enabling "lapic" boot option on 10.04 Live CD
01 Sep 2013 13:04 #38352
by ArcEye
Replied by ArcEye on topic enabling "lapic" boot option on 10.04 Live CD
I would use the uni-processor built kernel with 8.04
01 Sep 2013 19:14 #38361
by dbotos
Replied by dbotos on topic enabling "lapic" boot option on 10.04 Live CD
Sounds good - I'll give it a whirl.
Thanks,
David
Thanks,
David
15 Sep 2013 09:37 #38857
by dbotos
Got 8.04 installed and got my Edimax EW-7811Un wireless adapter working the other day thanks to this blog entry:
random tweaks - Edimax EW-7811Un
Got some more memory coming for this machine, but starting to mess with the SMI stuff in the meantime. Ran the lspci -vv command from a terminal window and it looks like it's rev 1 of ICH7.
15 Sep 2013 15:55 #38861
by ArcEye
Most of these adapters and dongles have a Realtek chip in them it seems.
Nice to know that this one works OK
Thats what I guessed from the B suffix, hopefully the smi module will sort it.
Don't forget to turn off power management, hyperthreading etc in BIOS as well, they will all affect latency
17 Sep 2013 02:00 - 17 Sep 2013 02:01 #38895
by dbotos
I followed steps 1-4 as described on the SMI page of the wiki, through editing /etc/emc2/rtapi.conf (I confirmed it was using that one by renaming it and LinuxCNC would not start).
wiki.linuxcnc.org/cgi-bin/wiki.pl?FixingSMIIssues
One thing I noticed when I was in that rtapi.conf file is that the "shm" module was not turned on. Should I enable that too? What does it do?
I will have to check in the BIOS and make sure all that other stuff is turned off...
Last edit: 17 Sep 2013 02:01 by dbotos.
17 Sep 2013 14:35 #38923
by ArcEye
rtai_shmem is part of realtime, it is not turned off, there is just not an explicit path for it, that is normal for the rtapi.conf, it does not show one for adeos either
The main thing is what is your latency like now?
18 Sep 2013 09:47 #38968
by dbotos
I turned off hyperthreading and processor power management in the BIOS and the current latency numbers are 28,061 and 39,156 ns with two windows of glxgears running for maybe 10 minutes while futzing around on the internet. I've got a 5i25 card from Mesa Electronics that I'm going to use to talk to the Gecko G540 motor controller.
Time to create page: 0.139 seconds
