2.5.3 to master-rt
25 Aug 2013 16:01 #38057
by billykid
2.5.3 to master-rt was created by billykid
hi
I installed LinuxCNC from last cd, added the repository buildbot
deb buildbot.linuxcnc.org/ lucid master-rt
deb-src buildbot.linuxcnc.org/ lucid master-rt
but when they do update manager names appear gray can not be selected.
I did upgrade to master-rt on that pc use with the machine without any problems.
I need this pc for testing.
Mauro
Mauro
25 Aug 2013 19:19 #38064
by ArcEye
Did you run apt-get update afterwards?
Replied by ArcEye on topic 2.5.3 to master-rt
25 Aug 2013 19:28 #38066
by billykid
Replied by billykid on topic 2.5.3 to master-rt
yes
but give this: Ign http:buildbot.linuxcnc.org lucid/master-rt packages
Ign http:buildbot.linuxcnc.org lucid/master-rt sources
Mauro
Mauro
25 Aug 2013 21:40 #38072
by ArcEye
I don't use the Update Manager and I am not on a Ubuntu machine presently.
If you want the latest binary of the master, just download
buildbot.linuxcnc.org/dists/lucid/master...82.gdd855f1_i386.deb
and install it (sudo dpkg -i linuxcnc_2.6.0~pre0.4682.gdd855f1_i386.deb)
25 Aug 2013 23:38 #38077
by billykid
I tried it and it installs with errors unfortunately.
I wanted to do the installation again with "ubuntu-10.04-linuxcnc3-i386.iso"
if you can explain the right steps.
Mauro
Mauro
26 Aug 2013 01:02 #38082
by ArcEye
The errors will tell you what is wrong, what were they? (exactly)
26 Aug 2013 02:57 #38089
by billykid
hardisk faulty we will replace it and let you know
Mauro
Mauro
Time to create page: 0.834 seconds
