update my linuxcnc from release 2.4.6 to 2:5.2
- molle_tauch_66
27 Jul 2013 03:57 #37078
by molle_tauch_66
update my linuxcnc from release 2.4.6 to 2:5.2 was created by molle_tauch_66
HALLO
FIRST OFF ALL LET ME INTRODUCE TO YOU.
I AM LIVING IN GERMANY NEARBY REGENSBURG (IT IST ABOUT 90 MILE NORTH OF MUNICH)
I AM 47 YEAR OLD AND AN ABSOLUTLY NEWBIE IN LINUXCNC.
FOR ON YEAR AGO I AM STARTED MY INTEREST IN LINUXCNC WITH RELEASE 2.4.6
I HAVE INSTALLED IT FROM LIVE-CD WITH UBUNTU 10.04
NOW I HAVE UPDATED IT TO RELEASE 2.5.2!
I USED THE WIKI INSTRUKTION UNDER
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.5
BUT NOW WHEN I AM STARTING LINUXCNC I GET THIS ERRORMESSAGE AND LINUXCNC TERMINATES.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.2
Machine configuration directory is '/home/franz/linuxcnc/configs/hm2-servo-2'
Machine configuration file is '5i20.ini'
INIFILE=/home/franz/linuxcnc/configs/hm2-servo-2/5i20.ini
PARAMETER_FILE=hm2-servo.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=2587
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 No such device
hm2-servo.hal:46: exit value: 1
hm2-servo.hal:46: insmod failed, returned -1
See the output of 'dmesg' for more information.
2587
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 3041.187808] I-pipe: Domain RTAI registered.
[ 3041.187818] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 3041.187821] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 3041.187829] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3041.187832] PIPELINE layers:
[ 3041.187836] fb898e20 9ac15d93 RTAI 200
[ 3041.187840] c085cb20 0 Linux 100
[ 3041.217556] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3041.217699] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 3041.217706] RTAI[sched]: hard timer type/freq = APIC/8312480(Hz); default timing: periodic; linear timed lists.
[ 3041.217711] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2926243000 hz.
[ 3041.217714] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3041.217825] RTAI[usi]: enabled.
[ 3041.310910] RTAI[math]: loaded.
[ 3041.403323] hm2: loading Mesa HostMot2 driver version 0.15
[ 3041.408213] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3041.768087] hm2: unloading
[ 3041.830486] RTAI[math]: unloaded.
[ 3041.893613] SCHED releases registered named ALIEN RTGLBH
[ 3041.908940] RTAI[malloc]: unloaded.
[ 3042.008025] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3042.011892] I-pipe: Domain RTAI unregistered.
[ 3042.011903] RTAI[hal]: unmounted.
I DON'T NOW WHAT WHAT WAS GOING WRONG:
I STARTED THE SAMPLE CONFIGURATION
hm2-servo/5i20
linuxcnc 2.5.2 starts up,but after a few seconds it terminats with this error message.
when i am starting another sample configuration like
nist-lathe/inch
it starts correctly and do not terminate.
does anybody know what couses this error and how i can fix it.
i hope you can understand what i mean, because my english skills aren't the best!
thanks and greatings from germany
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.2
TASK=milltask
HALUI=
DISPLAY=axis
Cleanup done
2587
hm2-servo/5i20
nist-lathe/inch
27 Jul 2013 08:34 #37084
This is the problem, but I have no idea what the cause is.
You seem to be on the right version, and the right kernel. I wonder if the problem is not actually related to the upgrade?
Is it possible that the 8i20 was disturbed?
Replied by andypugh on topic update my linuxcnc from release 2.4.6 to 2:5.2
- molle_tauch_66
28 Jul 2013 04:33 #37107
by molle_tauch_66
Replied by molle_tauch_66 on topic update my linuxcnc from release 2.4.6 to 2:5.2
THANKS FOR YOUR ANSWER
NO I DONT THINK THE 8I20 IS DISTURBED, BECAUSE I DONT USE ANY MESA-CARD
I JUST RUN THE SAMPLE CONFIGURATION WITHOUT ANY MESACARD
THE HM2-SERVO SAMPLES.
IS hm2_pci.ko the problem
CAN IT BE A PROBLEM WITH THE HOSTMOD2 DRIVER?
28 Jul 2013 04:35 #37108
by BigJohnT
Replied by BigJohnT on topic update my linuxcnc from release 2.4.6 to 2:5.2
If it is a PCI card you have to have the card installed to run the configuration.
JT
JT
- molle_tauch_66
28 Jul 2013 21:53 #37166
by molle_tauch_66
YES OF COURSE JOHN
THANKS FOR YOUR HINT!
I HAVE NOT READ THE HINTS IN THE SAMPLE CONFIGURATIONS.
YES J HAVE TO INSTALL THE CARDS AND THE HOSTMOT2 DRIVER!
WHAT A BIG MISTAKE OF MINE!
Time to create page: 0.146 seconds
