Installing on 12.04 using AraisRobo Hardware
So far so good, I have followed the instructions as per :
wiki.linuxcnc.org/cgi-bin/wiki.pl?ArtekBranch
And have compiled everything without any errors.
However when I try to run LinuxCNC I get the following errors :
LINUXCNC - master-2012.07.18 ARAIS ROBOT TECHNOLOGY
Error in startup script: couldn't load file "/home/gajafajumpa/linuxcnc/tcl/bin/../linuxcnc.so": /home/gajafajumpa/linuxcnc/tcl/bin/../linuxcnc.so: cannot open shared object file: No such file or directory
while executing
"load [file join [file dirname [info script]] linuxcnc[info sharedlibextension]]"
(file "/home/gajafajumpa/linuxcnc/tcl/bin/../linuxcnc.tcl" line 59)
invoked from within
"source [file join [file dirname [info script]] .. linuxcnc.tcl]"
(file "/home/gajafajumpa/linuxcnc/tcl/bin/pickconfig.tcl" line 29)
I have a friend that managed to get this up and running on his PC but says that the ARTEK Branch page looked different when he did it (about a week or so ago)
I cannot find the linuxcnc.so file anywhere on the PC or the internet for that matter so I assume it is something that is created during the compile.
I have emailed Arais Robo with the details and waiting for his reply.
I will keep this thread going until (hopefully) everything is working as a build log as others may wish to try this out.
If anybody has ideas on things to try I am all ears, just be aware I am by no means a linux guru, but I can copy and paste
Cheers.
Russell.
The error is to do with your library paths, probably from building in your home directory instead of /usr/src
If you have built a RIP build of linuxcnc, the python library linuxcnc.so is in .../lib/python/ of that build
If you have installed into your file system, then the lib is at /usr/lib/pyshared/python2.6/
The error is from the initial config chooser dialog, which is written in python and uses that lib
So is it just a matter of moving the library file or should I change the library paths ?
Sorry if I am asking stupid questions...
I don't know what type of builds you did, but this looks horribly hard coded
I would do a git clone again, but this time into /usr/src
Build as per the instructions which should leave you with a RIP build of a simulator (you may need to use sudo prefixing commands)
Make sure you have set the other library paths as per the wiki
# Add /usr/local/lib to shared library search path
# You might want to add the following line to ~/.bashrc
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
The linuxcnc.so lib will be in lib/python and that is where it should be looking
Make sure you do
cd ../
. ./scripts/rip-environment
after building and before you try to run it, and type linuxcnc from the same terminal not from a menu
Hopefully should work, albeit the wiki says that the simulator does not work, so not entirely sure of the point.
I cloned the repos from the wiki and built the libraries no problem
The linuxcnc branch would not compile until I added #include <stdint.h> to motion.h, for some reason it was not recognising int32_t as a type
This is probably to do with my setup, different kernel, headers and much else beyond.
Having built linuxcnc the config picker works fine, so got beyond your problem.
But when launching any of the scara sims, it errors trying to find motmod.so
This did not build for some reason, although it is in the Makefile
Machine configuration directory is '/usr/src/arias-linuxcnc/configs/araisrobo'
Machine configuration file is 'xyza-sim.ini'
Starting LinuxCNC...
io started
halcmd loadusr io started
motmod: dlopen: /usr/src/arias-linuxcnc/rtlib/motmod.so: cannot open shared object file: No such file or directory
xyza-stepper.hal:6: /usr/src/arias-linuxcnc/bin/rtapi_app exited without becoming ready
xyza-stepper.hal:6: insmod failed, returned -1
Cleanup done
As I have no use for it and this could be the error mentioned in the wiki, I gave up at this point without trying to figure out why motmod.so was not built.
Interested to see if you get the same.
NB all builds were done in /usr/src
Next on the list is that I cannot connect to the FPGA over USB so I will go through the hardware side of things and see what I have missed.
Thanks again for your help.
Russell.
I am assuming that there is somewhere I need to configure to tell LinuxCNC which USB port I am using, I have no idea what that is.
I read through the ini file and hal file (I am using the xyza.ini) but I cannot see anything I can modify to setup the USB side of things.
I did a lsusb and can see the MESA card :
Bus 006 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Any ideas ?
Cheers.
Russell.
Seems to connect and program the FPGA no probs now, onto finishing the rest of the machine I guess.
Cheers.
Russell.
