How to update 2.5 to 2.5.2 without internet
30 Jun 2013 01:07 #36161
by papaours
How to update 2.5 to 2.5.2 without internet was created by papaours
My workshop did not have lan or wifi internet connection ( except an 3G iPad. )
so i would like to upgrade linuxcnc 2.5, but how to do.
i have look around, but did not get any info
THank you.
THank you.
30 Jun 2013 03:11 #36162
by papaours
Replied by papaours on topic How to update 2.5 to 2.5.2 without internet
i am on my way to try it, i hop i will be able with the terminal to instal it....... i am a linux neewbe
linuxcnc.org/lucid/dists/lucid/linuxcnc2.5/source/?C=N;O=D
30 Jun 2013 16:16 - 30 Jun 2013 20:49 #36169
by ArcEye
Replied by ArcEye on topic How to update 2.5 to 2.5.2 without internet
Hi
The link you posted is to the sources for linuxcnc
Unless you have all the necessary build tools, which you also won't be able to download, you will not be able to build it.
If you already have 2.5, you should have all the required packages installed to upgrade the linuxcnc debs
This is the debian/control file for the 2.5.2 deb
Check through that you have all the packages listed under Depends: in this file
sudo dpkg --get-selections | grep packagename
(Where there are several package names seperated by a |, that means OR and you just need one of those packages )
If not you will have to search for it, to download the deb for the correct Ubuntu version and copy to USB stick
Then download from the binary repository at linuxcnc.org/lucid/dists/lucid/linuxcnc2.5/binary-i386/
the linuxcnc deb and the linuxcnc-dev deb
Transfer them to a USB stick and from there to your workshop computer
You can install using dpkg
First install any missing dependencies
sudo dpkg -i dependency.deb
(If there are more than one, may need to be in a particular order if they are inter-dependent)
Then
sudo dpkg -i linuxcnc_2.5.2_i386.deb
sudo dpkg -i linuxcnc-dev_2.5.2_i386.deb
to install the new ones
If you get any complaints, you may need to remove the old packages first
sudo dpkg -r linuxcnc
sudo dpkg -r linuxcnc-dev
Might seem a bit mind blowing if you are a complete linux newbie, but work through thoroughly and look up all the things you are doing before you do them
and you should come away with an understanding of how packages work if nothing else
Package: linuxcnc
Version: 1:2.5.2.234.gfb4e71e
Architecture: i386
Maintainer: Chris Radek <chris@timeguy.com>
Installed-Size: 20428
Depends: libart-2.0-2 (>= 2.3.18), libatk1.0-0 (>= 1.29.3), libc6 (>= 2.7), libcairo2 (>= 1.2.4), libfontconfig1 (>= 2.8.0), libfreetype6 (>= 2.2.1), libgcc1 (>= 1:4.1.1), libgl1-mesa-glx | libgl1, libglib2.0-0 (>= 2.16.0), libglu1-mesa | libglu1, libgnomecanvas2-0 (>= 2.11.1), libgnomeprint2.2-0 (>= 2.17.0), libgnomeprintui2.2-0 (>= 2.17.0), libgtk2.0-0 (>= 2.8.0), libice6 (>= 1:1.0.0), libncurses5 (>= 5.0), libpango1.0-0 (>= 1.14.0), libreadline6 (>= 6.0), libsm6, libstdc++6 (>= 4.2.1), libx11-6 (>= 0), libxaw7, libxext6, libxft2 (>> 2.1.1), libxinerama1, libxml2 (>= 2.6.27), libxmu6, libxrender1, libxss1, libxt6, tk8.5 (>= 8.5.0), zlib1g (>= 1:1.1.4), linux-image-2.6.32-122-rtai, rtai-modules-2.6.32-122-rtai, tcl8.5, bwidget (>= 1.7), libtk-img (>= 1.13), python (>= 2.6), python (<< 2.7), python-support (>= 0.90.0), python2.6-tk, python2.6-gnome2 | python-gnome2, python2.6-glade2 | python-glade2, python2.6-numpy | python-numpy, python2.6-imaging, python2.6-imaging-tk | python-imaging-tk, python-xlib, python-gtkglext1, python-configobj, tclreadline, bc, procps
Recommends: linuxcnc-doc-en | linuxcnc-doc-fr | linuxcnc-doc-de | linuxcnc-doc-es | linuxcnc-doc-pl, hostmot2-firmware
Conflicts: emc2, emc2-sim, linuxcnc-sim
Replaces: emc2
Provides: emc2
Section: misc
Priority: extra
Description: PC based motion controller for real-time Linux
LinuxCNC is the next-generation Enhanced Machine Controller which
provides motion control for CNC machine tools and robotic
applications (milling, cutting, routing, etc.).
Then
Last edit: 30 Jun 2013 20:49 by ArcEye.
The following user(s) said Thank You: skvallab
05 Jul 2013 05:39 #36316
by papaours
Thank you for your answer,
I have done the upgrade by removing the hard disk from the machine cabinet and plug it into a my home computer.
So simple...... When you can conect it to internet !
05 Jul 2013 16:05 #36328
by ArcEye
Yeah, that would work too
I thought your only option was a 3g iPad![:laugh: :laugh:](/media/kunena/emoticons/laughing.png)
Time to create page: 0.082 seconds
