Need help installing LinuxCNC
- jrbankston1
04 Jul 2013 20:49 #36301
by jrbankston1
Need help installing LinuxCNC was created by jrbankston1
I tried to run LinuxCNC under Ubuntu 10.04 but would not run in the demo mode nor in the installed mode. I got the attached error file. This same disk was used to install on another computer which runs fine. Any suggestions.
04 Jul 2013 22:01 #36305
by ArcEye
Replied by ArcEye on topic Need help installing LinuxCNC
Nothing attached.
Save it as a .txt extension and try again
- jrbankston1
05 Jul 2013 06:39 #36318
by jrbankston1
Replied by jrbankston1 on topic Need help installing LinuxCNC
Lets try again.
05 Jul 2013 09:26 #36322
Replied by PCW on topic Need help installing LinuxCNC
Looks like the common LAPIC issue:
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
see:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
for possible fix
see:
for possible fix
- jrbankston1
05 Jul 2013 18:56 #36331
by jrbankston1
Thanks for the help but how do I modify a read only file?
05 Jul 2013 19:33 #36333
gksudo gedit
That will open gedit in sudo mode, so it can edit any file.
Replied by andypugh on topic Need help installing LinuxCNC
gksudo gedit
- jrbankston1
05 Jul 2013 20:47 #36335
by jrbankston1
OK I tried that and now I get the attached error message.
05 Jul 2013 20:51 #36337
It still says
"[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic""
Did you remember the sudo update-grub part of the process?
Have you actually tried enabling it in the BIOS?
It still says
05 Jul 2013 20:54 #36338
by ArcEye
You still don't have LAPIC available
What computer is this?
If it is an older one you would be better using 8.04 and the LAPIC issue does not arise
[ 319.526466] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
Time to create page: 0.170 seconds
