How to check what Kernel I've install? RTAI or PAE
17 Jul 2013 01:47 - 17 Jul 2013 01:48 #36723
by nquantum
Earlier Post I've got answer from: ArcEye
I've question. I think it better to post new topic.
Just want to know what Kernel I've install. Coz I've 1 x 4Gb ram to be install. How to check that I've done correctly rtai kernel? Coz if it chose pae kernel it won't work right?
Is it check by uname -a , uname -r ?
I've test by clean install latest imageCD from Linuxcnc download page into Mac Parallels app. It is virtual pc app and can give them resource
1. Try give it resource 4gb memory
2. Try give it resource 2gb memory
I've some screen capture here.
It does mean both already install in rtai kernel?
Also it does mean Live CD already fix it by always install rtai kernel even they found >2gb memory inside?
Thank you.
ps. I've just download Live CD and use it to install normally not change anything.
How to check what Kernel I've install? RTAI or PAE was created by nquantum
You may find it best to remove memory down to 2GB when installing, because the Ubuntu installer will try to install the pae kernel if it detects 4GB of memory
(unless this has been fixed in later Live CDs)
Thank you.
Last edit: 17 Jul 2013 01:48 by nquantum.
17 Jul 2013 16:08 #36740
by ArcEye
Replied by ArcEye on topic How to check what Kernel I've install? RTAI or PAE
Yes both show the 2.6.32-122-rtai kernel, so the rtai kernel was installed.
The previous problem was with the ubiquity installer, that may well have been fixed.
It only affects the install, it will not suddenly change kernels if you add more RAM, I just suggested that you do the install with just 2GB installed to be safe, then put the other stick back in after
The following user(s) said Thank You: nquantum
18 Jul 2013 20:27 #36775
by nquantum
Replied by nquantum on topic How to check what Kernel I've install? RTAI or PAE
Thank you.
