 0000:01:09.0: reg 10 32bit mmio: [0xfc9ec000-0xfc9ecfff]
[ 0.106003] pci 0000:01:09.0: PME# supported from D0 D1 D3hot D3cold
[ 0.106015] pci 0000:01:09.0: PME# disabled
[ 0.106069] pci 0000:01:09.1: reg 10 32bit mmio: [0xfc9ed000-0xfc9edfff]
[ 0.106133] pci 0000:01:09.1: PME# supported from D0 D1 D3hot D3cold
[ 0.106145] pci 0000:01:09.1: PME# disabled
[ 0.106199] pci 0000:01:09.2: reg 10 32bit mmio: [0xfc9ee000-0xfc9eefff]
[ 0.106262] pci 0000:01:09.2: PME# supported from D0 D1 D3hot D3cold
[ 0.106274] pci 0000:01:09.2: PME# disabled
[ 0.106336] pci 0000:01:09.3: reg 10 32bit mmio: [0xfc9ef800-0xfc9ef8ff]
[ 0.106405] pci 0000:01:09.3: PME# supported from D0 D3hot D3cold
[ 0.106417] pci 0000:01:09.3: PME# disabled
[ 0.106479] pci 0000:01:0a.0: reg 10 io port: [0xdf80-0xdf9f]
[ 0.106543] pci 0000:01:0a.0: supports D1 D2
[ 0.106596] pci 0000:01:0a.1: reg 10 io port: [0xdff0-0xdff7]
[ 0.106659] pci 0000:01:0a.1: supports D1 D2
[ 0.106725] pci 0000:01:0c.0: reg 10 io port: [0xd800-0xd8ff]
[ 0.106742] pci 0000:01:0c.0: reg 14 32bit mmio: [0xfc9efc00-0xfc9effff]
[ 0.106782] pci 0000:01:0c.0: reg 30 32bit mmio pref: [0xfc9c0000-0xfc9dffff]
[ 0.106813] pci 0000:01:0c.0: supports D1 D2
[ 0.106822] pci 0000:01:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.106834] pci 0000:01:0c.0: PME# disabled
[ 0.106892] pci 0000:01:0d.0: reg 10 32bit mmio: [0xfc9f0000-0xfc9fffff]
[ 0.106909] pci 0000:01:0d.0: reg 14 io port: [0xdfe0-0xdfe7]
[ 0.106967] pci 0000:01:0d.0: PME# supported from D0 D3hot D3cold
[ 0.106979] pci 0000:01:0d.0: PME# disabled
[ 0.107023] pci 0000:00:1e.0: transparent bridge
[ 0.107035] pci 0000:00:1e.0: bridge io port: [0xd000-0xdfff]
[ 0.107048] pci 0000:00:1e.0: bridge 32bit mmio: [0xfc900000-0xfc9fffff]
[ 0.107062] pci 0000:00:1e.0: bridge 32bit mmio pref: [0xe4600000-0xe46fffff]
[ 0.107086] pci_bus 0000:00: on NUMA node 0
[ 0.107102] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.107412] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.112481] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12)
[ 0.112790] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12)
[ 0.113095] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12) *0, disabled.
[ 0.113417] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 9 10 11 12)
[ 0.113723] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12) *0, disabled.
[ 0.114034] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11 12)
[ 0.114340] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 *11 12)
[ 0.114647] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *9 10 11 12)
[ 0.115013] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.115036] vgaarb: loaded
[ 0.115476] SCSI subsystem initialized
[ 0.115728] libata version 3.00 loaded.
[ 0.116055] usbcore: registered new interface driver usbfs
[ 0.116102] usbcore: registered new interface driver hub
[ 0.116217] usbcore: registered new device driver usb
[ 0.116720] ACPI: WMI: Mapper loaded
[ 0.116729] PCI: Using ACPI for IRQ routing
[ 0.117149] NetLabel: Initializing
[ 0.117158] NetLabel: domain hash size = 128
[ 0.117165] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.117211] NetLabel: unlabeled traffic allowed by default
[ 0.117326] Switching to clocksource tsc
[ 0.122795] AppArmor: AppArmor Filesystem Enabled
[ 0.122859] pnp: PnP ACPI init
[ 0.122917] ACPI: bus type pnp registered
[ 0.132810] pnp: PnP ACPI: found 12 devices
[ 0.132822] ACPI: ACPI bus type pnp unregistered
[ 0.132837] PnPBIOS: Disabled by ACPI PNP
[ 0.132881] system 00:0b: iomem range 0x0-0x9ffff could not be reserved
[ 0.132895] system 00:0b: iomem range 0xe0000-0xfffff could not be reserved
[ 0.132908] system 00:0b: iomem range 0x100000-0x1fffffff could not be reserved
[ 0.168091] pci 0000:01:0c.0: BAR 6: address space collision on of device [0xfc9c0000-0xfc9dffff]
[ 0.168127] pci 0000:00:01.0: PCI bridge, secondary bus 0000:02
[ 0.168136] pci 0000:00:01.0: IO window: disabled
[ 0.168151] pci 0000:00:01.0: MEM window: 0xfca00000-0xfeafffff
[ 0.168164] pci 0000:00:01.0: PREFETCH window: 0xe4700000-0xf47fffff
[ 0.168188] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:01
[ 0.168200] pci 0000:00:1e.0: IO window: 0xd000-0xdfff
[ 0.168214] pci 0000:00:1e.0: MEM window: 0xfc900000-0xfc9fffff
[ 0.168227] pci 0000:00:1e.0: PREFETCH window: 0xe4600000-0xe46fffff
[ 0.168263] pci 0000:00:1e.0: setting latency timer to 64
[ 0.168278] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.168289] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.168300] pci_bus 0000:02: resource 1 mem: [0xfca00000-0xfeafffff]
[ 0.168311] pci_bus 0000:02: resource 2 pref mem [0xe4700000-0xf47fffff]
[ 0.168323] pci_bus 0000:01: resource 0 io: [0xd000-0xdfff]
[ 0.168333] pci_bus 0000:01: resource 1 mem: [0xfc900000-0xfc9fffff]
[ 0.168344] pci_bus 0000:01: resource 2 pref mem [0xe4600000-0xe46fffff]
[ 0.168355] pci_bus 0000:01: resource 3 io: [0x00-0xffff]
[ 0.168365] pci_bus 0000:01: resource 4 mem: [0x000000-0xffffffff]
[ 0.168490] NET: Registered protocol family 2
[ 0.168828] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.169884] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.170232] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.170730] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.170748] TCP reno registered
[ 0.171135] NET: Registered protocol family 1
[ 0.171282] pci 0000:02:00.0: Boot video device
[ 0.171669] Simple Boot Flag at 0x7a set to 0x1
[ 0.171974] Scanning for low memory corruption every 60 seconds
[ 0.172372] audit: initializing netlink socket (disabled)
[ 0.172413] type=2000 audit(1365757157.170:1): initialized
[ 0.197808] Trying to unpack rootfs image as initramfs...
[ 0.227183] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.239044] VFS: Disk quotas dquot_6.5.2
[ 0.239366] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.241861] fuse init (API version 7.13)
[ 0.242223] msgmni has been set to 967
[ 0.248020] alg: No test for stdrng (krng)
[ 0.248232] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.248244] io scheduler noop registered
[ 0.248252] io scheduler anticipatory registered
[ 0.248260] io scheduler deadline registered
[ 0.248444] io scheduler cfq registered (default)
[ 0.248849] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.248934] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.249173] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.249198] ACPI: Sleep Button [SBTN]
[ 0.249412] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.249423] ACPI: Power Button [PWRF]
[ 0.254468] isapnp: Scanning for PnP cards...
[ 0.263563] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.263741] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.264716] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.317455] brd: module loaded
[ 0.324471] loop: module loaded
[ 0.324849] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.325266] ata_piix 0000:00:1f.1: version 2.13
[ 0.325444] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.331733] scsi0 : ata_piix
[ 0.332234] scsi1 : ata_piix
[ 0.337914] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 0.337927] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 0.339329] Fixed MDIO Bus: probed
[ 0.339473] PPP generic driver version 2.4.2
[ 0.339668] tun: Universal TUN/TAP device driver, 1.6
[ 0.339676] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.340006] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.340524] ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 11
[ 0.340535] PCI: setting IRQ 11 as level-triggered
[ 0.340550] ehci_hcd 0000:01:09.3: PCI INT A -> Link[LNKF] -> GSI 11 (level, low) -> IRQ 11
[ 0.340594] ehci_hcd 0000:01:09.3: EHCI Host Controller
[ 0.340753] ehci_hcd 0000:01:09.3: new USB bus registered, assigned bus number 1
[ 0.340833] ehci_hcd 0000:01:09.3: debug port 1
[ 0.362721] ehci_hcd 0000:01:09.3: irq 11, io mem 0xfc9ef800
[ 0.375162] ehci_hcd 0000:01:09.3: USB 2.0 started, EHCI 1.00
[ 0.375614] usb usb1: configuration #1 chosen from 1 choice
[ 0.375722] hub 1-0:1.0: USB hub found
[ 0.375762] hub 1-0:1.0: 6 ports detected
[ 0.375951] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.376525] ACPI: PCI Interrupt Link [LNKG] enabled at IRQ 11
[ 0.376541] ohci_hcd 0000:01:09.0: PCI INT B -> Link[LNKG] -> GSI 11 (level, low) -> IRQ 11
[ 0.376585] ohci_hcd 0000:01:09.0: OHCI Host Controller
[ 0.376778] ohci_hcd 0000:01:09.0: new USB bus registered, assigned bus number 2
[ 0.376832] ohci_hcd 0000:01:09.0: irq 11, io mem 0xfc9ec000
[ 0.433430] usb usb2: configuration #1 chosen from 1 choice
[ 0.433539] hub 2-0:1.0: USB hub found
[ 0.433580] hub 2-0:1.0: 2 ports detected
[ 0.434244] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 9
[ 0.434256] PCI: setting IRQ 9 as level-triggered
[ 0.434269] ohci_hcd 0000:01:09.1: PCI INT C -> Link[LNKH] -> GSI 9 (level, low) -> IRQ 9
[ 0.434313] ohci_hcd 0000:01:09.1: OHCI Host Controller
[ 0.434517] ohci_hcd 0000:01:09.1: new USB bus registered, assigned bus number 3
[ 0.439483] ohci_hcd 0000:01:09.1: irq 9, io mem 0xfc9ed000
[ 0.513536] usb usb3: configuration #1 chosen from 1 choice
[ 0.513647] hub 3-0:1.0: USB hub found
[ 0.513689] hub 3-0:1.0: 2 ports detected
[ 0.514361] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
[ 0.514373] PCI: setting IRQ 10 as level-triggered
[ 0.514388] ohci_hcd 0000:01:09.2: PCI INT D -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 0.514433] ohci_hcd 0000:01:09.2: OHCI Host Controller
[ 0.519550] ohci_hcd 0000:01:09.2: new USB bus registered, assigned bus number 4
[ 0.519628] ohci_hcd 0000:01:09.2: irq 10, io mem 0xfc9ee000
[ 0.523242] ata1.00: ATA-6: WDC WD800JB-00JJC0, 05.01C05, max UDMA/100
[ 0.523257] ata1.00: 156301488 sectors, multi 16: LBA
[ 0.523340] ata1.00: limited to UDMA/33 due to 40-wire cable
[ 0.531529] ata1.00: configured for UDMA/33
[ 0.605035] usb usb4: configuration #1 chosen from 1 choice
[ 0.605153] hub 4-0:1.0: USB hub found
[ 0.605196] hub 4-0:1.0: 2 ports detected
[ 0.605368] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.606056] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 3
[ 0.606068] PCI: setting IRQ 3 as level-triggered
[ 0.606082] uhci_hcd 0000:00:1f.2: PCI INT D -> Link[LNKD] -> GSI 3 (level, low) -> IRQ 3
[ 0.606106] uhci_hcd 0000:00:1f.2: setting latency timer to 64
[ 0.606117] uhci_hcd 0000:00:1f.2: UHCI Host Controller
[ 0.606345] uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 5
[ 0.606404] uhci_hcd 0000:00:1f.2: irq 3, io base 0x0000ef40
[ 0.611372] usb usb5: configuration #1 chosen from 1 choice
[ 0.611488] hub 5-0:1.0: USB hub found
[ 0.611531] hub 5-0:1.0: 2 ports detected
[ 0.611715] uhci_hcd 0000:00:1f.4: PCI INT C -> Link[LNKH] -> GSI 9 (level, low) -> IRQ 9
[ 0.611742] uhci_hcd 0000:00:1f.4: setting latency timer to 64
[ 0.611754] uhci_hcd 0000:00:1f.4: UHCI Host Controller
[ 0.611905] uhci_hcd 0000:00:1f.4: new USB bus registered, assigned bus number 6
[ 0.611959] uhci_hcd 0000:00:1f.4: irq 9, io base 0x0000ef80
[ 0.612313] usb usb6: configuration #1 chosen from 1 choice
[ 0.612422] hub 6-0:1.0: USB hub found
[ 0.612454] hub 6-0:1.0: 2 ports detected
[ 0.612777] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.620120] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.620163] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.620756] mice: PS/2 mouse device common for all mice
[ 0.621197] rtc_cmos 00:02: RTC can wake from S4
[ 0.621397] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.621436] rtc0: alarms up to one month, 114 bytes nvram
[ 0.621826] device-mapper: uevent: version 1.0.3
[ 0.627338] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.627676] device-mapper: multipath: version 1.1.0 loaded
[ 0.627688] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.628204] EISA: Probing bus 0 at eisa.0
[ 0.628262] EISA: Detected 0 cards.
[ 0.628273] cpuidle: using governor ladder
[ 0.628282] cpuidle: using governor menu
[ 0.629952] TCP cubic registered
[ 0.630645] NET: Registered protocol family 10
[ 0.632287] lo: Disabled Privacy Extensions
[ 0.633471] NET: Registered protocol family 17
[ 0.633573] Using IPI No-Shortcut mode
[ 0.633958] registered taskstats version 1
[ 0.639503] rtc_cmos 00:02: setting system clock to 2013-04-12 08:59:18 UTC (1365757158)
[ 0.639522] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.639529] EDD information not available.
[ 0.719051] ata2.00: ATAPI: FX4831T, R02C, max UDMA/33
[ 0.719157] ata2.01: ATAPI: Memorex DVD+-RAM 530L v1, 5M64, max UDMA/66
[ 0.735983] ata2.00: configured for UDMA/33
[ 0.799331] ata2.01: configured for UDMA/66
[ 0.974650] isapnp: No Plug & Play device found
[ 0.974729] usb 5-1: new low speed USB device using uhci_hcd and address 2
[ 0.975504] scsi 0:0:0:0: Direct-Access ATA WDC WD800JB-00JJ 05.0 PQ: 0 ANSI: 5
[ 0.976044] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.976555] sd 0:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 0.976796] sd 0:0:0:0: [sda] Write Protect is off
[ 0.976808] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.977096] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.977597] scsi 1:0:0:0: CD-ROM MITSUMI CD-ROM FX4831T!A R02C PQ: 0 ANSI: 5
[ 0.978470] sda:sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[ 0.986250] Uniform CD-ROM driver Revision: 3.20
[ 0.986721] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 0.986945] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 0.989150] scsi 1:0:1:0: CD-ROM Memorex DVD+-RAM 530L v1 5M64 PQ: 0 ANSI: 5
[ 0.997048] sda1
[ 0.998286] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.000532] sr1: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.000946] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 1.001176] sr 1:0:1:0: Attached scsi generic sg2 type 5
[ 1.158331] usb 5-1: configuration #1 chosen from 1 choice
[ 1.272197] usb 5-2: new low speed USB device using uhci_hcd and address 3
[ 1.431452] usb 5-2: configuration #1 chosen from 1 choice
[ 1.778601] Freeing initrd memory: 13131k freed
[ 1.837211] Freeing unused kernel memory: 620k freed
[ 1.840234] Write protecting the kernel text: 4540k
[ 1.840339] Write protecting the kernel read-only data: 1668k
[ 1.918917] udev: starting version 151
[ 2.686565] Linux agpgart interface v0.103
[ 2.698785] Floppy drive(s): fd0 is 1.44M
[ 2.725631] Linux Tulip driver version 1.1.15 (Feb 27, 2007)
[ 2.725768] tulip 0000:01:0c.0: PCI INT A -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 2.726344] tulip0: MII transceiver #1 config 1000 status 7849 advertising 01e1.
[ 2.732926] FDC 0 is a post-1991 82077
[ 2.737795] eth0: ADMtek Comet rev 17 at Port 0xd800, 00:20:78:06:76:51, IRQ 10.
[ 2.769287] usbcore: registered new interface driver hiddev
[ 2.882757] input: LiteOn HP USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1f.2/usb5/5-1/5-1:1.0/input/input3
[ 2.883380] generic-usb 0003:04CA:0040.0001: input,hidraw0: USB HID v1.10 Keyboard [LiteOn HP USB Multimedia Keyboard] on usb-0000:00:1f.2-1/input0
[ 2.885005] [drm] Initialized drm 1.1.0 20060810
[ 2.911288] agpgart-intel 0000:00:00.0: Intel i815 Chipset
[ 2.918746] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xf8000000
[ 2.964950] input: LiteOn HP USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1f.2/usb5/5-1/5-1:1.1/input/input4
[ 2.965414] generic-usb 0003:04CA:0040.0002: input,hiddev96,hidraw1: USB HID v1.10 Device [LiteOn HP USB Multimedia Keyboard] on usb-0000:00:1f.2-1/input1
[ 2.980990] input: HID 0461:4d09 as /devices/pci0000:00/0000:00:1f.2/usb5/5-2/5-2:1.0/input/input5
[ 2.981848] generic-usb 0003:0461:4D09.0003: input,hidraw2: USB HID v1.00 Mouse [HID 0461:4d09] on usb-0000:00:1f.2-2/input0
[ 2.981981] usbcore: registered new interface driver usbhid
[ 2.982402] usbhid: v2.6:USB HID core driver
[ 3.071742] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[ 3.071762] nouveau 0000:02:00.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 3.096331] [drm] nouveau 0000:02:00.0: Detected an NV10 generation card (0x011100b2)
[ 3.096548] [drm] nouveau 0000:02:00.0: Attempting to load BIOS image from PROM
[ 3.248887] [drm] nouveau 0000:02:00.0: ... appears to be valid
[ 3.249736] [drm] nouveau 0000:02:00.0: BMP BIOS found
[ 3.249746] [drm] nouveau 0000:02:00.0: BMP version 5.20
[ 3.249757] [drm] nouveau 0000:02:00.0: Bios version 03.11.01.30
[ 3.249770] [drm] nouveau 0000:02:00.0: Found Display Configuration Block version 1.5
[ 3.249785] [drm] nouveau 0000:02:00.0: Raw DCB entry 0: f0003f00 000088b8
[ 3.250532] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 0 at offset 0x962C
[ 3.250560] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 1 at offset 0x9D1A
[ 3.250578] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 2 at offset 0x9647
[ 3.250619] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 3 at offset 0x9CC1
[ 3.250640] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 4 at offset 0x96DA
[ 3.250653] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 5 at offset 0x982E
[ 3.250691] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 6 at offset 0x96FF
[ 3.250736] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 7 at offset 0x97C9
[ 3.259661] [TTM] Zone kernel: Available graphics memory: 254602 kiB.
[ 3.259706] [drm] nouveau 0000:02:00.0: 32 MiB VRAM
[ 3.259827] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
[ 3.259867] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 3.259912] nouveau 0000:02:00.0: putting AGP V2 device into 4x mode
[ 3.259990] [drm] nouveau 0000:02:00.0: 64 MiB GART (aperture)
[ 3.260494] [drm] nouveau 0000:02:00.0: Allocating FIFO number 0
[ 3.262899] [drm] nouveau 0000:02:00.0: nouveau_channel_alloc: initialised FIFO 0
[ 3.262933] [drm] nouveau 0000:02:00.0: Initial CRTC_OWNER is 0
[ 3.262952] [drm] nouveau 0000:02:00.0: Saving VGA fonts
[ 3.311143] [drm] nouveau 0000:02:00.0: Detected a VGA connector
[ 3.312850] [drm] nouveau 0000:02:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 3.437839] [drm] nouveau 0000:02:00.0: allocated 1280x1024 fb: 0x49000, bo d780ec00
[ 3.438316] fb0: nouveaufb frame buffer device
[ 3.438324] registered panic notifier
[ 3.438342] [drm] Initialized nouveau 0.0.15 20090420 for 0000:02:00.0 on minor 0
[ 3.449950] vga16fb: initializing
[ 3.449970] vga16fb: mapped to 0xc00a0000
[ 3.449986] vga16fb: not registering due to another framebuffer present
[ 3.554279] [drm] nouveau 0000:02:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 3.554294] [drm] nouveau 0000:02:00.0: Output VGA-1 is running on CRTC 0 using output A
[ 3.558014] Console: switching to colour frame buffer device 160x64
[ 4.294880] xor: automatically using best checksumming function: pIII_sse
[ 4.312034] pIII_sse : 1496.000 MB/sec
[ 4.312043] xor: using function: pIII_sse (1496.000 MB/sec)
[ 4.327313] device-mapper: dm-raid45: initialized v0.2594b
[ 4.932657] EXT4-fs (loop0): mounted filesystem with ordered data mode
[ 8.069795] udev: starting version 151
[ 9.696487] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.774014] intel_rng: Firmware space is locked read-only. If you can't or
[ 9.774025] intel_rng: don't want to disable this in firmware setup, and if
[ 9.774031] intel_rng: you are certain that your system has a functional
[ 9.774036] intel_rng: RNG, try using the 'no_fwh_detect' option.
[ 9.866778] parport_pc 00:09: reported by Plug and Play ACPI
[ 9.866826] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 10.057321] lp0: using parport0 (interrupt-driven).
[ 10.068132] ppdev: user-space parallel port driver
[ 10.627787] gameport: EMU10K1 is pci0000:01:0a.1/gameport0, io 0xdff0, speed 1104kHz
[ 11.528932] type=1505 audit(1365771569.388:2): operation="profile_load" pid=556 name="/sbin/dhclient3"
[ 11.530529] type=1505 audit(1365771569.388:3): operation="profile_load" pid=556 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 11.531413] type=1505 audit(1365771569.388:4): operation="profile_load" pid=556 name="/usr/lib/connman/scripts/dhclient-script"
[ 11.537964] type=1505 audit(1365771569.396:5): operation="profile_replace" pid=554 name="/sbin/dhclient3"
[ 11.539600] type=1505 audit(1365771569.396:6): operation="profile_replace" pid=554 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 11.550658] type=1505 audit(1365771569.408:7): operation="profile_replace" pid=554 name="/usr/lib/connman/scripts/dhclient-script"
[ 12.333411] EMU10K1_Audigy 0000:01:0a.0: PCI INT A -> Link[LNKG] -> GSI 11 (level, low) -> IRQ 11
[ 18.371786] Adding 261112k swap on /host/ubuntu/disks/swap.disk. Priority:-1 extents:1 across:261112k
[ 19.773509] type=1505 audit(1365771577.633:8): operation="profile_load" pid=859 name="/usr/share/gdm/guest-session/Xsession"
[ 19.796303] type=1505 audit(1365771577.656:9): operation="profile_replace" pid=860 name="/sbin/dhclient3"
[ 19.797922] type=1505 audit(1365771577.656:10): operation="profile_replace" pid=860 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 19.798860] type=1505 audit(1365771577.656:11): operation="profile_replace" pid=860 name="/usr/lib/connman/scripts/dhclient-script"
[ 20.093383] type=1505 audit(1365771577.952:12): operation="profile_load" pid=863 name="/usr/bin/evince"
[ 20.119956] type=1505 audit(1365771577.976:13): operation="profile_load" pid=863 name="/usr/bin/evince-previewer"
[ 20.141195] type=1505 audit(1365771578.000:14): operation="profile_load" pid=863 name="/usr/bin/evince-thumbnailer"
[ 20.332342] type=1505 audit(1365771578.192:15): operation="profile_load" pid=875 name="/usr/lib/cups/backend/cups-pdf"
[ 20.334355] type=1505 audit(1365771578.192:16): operation="profile_load" pid=875 name="/usr/sbin/cupsd"
[ 20.397098] type=1505 audit(1365771578.256:17): operation="profile_load" pid=879 name="/usr/sbin/tcpdump"
[ 24.630165] [drm] nouveau 0000:02:00.0: Allocating FIFO number 1
[ 24.638020] [drm] nouveau 0000:02:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 32.356073] eth0: no IPv6 routers present
[ 119.973046] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 277.975236] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 279.110855] halcmd[1744]: segfault at 8 ip 009c56bc sp bfc436b0 error 6 in liblinuxcnchal.so.0[9c0000+8000]
[ 279.121585] halcmd[1745]: segfault at 8 ip 008996bc sp bf8b3750 error 6 in liblinuxcnchal.so.0[894000+8000]
[ 279.182844] halcmd[1748]: segfault at 8 ip 0085d6bc sp bfee9e90 error 6 in liblinuxcnchal.so.0[858000+8000]
[ 279.462729] halcmd[1752]: segfault at 8 ip 00a1e6bc sp bfafd810 error 6 in liblinuxcnchal.so.0[a19000+8000]
[ 279.687267] halcmd[1756]: segfault at 8 ip 00f4b6bc sp bfec3460 error 6 in liblinuxcnchal.so.0[f46000+8000]
[ 279.915214] halcmd[1760]: segfault at 8 ip 006066bc sp bfcf3fe0 error 6 in liblinuxcnchal.so.0[601000+8000]
[ 280.142890] halcmd[1764]: segfault at 8 ip 00dd16bc sp bfd04a70 error 6 in liblinuxcnchal.so.0[dcc000+8000]
[ 280.376579] halcmd[1768]: segfault at 8 ip 00f3e6bc sp bfa7b2d0 error 6 in liblinuxcnchal.so.0[f39000+8000]
[ 280.603332] halcmd[1772]: segfault at 8 ip 00a0a6bc sp bfa83e40 error 6 in liblinuxcnchal.so.0[a05000+8000]
[ 280.830400] halcmd[1776]: segfault at 8 ip 007406bc sp bff116d0 error 6 in liblinuxcnchal.so.0[73b000+8000]
[ 373.060642] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 373.973607] __ratelimit: 2 callbacks suppressed
[ 373.973625] halcmd[1923]: segfault at 8 ip 00f146bc sp bfbf1eb0 error 6 in liblinuxcnchal.so.0[f0f000+8000]
[ 373.984277] halcmd[1924]: segfault at 8 ip 00c356bc sp bfa3b700 error 6 in liblinuxcnchal.so.0[c30000+8000]
[ 374.010601] halcmd[1927]: segfault at 8 ip 0036d6bc sp bfa3b440 error 6 in liblinuxcnchal.so.0[368000+8000]
[ 374.235227] halcmd[1931]: segfault at 8 ip 008746bc sp bf9fb310 error 6 in liblinuxcnchal.so.0[86f000+8000]
[ 374.463307] halcmd[1935]: segfault at 8 ip 008a36bc sp bf81ef70 error 6 in liblinuxcnchal.so.0[89e000+8000]
[ 374.690262] halcmd[1939]: segfault at 8 ip 00f566bc sp bffc0a70 error 6 in liblinuxcnchal.so.0[f51000+8000]
[ 374.915174] halcmd[1943]: segfault at 8 ip 006656bc sp bfe4dfe0 error 6 in liblinuxcnchal.so.0[660000+8000]
[ 375.145413] halcmd[1947]: segfault at 8 ip 002396bc sp bfdf76f0 error 6 in liblinuxcnchal.so.0[234000+8000]
[ 375.375252] halcmd[1951]: segfault at 8 ip 003ba6bc sp bfa43140 error 6 in liblinuxcnchal.so.0[3b5000+8000]
[ 375.602687] halcmd[1955]: segfault at 8 ip 007b76bc sp bf9ad260 error 6 in liblinuxcnchal.so.0[7b2000+8000]
[ 450.365194] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 451.258441] __ratelimit: 2 callbacks suppressed
[ 451.258459] halcmd[2143]: segfault at 8 ip 006206bc sp bf92c4b0 error 6 in liblinuxcnchal.so.0[61b000+8000]
[ 451.269088] halcmd[2144]: segfault at 8 ip 004956bc sp bfcba840 error 6 in liblinuxcnchal.so.0[490000+8000]
[ 451.295441] halcmd[2147]: segfault at 8 ip 006fb6bc sp bfc1c9d0 error 6 in liblinuxcnchal.so.0[6f6000+8000]
[ 451.523046] halcmd[2151]: segfault at 8 ip 002a36bc sp bfb16040 error 6 in liblinuxcnchal.so.0[29e000+8000]
[ 451.747191] halcmd[2155]: segfault at 8 ip 00aa16bc sp bff5b000 error 6 in liblinuxcnchal.so.0[a9c000+8000]
[ 451.975232] halcmd[2159]: segfault at 8 ip 007986bc sp bfe59b30 error 6 in liblinuxcnchal.so.0[793000+8000]
[ 452.203242] halcmd[2163]: segfault at 8 ip 00da66bc sp bff910e0 error 6 in liblinuxcnchal.so.0[da1000+8000]
[ 452.431296] halcmd[2167]: segfault at 8 ip 009bb6bc sp bfc55470 error 6 in liblinuxcnchal.so.0[9b6000+8000]
[ 452.655178] halcmd[2171]: segfault at 8 ip 00e166bc sp bf9933c0 error 6 in liblinuxcnchal.so.0[e11000+8000]
[ 452.883224] halcmd[2175]: segfault at 8 ip 0046f6bc sp bfda80d0 error 6 in liblinuxcnchal.so.0[46a000+8000]
[ 1639.278114] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1640.828929] __ratelimit: 2 callbacks suppressed
[ 1640.828947] halcmd[2897]: segfault at 8 ip 0027e6bc sp bfe4f8e0 error 6 in liblinuxcnchal.so.0[279000+8000]
[ 1640.839616] halcmd[2898]: segfault at 8 ip 00d776bc sp bfdc5e30 error 6 in liblinuxcnchal.so.0[d72000+8000]
[ 1640.877453] halcmd[2901]: segfault at 8 ip 00bdd6bc sp bfc57a90 error 6 in liblinuxcnchal.so.0[bd8000+8000]
[ 1641.131353] halcmd[2905]: segfault at 8 ip 00f426bc sp bfef73a0 error 6 in liblinuxcnchal.so.0[f3d000+8000]
[ 1641.359130] halcmd[2909]: segfault at 8 ip 0066a6bc sp bfbe8f90 error 6 in liblinuxcnchal.so.0[665000+8000]
[ 1641.583330] halcmd[2913]: segfault at 8 ip 00d2f6bc sp bfc5f1a0 error 6 in liblinuxcnchal.so.0[d2a000+8000]
[ 1641.811261] halcmd[2917]: segfault at 8 ip 00f3f6bc sp bfac5680 error 6 in liblinuxcnchal.so.0[f3a000+8000]
[ 1642.039454] halcmd[2921]: segfault at 8 ip 00bb06bc sp bfd04240 error 6 in liblinuxcnchal.so.0[bab000+8000]
[ 1642.267274] halcmd[2925]: segfault at 8 ip 001616bc sp bfb5c480 error 6 in liblinuxcnchal.so.0[15c000+8000]
[ 1642.491340] halcmd[2929]: segfault at 8 ip 002536bc sp bfd25c60 error 6 in liblinuxcnchal.so.0[24e000+8000]
[ 1824.900065] usb 1-3: new high speed USB device using ehci_hcd and address 2
[ 1825.037851] usb 1-3: configuration #1 chosen from 1 choice
[ 1825.308107] Initializing USB Mass Storage driver...
[ 1825.312613] scsi2 : SCSI emulation for USB Mass Storage devices
[ 1825.313340] usbcore: registered new interface driver usb-storage
[ 1825.313354] USB Mass Storage support registered.
[ 1825.334678] usb-storage: device found at 2
[ 1825.334690] usb-storage: waiting for device to settle before scanning
[ 1830.332830] usb-storage: device scan complete
[ 1830.333925] scsi 2:0:0:0: Direct-Access Generic Mass Storage 1.00 PQ: 0 ANSI: 2
[ 1830.342231] sd 2:0:0:0: Attached scsi generic sg3 type 0
[ 1830.347378] sd 2:0:0:0: [sdb] 2031487 512-byte logical blocks: (1.04 GB/991 MiB)
[ 1830.348610] sd 2:0:0:0: [sdb] Write Protect is off
[ 1830.348626] sd 2:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 1830.348636] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 1830.362885] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 1830.362927] sdb:
[ 1830.401238] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 1830.401258] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 1926.593062] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1927.866055] __ratelimit: 2 callbacks suppressed
[ 1927.866074] halcmd[3111]: segfault at 8 ip 001156bc sp bf88a6f0 error 6 in liblinuxcnchal.so.0[110000+8000]
[ 1927.877048] halcmd[3112]: segfault at 8 ip 00f9e6bc sp bf9020d0 error 6 in liblinuxcnchal.so.0[f99000+8000]
[ 1927.916225] halcmd[3115]: segfault at 8 ip 00d4a6bc sp bfa86380 error 6 in liblinuxcnchal.so.0[d45000+8000]
[ 1928.143005] halcmd[3119]: segfault at 8 ip 002ad6bc sp bfa24720 error 6 in liblinuxcnchal.so.0[2a8000+8000]
[ 1928.367165] halcmd[3123]: segfault at 8 ip 00fa96bc sp bfd58220 error 6 in liblinuxcnchal.so.0[fa4000+8000]
[ 1928.595194] halcmd[3127]: segfault at 8 ip 00ee46bc sp bfd48950 error 6 in liblinuxcnchal.so.0[edf000+8000]
[ 1928.824502] halcmd[3131]: segfault at 8 ip 006766bc sp bfbe7aa0 error 6 in liblinuxcnchal.so.0[671000+8000]
[ 1929.055717] halcmd[3135]: segfault at 8 ip 006c76bc sp bfce9c40 error 6 in liblinuxcnchal.so.0[6c2000+8000]
[ 1929.282396] halcmd[3139]: segfault at 8 ip 002db6bc sp bf9059b0 error 6 in liblinuxcnchal.so.0[2d6000+8000]
[ 1929.507158] halcmd[3143]: segfault at 8 ip 003dc6bc sp bfd7c140 error 6 in liblinuxcnchal.so.0[3d7000+8000]
Last edit: 13 Apr 2013 18:21 by BigJohnT. Reason: add code tags
13 Apr 2013 01:13 #32655
Replied by PCW on topic A VERY Newbie question.
The logfile somehow did not get attached, but a 733 MHz system may well be
too old to run the standard 10.04 based LinuxCNC distribution.
I first would check if the problem is the LAPIC issue:
wiki.linuxcnc.org/cgi-bin/wiki.pl?TroubleShooting (section 2 : missing LAPIC)
If the changes to grub don't fix things I would use the older 8.04 lLinuxCNC based distribution
13 Apr 2013 02:35 #32660
by fishtruk
Replied by fishtruk on topic A VERY Newbie question.
Hello, I pasted the errors in the first post above since I couldn't attach it for some reason.
13 Apr 2013 08:38 #32667
The multi-processor version of LinuxCNC requires a LAPIC. It looks like that is disabled in your BIOS.
If you can't enable it then the old (Hardy Heron Ubuntu 8.04) installation of LinuxCNC will probably work, and can actually be upgraded to the the latest (2.5.2) LinuxCNC version, though only if you don't update the OS)
There may be boot-menu options to circumvent the problem.
Replied by andypugh on topic A VERY Newbie question.
13 Apr 2013 18:23 #32675
by BigJohnT
Using the code tags will make the overall message smaller and easier to navigate. If you use one of the extensions that is allowed for attachments it will attach. Using .txt is good for error messages.
Replied by BigJohnT on topic A VERY Newbie question.
Time to create page: 0.297 seconds
