Paroblem installing Master-sim from buildbot.
- Topic Author
- Thank you received: 1369
31 Jul 2013 21:00 #37294
Paroblem installing Master-sim from buildbot. was created by Todd Zuercher
Last night I was having trouble installing Master-sim from buildbot. It was saying that dependencies for libmodbus5 could not be installed. Is this something that is recently broken? I installed master a week or so ago and did not run into this. Any suggestions for an easy workarround (easier than downloading and compiling libmodbus seperately)
31 Jul 2013 21:21 #37296
by ArcEye
Replied by ArcEye on topic Paroblem installing Master-sim from buildbot.
Hi
Assuming you are talking about the master sim for lucid (latest linuxcnc-sim_2.6.0~pre0.4633.gb64082b_i386.deb )
it does list libmodbus5 in its dependencies
I just downloaded it with apt
If for some reason you can't you probably need to run apt-get update to refresh the lists
But it is attached in the zip, put it in /var/cache/apt/archives and run dpkg -i linuxcnc-sim_2.6.0~pre0.4633.gb64082b_i386.deb from there
The following user(s) said Thank You: Todd Zuercher
31 Jul 2013 21:40 - 31 Jul 2013 21:40 #37298
by cradek
Replied by cradek on topic Paroblem installing Master-sim from buildbot.
That package is found in the "base" component on linuxcnc.org. Add this to your sources.list:
deb http://linuxcnc.org lucid base
Last edit: 31 Jul 2013 21:40 by cradek. Reason: unfuck my url
Time to create page: 0.213 seconds
