10.04 LiveCD Installation locks-up
- tonyheatco
29 Apr 2013 19:27 #33382
by tonyheatco
10.04 LiveCD Installation locks-up was created by tonyheatco
Greetings,
Wasn't able find this issue through the search option. Hoping there is a known solution to the following...
Symptoms:
About 2 minutes into install the PC locks-up, caps and scroll lock leds flash, Ubuntu progress "dots" halt.
What I've tried/found:
Twice downloaded ISO - 2 different CD-R brands - 2 different PC's with/without network connection (1) Dell Dimmension4550 (2) Dell Vostro 1500 - both known working machines.
-Checksum matched published on both downloaded ISO's
-Fails both Live and Full installation attempts - both PC's with same symptoms
-Check disk files option advises of 1 bad file both CD's... no report of which file though
Any ideas?
Thanks!
Symptoms:
Any ideas?
Thanks!
29 Apr 2013 19:32 #33383
by ArcEye
Replied by ArcEye on topic 10.04 LiveCD Installation locks-up
Hi
Dell Dimension looks to be a Intel P4
Try the Ubuntu 8.04 Live CD, 10.04 will not even load on some older machines
- tonyheatco
29 Apr 2013 19:39 #33385
by tonyheatco
You are correct, P4 in the Dimension. The Vostro is a Core2 Duo. I'll give the 8.04 version a whirl and advise.
Thanks for the quick advice!
Replied by tonyheatco on topic 10.04 LiveCD Installation locks-up
Hi
- tonyheatco
30 Apr 2013 08:11 #33422
by tonyheatco
No troubles installing 8.04 from the LiveCD - Many thanks!
Time to create page: 0.114 seconds
