New Installation LinuxCNC Crashes/Hangs computer w
23 Jun 2013 00:46 #35925
by Sferix2
New Installation LinuxCNC Crashes/Hangs computer w was created by Sferix2
Newbie here, needing some help getting LinuxCNC running please. I have installed LinuxCNC but when I run it, it crashes/hangs the computer and needs a reboot to recover. Steps I have followed are:
I Downloaded ubuntu-10.04-linuxcnc3-i386.iso from this site, burnt the ISO disk and installed it afresh on computer. It installed Ubuntu 10.04 and LinuxCNC 2.5.0, with no updates or upgrades (network disconnected).
I ran the Stepconf wizard ok but when I tried the Test Axis panel it failed with a Broken Pipe error. I read thru the troubleshooting guide and found I was getting the LAPIC error "error inserting '/usr/realtime-2.6.32-122rtai/modules..." .
I followed the steps to fix the LAPIC error and after reboot I could run the Test Axis panel in Stepconf and jog the axes around, hooray ! However when I run LinuxCNC proper it just crashes/hangs the computer, and needs a reboot to recover.
I connected the network and let ubuntu update manager apply updates (not upgrading from 10.04). I now have LinuxCNC 2.5.2 on Ubuntu 10.04. However when I run LinuxCNC it still crashes/hangs the computer. The kernel is 2.6.32-122-rtai.
When I run LinuxCNC the message window shows 9 lines before it hangs.
1: ( AXIS "splash g-code" Not intended for actual milling )
7: ( LinuxCNC 19/1/2012 2:13:51 PM )
8: G21 G90 G64 G40
9: G0 Z3.0
and then it freezes.
I've repeated the install from scratch and still get the same problem. I've read the Troubleshooting guide but can't find any further help there. I've scanned the forum, but also haven't found any further help for this problem.
Hands up I'm probably missing something, but it's new, I don't understand what's wrong and I'm no linux guru. So I'd appreciate any help/guidance to troubleshoot the problem and get it working please.
8: G21 G90 G64 G40
9: G0 Z3.0
23 Jun 2013 16:06 #35943
by ArcEye
Replied by ArcEye on topic New Installation LinuxCNC Crashes/Hangs computer w
Hi
There was a problem with axis.ngc which is run by default when Axis starts, locking it up, but I can't remember which version it was with or if it was fixed properly.
Go to /usr/share/axis/images
Copy axis.ngc to axis.ngc.old
Open axis.ngc and delete everything except the final M2 line and save it
Then try opening linuxcnc again
If the problem was that file it should work fine, if not start linuxcnc from a terminal and cut and paste the output in a post so we can see what is happening.
(Another possibility is an openGL error as soon as it tries to render a plot.)
23 Jun 2013 19:44 #35948
by Sferix2
Replied by Sferix2 on topic New Installation LinuxCNC Crashes/Hangs computer w
Thanks ArcEye I will investigate that.
I forgot to mention that I ran glxgears when running the the latency test without any problem, so openGL seems to work ok, and the ubuntu installation does otherwise seem ok, although I've not given it an exhaustive test.
Thanks for your help.
23 Jun 2013 20:07 - 23 Jun 2013 20:19 #35949
by Rick G
Replied by Rick G on topic New Installation LinuxCNC Crashes/Hangs computer w
Is there also a problem with just jogging around, or running a regular ngc file?
If not it would seem axis.ngc is the problem, as there is no reason to run it seems like no reason to worry about it.
Or perhaps I misunderstood your post. Are you saying Linuxcnc hangs when starting or when you try to run the splash screen?
You can also edit the Display section of your ini file to use tkemc to see if the problem goes away.
www.linuxcnc.org/docs/2.4/html/config_ini_config.html
Rick G
Rick G
Last edit: 23 Jun 2013 20:19 by Rick G.
25 Jun 2013 05:03 #36011
by Sferix2
I've tried modifying the axis.ngc file as suggested by ArcEye but it hasn't helped sadly. When I run LinuxCNC the message window shows
1: M2
and then the computer freezes.
I've tried starting LinuxCNC from a terminal and all I get is
Starting LinuxCNC...
I've installed from scratch again, no updates or upgrades (network disconnected), Linux 2.5.0. Fixed the Lapic error and performed the above tests again with the same results. The computer freezes.
The Ubuntu installation itself seems to work fine. When it has been connected to the network I can browse the web, watch YouTube videos, run glxgears and so on.
One thing I noted, is when starting LinuxCNC from a terminal it prompts me to choose a conf file, e.g. my-mill. It then freezes the computer whatever conf file I choose.
Rick G: Yes LinuxCNC hangs/freezes/crashes the whole computer when it is started. I have not yet got LinuxCNC to run at all, to try anything else with it. I have jogged the axes using the test panel in the stepconf wizard.
Thanks for your help so far, but I'm still stuck so any other suggestions please.
What's involved in building from source is that worth a try ?
1: M2
25 Jun 2013 05:24 #36013
by BigJohnT
Replied by BigJohnT on topic New Installation LinuxCNC Crashes/Hangs computer w
Try running a sample config that uses a non-open gl driver like anything but axis and see if it is an open gl issue.
JT
JT
25 Jun 2013 13:59 #36023
by Sferix2
Thanks for the suggestion JT.
I am totally new to LinuxCNC, and CNC in general. How/where do I identify a config that uses a non-open gl driver ?
25 Jun 2013 14:49 - 25 Jun 2013 14:52 #36028
by ArcEye
Try Sample Configurations > sim > tklinuxcnc or xlinuxcnc
You will recall I did say it could be the actual rendering of the plot rather than the file it was loading, that caused the problem
But we had to eliminate the file first.
Sometimes running glxgears is not a good indication of openGL problems
It is not a very extensive or sophisticated rendering.
This seems especially true when using a nvidia card or chip, their proprietary drivers GL rendering can cause huge problems.
If you have nvidia, consider using the opensource nv driver or even changing to the vesa one and see if that allows the plot rendering to work.
I don't think that switching to the software openGL libraries is likely to be the answer, because the situation that requires this normally produces a
blank black square or broken lines in Gremlin and never gets as far as rendering a plot.
But it is another option if the other ones don't apply / don't work
PS
Really need the output from dmesg after the computer locked (dmesg > dmesg.text)
That should show a segfault and the library access that caused it
PS
Last edit: 25 Jun 2013 14:52 by ArcEye.
02 Jul 2013 05:11 #36223
by Sferix2
Sorry for the delay, and thanks for your help. I tried some of the non OpenGL configs and they seemed to work ok, and more importantly didn't crash the machine.
The gfx card isn't NVidia but an ATI Rage128 Pro 32MB. Synaptic reported the Xorg Rage driver was installed so I uninstalled that and rebooted to the ubuntu generic vga driver.
I then run LinuxCNC with a graphics config and it seems to run ok, no crash/hang. I have been able to run the LinuxCNC test program and the mill seems to be doing the right things. So this has worked around the problem but left me with a rather poor graphics display. Hence I need to do some further investigation on the gfx card/driver issue and possibly replace the card.
The machine I'm using is quite old, as the requirement for a desktop machine with a parallel port to connect to the mill has limited what I have available. So if I replace the gfx card I'm looking for something that will go in an AGP 1/2/4x slot. Any advice on what AGP cards are known to work would be appreciated.
Thanks again for your help.
02 Jul 2013 15:06 #36227
by ArcEye
Hi
At least that has narrowed down the problem to the openGL one suspected
I have no personal knowledge of working AGP cards but the latency test wiki does list the graphics cards used for the most part
If you spot one on there you can acquire that seems to be linked with good latency, might be one way to choose
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
One thing I would try before doing this, is the software based openGL libraries
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
It is as simple as going into synaptic package manager and searching for and selecting libgl1-mesa-swx11
Select apply and you will be notified that libgl1-mesa-XXX will be removed, just make a note of the exact names
If that does not work better with your card, then go back into synaptic and install the libraries which were removed and libgl1-mesa-swx11 will be removed.
Then have a look for an AGP card
Time to create page: 0.130 seconds
