Have some errors, but dont understand what Problem
06 Sep 2013 19:48 - 06 Sep 2013 19:51 #38516
by Cybermuk
Have some errors, but dont understand what Problem was created by Cybermuk
First at all please excause my bad english
So my Problem is:
After installing Ubuntu 10.04 and the available Updates, ive tried to install LinuxCNC whith the linuxcnc-install.sh
(I cannot use the live CD because the CPU Fan does´nt run... but on it the LinuxCNC works fine)
I´ve become this Failure:
So what must i have to do?
Thanks a lot...
So my Problem is:
Warning: Spoiler!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3
Machine configuration directory is '/home/michael/linuxcnc/configs/5axis'
Machine configuration file is '5axis.ini'
INIFILE=/home/michael/linuxcnc/configs/5axis/5axis.ini
PARAMETER_FILE=5axis.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Realtime system did not load
Killing task linuxcncsvr, PID=1610
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1610
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
/usr/bin/linuxcnc: Zeile 433: 1648 Speicherzugriffsfehler $HALCMD stop
Unloading hal components
/usr/bin/linuxcnc: Zeile 433: 1649 Speicherzugriffsfehler $HALCMD unload all
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000002ffd0000 (usable)
[ 0.000000] BIOS-e820: 000000002ffd0000 - 000000002fff0c00 (reserved)
[ 0.000000] BIOS-e820: 000000002fff0c00 - 000000002fffc000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000002fffc000 - 0000000030000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x2ffd0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 020000000 mask FF0000000 write-back
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000002ffd0000 (usable)
[ 0.000000] modified: 000000002ffd0000 - 000000002fff0c00 (reserved)
[ 0.000000] modified: 000000002fff0c00 - 000000002fffc000 (ACPI NVS)
[ 0.000000] modified: 000000002fffc000 - 0000000030000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000002ffd0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 002fc00000 page 2M
[ 0.000000] 002fc00000 - 002ffd0000 page 4k
[ 0.000000] kernel direct mapping tables up to 2ffd0000 @ 7000-c000
[ 0.000000] RAMDISK: 23867000 - 2401b51b
[ 0.000000] ACPI: RSDP 000f6a80 00014 (v00 COMPAQ)
[ 0.000000] ACPI: RSDT 2fff0c84 0002C (v01 COMPAQ CPQ00B7 09120320 CPQ 00000001)
[ 0.000000] ACPI: FACP 2fff0c00 00084 (v02 COMPAQ CPQ00B7 00000002 CPQ 00000001)
[ 0.000000] ACPI: DSDT 2fff0cb0 05FAF (v01 COMPAQ EVON610C 00010000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 2fffbe80 00040
[ 0.000000] ACPI: SSDT 2fff6c5f 0010E (v01 COMPAQ CPQGysr 00001001 MSFT 0100000E)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 767MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 2ffd0000
[ 0.000000] low ram: 0 - 2ffd0000
[ 0.000000] node 0 low ram: 00000000 - 2ffd0000
[ 0.000000] node 0 bootmap 00008000 - 0000dffc
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 002ffd0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [0023867000 - 002401b51b] RAMDISK ==> [0023867000 - 002401b51b]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b4128] BRK ==> [00008b1000 - 00008b4128]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000e000] BOOTMAP ==> [0000008000 - 000000e000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0002ffd0
[ 0.000000] HighMem 0x0002ffd0 -> 0x0002ffd0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0002ffd0
[ 0.000000] On node 0 totalpages: 196459
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 190960 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 30000000 (gap: 30000000:d0000000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 194923
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=B220DDD020DD9C23 loop=/ubuntu/disks/root.disk ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 3931200 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 758920k/786240k available (4539k kernel code, 26692k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf07d0000 - 0xff7fe000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xeffd0000 ( 767 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1993.715 MHz processor.
[ 0.008016] Calibrating delay loop (skipped), value calculated using timer frequency.. 3987.43 BogoMIPS (lpj=7974860)
[ 0.008058] Security Framework initialized
[ 0.008112] AppArmor: AppArmor initialized
[ 0.008127] Mount-cache hash table entries: 512
[ 0.008459] Initializing cgroup subsys ns
[ 0.008467] Initializing cgroup subsys cpuacct
[ 0.008478] Initializing cgroup subsys memory
[ 0.008506] Initializing cgroup subsys devices
[ 0.008521] Initializing cgroup subsys freezer
[ 0.008526] Initializing cgroup subsys net_cls
[ 0.008586] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.008594] CPU: L2 cache: 512K
[ 0.008599] CPU: Hyper-Threading is disabled
[ 0.008616] mce: CPU supports 4 MCE banks
[ 0.008653] Performance Events: no PMU driver, software events only.
[ 0.008667] Checking 'hlt' instruction... OK.
[ 0.026090] SMP alternatives: switching to UP code
[ 0.048871] Freeing SMP alternatives: 31k freed
[ 0.048917] ACPI: Core revision 20090903
[ 0.072734] ACPI: setting ELCR to 0200 (from 0c00)
[ 0.076042] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.076063] ftrace: allocating 21003 entries in 42 pages
[ 0.094877] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.094884] weird, boot CPU (#0) not listed by the BIOS.
[ 0.094887] SMP motherboard not detected.
[ 0.094891] Local APIC not detected. Using dummy APIC emulation.
[ 0.094894] SMP disabled
[ 0.095219] Brought up 1 CPUs
[ 0.095225] Total of 1 processors activated (3987.43 BogoMIPS).
[ 0.095581] CPU0 attaching NULL sched-domain.
[ 0.095823] devtmpfs: initialized
[ 0.096440] regulator: core version 0.5
[ 0.096524] NET: Registered protocol family 16
[ 0.096736] EISA bus registered
[ 0.096750] ACPI: bus type pci registered
[ 0.098765] PCI: PCI BIOS revision 2.10 entry at 0xf03a2, last bus=4
[ 0.098769] PCI: Using configuration type 1 for base access
[ 0.100213] bio: create slab <bio-0> at 0
[ 0.101536] ACPI: EC: Look up EC in DSDT
[ 0.125262] ACPI: Interpreter enabled
[ 0.125269] ACPI: (supports S0 S5)
[ 0.125288] ACPI: Using PIC for interrupt routing
[ 0.142289] ACPI: Power Resource [C15D] (on)
[ 0.142421] ACPI: Power Resource [C171] (on)
[ 0.142550] ACPI: Power Resource [C175] (on)
[ 0.142679] ACPI: Power Resource [C178] (on)
[ 0.142739] ACPI: Power Resource [C181] (on)
[ 0.142857] ACPI: Power Resource [C1EB] (off)
[ 0.142969] ACPI: Power Resource [C1EC] (off)
[ 0.143080] ACPI: Power Resource [C1ED] (off)
[ 0.143405] ACPI: No dock devices found.
[ 0.150878] ACPI: PCI Root Bridge [C045] (0000:00)
[ 0.150957] pci 0000:00:00.0: reg 10 32bit mmio pref: [0x60000000-0x6fffffff]
[ 0.151201] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
[ 0.151209] pci 0000:00:1f.0: quirk: region 1100-113f claimed by ICH4 GPIO
[ 0.151247] pci 0000:00:1f.1: reg 10 io port: [0x00-0x07]
[ 0.151258] pci 0000:00:1f.1: reg 14 io port: [0x00-0x03]
[ 0.151269] pci 0000:00:1f.1: reg 18 io port: [0x00-0x07]
[ 0.151279] pci 0000:00:1f.1: reg 1c io port: [0x00-0x03]
[ 0.151290] pci 0000:00:1f.1: reg 20 io port: [0x4440-0x444f]
[ 0.151301] pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
[ 0.151352] pci 0000:00:1f.5: reg 10 io port: [0x4000-0x40ff]
[ 0.151363] pci 0000:00:1f.5: reg 14 io port: [0x4400-0x443f]
[ 0.151461] pci 0000:01:00.0: reg 10 32bit mmio pref: [0x48000000-0x4fffffff]
[ 0.151473] pci 0000:01:00.0: reg 14 io port: [0x3000-0x30ff]
[ 0.151482] pci 0000:01:00.0: reg 18 32bit mmio: [0x40400000-0x4040ffff]
[ 0.151505] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.151534] pci 0000:01:00.0: supports D1 D2
[ 0.151587] pci 0000:00:01.0: bridge io port: [0x3000-0x3fff]
[ 0.151593] pci 0000:00:01.0: bridge 32bit mmio: [0x40400000-0x404fffff]
[ 0.151600] pci 0000:00:01.0: bridge 32bit mmio pref: [0x48000000-0x4fffffff]
[ 0.151657] pci 0000:02:04.0: reg 10 32bit mmio: [0x40280000-0x402800ff]
[ 0.151668] pci 0000:02:04.0: reg 14 io port: [0x2440-0x2447]
[ 0.151678] pci 0000:02:04.0: reg 18 io port: [0x2000-0x20ff]
[ 0.151729] pci 0000:02:04.0: supports D2
[ 0.151733] pci 0000:02:04.0: PME# supported from D2 D3hot D3cold
[ 0.151740] pci 0000:02:04.0: PME# disabled
[ 0.151790] pci 0000:02:06.0: reg 10 32bit mmio: [0x40000000-0x40000fff]
[ 0.151818] pci 0000:02:06.0: supports D1 D2
[ 0.151822] pci 0000:02:06.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.151828] pci 0000:02:06.0: PME# disabled
[ 0.151876] pci 0000:02:06.1: reg 10 32bit mmio: [0x40080000-0x40080fff]
[ 0.151904] pci 0000:02:06.1: supports D1 D2
[ 0.151907] pci 0000:02:06.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.151914] pci 0000:02:06.1: PME# disabled
[ 0.151971] pci 0000:02:08.0: reg 10 32bit mmio: [0x40100000-0x40100fff]
[ 0.151982] pci 0000:02:08.0: reg 14 io port: [0x2400-0x243f]
[ 0.152053] pci 0000:02:08.0: supports D1 D2
[ 0.152058] pci 0000:02:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.152065] pci 0000:02:08.0: PME# disabled
[ 0.152120] pci 0000:02:0e.0: reg 10 32bit mmio: [0x40180000-0x40180fff]
[ 0.152181] pci 0000:02:0e.0: supports D1 D2
[ 0.152185] pci 0000:02:0e.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.152192] pci 0000:02:0e.0: PME# disabled
[ 0.152238] pci 0000:02:0e.1: reg 10 32bit mmio: [0x40200000-0x40200fff]
[ 0.152300] pci 0000:02:0e.1: supports D1 D2
[ 0.152305] pci 0000:02:0e.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.152312] pci 0000:02:0e.1: PME# disabled
[ 0.152359] pci 0000:02:0e.2: reg 10 32bit mmio: [0x40300000-0x403000ff]
[ 0.152420] pci 0000:02:0e.2: supports D1 D2
[ 0.152424] pci 0000:02:0e.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.152431] pci 0000:02:0e.2: PME# disabled
[ 0.152477] pci 0000:00:1e.0: transparent bridge
[ 0.152485] pci 0000:00:1e.0: bridge io port: [0x2000-0x2fff]
[ 0.152492] pci 0000:00:1e.0: bridge 32bit mmio: [0x40000000-0x403fffff]
[ 0.152554] pci_bus 0000:00: on NUMA node 0
[ 0.152564] ACPI: PCI Interrupt Routing Table [\_SB_.C045._PRT]
[ 0.152614] ACPI: PCI Interrupt Routing Table [\_SB_.C045.C046._PRT]
[ 0.152657] ACPI: PCI Interrupt Routing Table [\_SB_.C045.C058._PRT]
[ 0.162237] ACPI: PCI Interrupt Link [C0C0] (IRQs 5 10 *11)
[ 0.162544] ACPI: PCI Interrupt Link [C0C1] (IRQs 5 10 *11)
[ 0.162828] ACPI: PCI Interrupt Link [C0C2] (IRQs 5 10 11) *0, disabled.
[ 0.163131] ACPI: PCI Interrupt Link [C0C3] (IRQs 5 10 *11)
[ 0.163433] ACPI: PCI Interrupt Link [C0C4] (IRQs 5 *10 11)
[ 0.163716] ACPI: PCI Interrupt Link [C0C5] (IRQs) *0, disabled.
[ 0.164025] ACPI: PCI Interrupt Link [C0C6] (IRQs) *0, disabled.
[ 0.164309] ACPI: PCI Interrupt Link [C0C7] (IRQs) *0, disabled.
[ 0.164573] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.164584] vgaarb: loaded
[ 0.164835] SCSI subsystem initialized
[ 0.164975] libata version 3.00 loaded.
[ 0.165102] usbcore: registered new interface driver usbfs
[ 0.165126] usbcore: registered new interface driver hub
[ 0.165173] usbcore: registered new device driver usb
[ 0.165428] ACPI: WMI: Mapper loaded
[ 0.165433] PCI: Using ACPI for IRQ routing
[ 0.165661] NetLabel: Initializing
[ 0.165666] NetLabel: domain hash size = 128
[ 0.165669] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.165692] NetLabel: unlabeled traffic allowed by default
[ 0.165753] Switching to clocksource tsc
[ 0.168001] AppArmor: AppArmor Filesystem Enabled
[ 0.168001] pnp: PnP ACPI init
[ 0.168001] ACPI: bus type pnp registered
[ 0.190498] pnp: PnP ACPI: found 14 devices
[ 0.190503] ACPI: ACPI bus type pnp unregistered
[ 0.190511] PnPBIOS: Disabled by ACPI PNP
[ 0.190532] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.190538] system 00:00: iomem range 0xe0000-0xfffff could not be reserved
[ 0.190545] system 00:00: iomem range 0x100000-0x2fffffff could not be reserved
[ 0.190563] system 00:0c: ioport range 0x140-0x14f has been reserved
[ 0.190569] system 00:0c: iomem range 0xffb00000-0xffbfffff has been reserved
[ 0.190576] system 00:0c: iomem range 0xfff00000-0xffffffff has been reserved
[ 0.190587] system 00:0d: ioport range 0x4d0-0x4d1 has been reserved
[ 0.190593] system 00:0d: ioport range 0x1000-0x107f has been reserved
[ 0.190599] system 00:0d: ioport range 0x1100-0x113f has been reserved
[ 0.190605] system 00:0d: ioport range 0x1200-0x121f has been reserved
[ 0.190610] system 00:0d: iomem range 0xffc00000-0xffc003ff has been reserved
[ 0.225483] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.225490] pci 0000:00:01.0: IO window: 0x3000-0x3fff
[ 0.225497] pci 0000:00:01.0: MEM window: 0x40400000-0x404fffff
[ 0.225504] pci 0000:00:01.0: PREFETCH window: 0x48000000-0x4fffffff
[ 0.225522] pci 0000:02:06.0: CardBus bridge, secondary bus 0000:03
[ 0.225526] pci 0000:02:06.0: IO window: 0x002800-0x0028ff
[ 0.225533] pci 0000:02:06.0: IO window: 0x002c00-0x002cff
[ 0.225541] pci 0000:02:06.0: PREFETCH window: 0x30000000-0x33ffffff
[ 0.225548] pci 0000:02:06.0: MEM window: 0x3c000000-0x3fffffff
[ 0.225555] pci 0000:02:06.1: CardBus bridge, secondary bus 0000:04
[ 0.225560] pci 0000:02:06.1: IO window: 0x001400-0x0014ff
[ 0.225567] pci 0000:02:06.1: IO window: 0x001800-0x0018ff
[ 0.225574] pci 0000:02:06.1: PREFETCH window: 0x34000000-0x37ffffff
[ 0.225581] pci 0000:02:06.1: MEM window: 0x44000000-0x47ffffff
[ 0.225588] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.225594] pci 0000:00:1e.0: IO window: 0x2000-0x2fff
[ 0.225603] pci 0000:00:1e.0: MEM window: 0x40000000-0x403fffff
[ 0.225610] pci 0000:00:1e.0: PREFETCH window: 0x30000000-0x37ffffff
[ 0.225637] pci 0000:00:1e.0: setting latency timer to 64
[ 0.226090] ACPI: PCI Interrupt Link [C0C3] enabled at IRQ 11
[ 0.226095] PCI: setting IRQ 11 as level-triggered
[ 0.226103] pci 0000:02:06.0: PCI INT A -> Link[C0C3] -> GSI 11 (level, low) -> IRQ 11
[ 0.226122] pci 0000:02:06.1: PCI INT A -> Link[C0C3] -> GSI 11 (level, low) -> IRQ 11
[ 0.226132] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.226137] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.226142] pci_bus 0000:01: resource 0 io: [0x3000-0x3fff]
[ 0.226147] pci_bus 0000:01: resource 1 mem: [0x40400000-0x404fffff]
[ 0.226151] pci_bus 0000:01: resource 2 pref mem [0x48000000-0x4fffffff]
[ 0.226186] pci_bus 0000:02: resource 0 io: [0x2000-0x2fff]
[ 0.226191] pci_bus 0000:02: resource 1 mem: [0x40000000-0x403fffff]
[ 0.226196] pci_bus 0000:02: resource 2 pref mem [0x30000000-0x37ffffff]
[ 0.226201] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.226205] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.226210] pci_bus 0000:03: resource 0 io: [0x2800-0x28ff]
[ 0.226214] pci_bus 0000:03: resource 1 io: [0x2c00-0x2cff]
[ 0.226219] pci_bus 0000:03: resource 2 pref mem [0x30000000-0x33ffffff]
[ 0.226224] pci_bus 0000:03: resource 3 mem: [0x3c000000-0x3fffffff]
[ 0.226228] pci_bus 0000:04: resource 0 io: [0x1400-0x14ff]
[ 0.226233] pci_bus 0000:04: resource 1 io: [0x1800-0x18ff]
[ 0.226237] pci_bus 0000:04: resource 2 pref mem [0x34000000-0x37ffffff]
[ 0.226242] pci_bus 0000:04: resource 3 mem: [0x44000000-0x47ffffff]
[ 0.226304] NET: Registered protocol family 2
[ 0.226471] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.227112] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.228551] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.229479] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.229485] TCP reno registered
[ 0.229721] NET: Registered protocol family 1
[ 0.229776] pci 0000:01:00.0: Boot video device
[ 0.229827] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.230296] Scanning for low memory corruption every 60 seconds
[ 0.230479] audit: initializing netlink socket (disabled)
[ 0.230500] type=2000 audit(1378477016.230:1): initialized
[ 0.240243] Trying to unpack rootfs image as initramfs...
[ 0.250614] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.256707] VFS: Disk quotas dquot_6.5.2
[ 0.256827] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.257869] fuse init (API version 7.13)
[ 0.258020] msgmni has been set to 1482
[ 0.262937] alg: No test for stdrng (krng)
[ 0.263096] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.263103] io scheduler noop registered
[ 0.263108] io scheduler anticipatory registered
[ 0.263111] io scheduler deadline registered
[ 0.263181] io scheduler cfq registered (default)
[ 0.263379] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.263423] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.263602] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.263617] ACPI: Sleep Button [C19B]
[ 0.263699] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.263880] ACPI: Lid Switch [C19C]
[ 0.263971] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.263976] ACPI: Power Button [PWRF]
[ 0.266685] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.266813] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.266982] serial8250: ttyS2 at I/O 0x3e8 (irq = 4) is a 16550A
[ 0.267301] 00:02: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.269242] brd: module loaded
[ 0.270043] loop: module loaded
[ 0.270261] isapnp: Scanning for PnP cards...
[ 0.282683] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.282913] ata_piix 0000:00:1f.1: version 2.13
[ 0.282937] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 0.283453] ACPI: PCI Interrupt Link [C0C2] enabled at IRQ 10
[ 0.283459] PCI: setting IRQ 10 as level-triggered
[ 0.283466] ata_piix 0000:00:1f.1: PCI INT A -> Link[C0C2] -> GSI 10 (level, low) -> IRQ 10
[ 0.283551] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.327204] scsi0 : ata_piix
[ 0.327375] scsi1 : ata_piix
[ 0.328859] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x4440 irq 14
[ 0.328865] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x4448 irq 15
[ 0.329540] Fixed MDIO Bus: probed
[ 0.329610] PPP generic driver version 2.4.2
[ 0.329723] tun: Universal TUN/TAP device driver, 1.6
[ 0.329727] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.329892] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.330433] ACPI: PCI Interrupt Link [C0C4] enabled at IRQ 10
[ 0.330442] ehci_hcd 0000:02:0e.2: PCI INT C -> Link[C0C4] -> GSI 10 (level, low) -> IRQ 10
[ 0.330485] ehci_hcd 0000:02:0e.2: EHCI Host Controller
[ 0.330561] ehci_hcd 0000:02:0e.2: new USB bus registered, assigned bus number 1
[ 0.354548] ehci_hcd 0000:02:0e.2: irq 10, io mem 0x40300000
[ 0.366251] ehci_hcd 0000:02:0e.2: USB 2.0 started, EHCI 0.95
[ 0.366486] usb usb1: configuration #1 chosen from 1 choice
[ 0.366541] hub 1-0:1.0: USB hub found
[ 0.366565] hub 1-0:1.0: 5 ports detected
[ 0.366667] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.366716] ohci_hcd 0000:02:0e.0: PCI INT A -> Link[C0C4] -> GSI 10 (level, low) -> IRQ 10
[ 0.366748] ohci_hcd 0000:02:0e.0: OHCI Host Controller
[ 0.366818] ohci_hcd 0000:02:0e.0: new USB bus registered, assigned bus number 2
[ 0.366850] ohci_hcd 0000:02:0e.0: irq 10, io mem 0x40180000
[ 0.935244] ata2.00: ATAPI: Optiarc DVD RW AD-7543A, 1-00, max UDMA/33
[ 0.935421] ata1.00: ATA-5: HITACHI_DK23EA-30, 00K4A0A2, max UDMA/100
[ 0.935427] ata1.00: 58605120 sectors, multi 16: LBA
[ 0.943045] ata2.00: configured for UDMA/33
[ 0.943291] ata1.00: configured for UDMA/100
[ 1.448110] isapnp: No Plug & Play device found
[ 1.448367] scsi 0:0:0:0: Direct-Access ATA HITACHI_DK23EA-3 00K4 PQ: 0 ANSI: 5
[ 1.448660] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.448922] sd 0:0:0:0: [sda] 58605120 512-byte logical blocks: (30.0 GB/27.9 GiB)
[ 1.449018] sd 0:0:0:0: [sda] Write Protect is off
[ 1.449024] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.449072] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.449512] sda:
[ 1.450453] scsi 1:0:0:0: CD-ROM Optiarc DVD RW AD-7543A 1-00 PQ: 0 ANSI: 5
[ 1.455561] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.455572] Uniform CD-ROM driver Revision: 3.20
[ 1.455788] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.455917] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.472880] Freeing initrd memory: 7889k freed
[ 1.487816] sda1
[ 1.488507] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.488721] usb usb2: configuration #1 chosen from 1 choice
[ 1.488773] hub 2-0:1.0: USB hub found
[ 1.488797] hub 2-0:1.0: 3 ports detected
[ 1.488894] ohci_hcd 0000:02:0e.1: PCI INT B -> Link[C0C4] -> GSI 10 (level, low) -> IRQ 10
[ 1.488925] ohci_hcd 0000:02:0e.1: OHCI Host Controller
[ 1.489001] ohci_hcd 0000:02:0e.1: new USB bus registered, assigned bus number 3
[ 1.489032] ohci_hcd 0000:02:0e.1: irq 10, io mem 0x40200000
[ 2.050223] usb usb3: configuration #1 chosen from 1 choice
[ 2.050270] hub 3-0:1.0: USB hub found
[ 2.050291] hub 3-0:1.0: 2 ports detected
[ 2.050366] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.050535] PNP: PS/2 Controller [PNP0303:C17E,PNP0f13:C17F] at 0x60,0x64 irq 1,12
[ 2.051917] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 2.052671] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.052684] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 2.052732] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 2.052774] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 2.052816] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 2.053041] mice: PS/2 mouse device common for all mice
[ 2.053275] rtc_cmos 00:09: RTC can wake from S4
[ 2.053355] rtc_cmos 00:09: rtc core: registered rtc_cmos as rtc0
[ 2.053379] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 2.053586] device-mapper: uevent: version 1.0.3
[ 2.053787] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 2.053880] device-mapper: multipath: version 1.1.0 loaded
[ 2.053886] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 2.054079] EISA: Probing bus 0 at eisa.0
[ 2.054090] Cannot allocate resource for EISA slot 1
[ 2.054095] Cannot allocate resource for EISA slot 2
[ 2.054099] Cannot allocate resource for EISA slot 3
[ 2.054103] Cannot allocate resource for EISA slot 4
[ 2.054120] EISA: Detected 0 cards.
[ 2.054125] cpuidle: using governor ladder
[ 2.054129] cpuidle: using governor menu
[ 2.054830] TCP cubic registered
[ 2.055043] NET: Registered protocol family 10
[ 2.055730] lo: Disabled Privacy Extensions
[ 2.056274] NET: Registered protocol family 17
[ 2.056330] Using IPI No-Shortcut mode
[ 2.056519] registered taskstats version 1
[ 2.056935] rtc_cmos 00:09: setting system clock to 2013-09-06 14:16:58 UTC (1378477018)
[ 2.056942] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 2.056946] EDD information not available.
[ 2.057020] Freeing unused kernel memory: 620k freed
[ 2.058073] Write protecting the kernel text: 4540k
[ 2.058110] Write protecting the kernel read-only data: 1668k
[ 2.074949] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 2.097784] udev: starting version 151
[ 2.599435] Floppy drive(s): fd0 is 1.44M
[ 2.615861] FDC 0 is a post-1991 82077
[ 2.618865] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 2.618872] e100: Copyright(c) 1999-2006 Intel Corporation
[ 2.618950] e100 0000:02:08.0: PCI INT A -> Link[C0C4] -> GSI 10 (level, low) -> IRQ 10
[ 2.709760] e100 0000:02:08.0: PME# disabled
[ 2.741236] e100: eth0: e100_probe: addr 0x40100000, irq 10, MAC addr 00:02:a5:c2:5d:d1
[ 3.044563] EXT4-fs (loop0): INFO: recovery required on readonly filesystem
[ 3.044574] EXT4-fs (loop0): write access will be enabled during recovery
[ 4.181476] EXT4-fs (loop0): orphan cleanup on readonly fs
[ 4.181496] EXT4-fs (loop0): ext4_orphan_cleanup: deleting unreferenced inode 133511
[ 4.181649] EXT4-fs (loop0): ext4_orphan_cleanup: deleting unreferenced inode 2031
[ 4.181718] EXT4-fs (loop0): ext4_orphan_cleanup: deleting unreferenced inode 2030
[ 4.181778] EXT4-fs (loop0): 3 orphan inodes deleted
[ 4.181785] EXT4-fs (loop0): recovery complete
[ 4.183923] EXT4-fs (loop0): mounted filesystem with ordered data mode
[ 28.735292] udev: starting version 151
[ 29.087744] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 29.239578] intel_rng: FWH not detected
[ 29.438028] Linux agpgart interface v0.103
[ 29.589517] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[ 29.719963] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0x60000000
[ 29.730187] lp: driver loaded but no devices found
[ 29.736396] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:00/LNXVIDEO:00/input/input5
[ 29.736645] ACPI: Video Device [C0CE] (multi-head: yes rom: no post: no)
[ 29.835123] parport_pc 00:05: reported by Plug and Play ACPI
[ 29.835186] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 29.945524] lp0: using parport0 (interrupt-driven).
[ 29.950801] irda_init()
[ 29.950829] NET: Registered protocol family 23
[ 29.985573] ppdev: user-space parallel port driver
[ 30.272855] Synaptics Touchpad, model: 1, fw: 5.8, id: 0x9b48b1, caps: 0x884793/0x0
[ 30.272867] serio: Synaptics pass-through port at isa0060/serio4/input0
[ 30.330234] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input6
[ 30.332848] found SMC SuperIO Chip (devid=0x0e rev=01 base=0x002e): LPC47N252
[ 30.332875] smsc_ircc_present: can't get sir_base of 0x3e8
[ 30.436423] yenta_cardbus 0000:02:06.0: CardBus bridge found [0e11:00b7]
[ 30.436451] yenta_cardbus 0000:02:06.0: Enabling burst memory read transactions
[ 30.436459] yenta_cardbus 0000:02:06.0: Using CSCINT to route CSC interrupts to PCI
[ 30.436463] yenta_cardbus 0000:02:06.0: Routing CardBus interrupts to PCI
[ 30.436471] yenta_cardbus 0000:02:06.0: TI: mfunc 0x01001002, devctl 0x64
[ 30.668387] yenta_cardbus 0000:02:06.0: ISA IRQ mask 0x0038, PCI irq 11
[ 30.668396] yenta_cardbus 0000:02:06.0: Socket status: 30000006
[ 30.668409] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge I/O window: 0x2000 - 0x2fff
[ 30.668416] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x2000-0x2fff: clean.
[ 30.668840] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge Memory window: 0x40000000 - 0x403fffff
[ 30.668847] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge Memory window: 0x30000000 - 0x37ffffff
[ 30.669474] yenta_cardbus 0000:02:06.1: CardBus bridge found [0e11:00b7]
[ 30.669499] yenta_cardbus 0000:02:06.1: Using CSCINT to route CSC interrupts to PCI
[ 30.669503] yenta_cardbus 0000:02:06.1: Routing CardBus interrupts to PCI
[ 30.669511] yenta_cardbus 0000:02:06.1: TI: mfunc 0x01001002, devctl 0x64
[ 30.815718] type=1505 audit(1378469847.255:2): operation="profile_load" pid=603 name="/sbin/dhclient3"
[ 30.818177] type=1505 audit(1378469847.259:3): operation="profile_replace" pid=608 name="/sbin/dhclient3"
[ 30.819026] type=1505 audit(1378469847.259:4): operation="profile_load" pid=608 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 30.819493] type=1505 audit(1378469847.259:5): operation="profile_load" pid=608 name="/usr/lib/connman/scripts/dhclient-script"
[ 30.832742] type=1505 audit(1378469847.275:6): operation="profile_replace" pid=603 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 30.833226] type=1505 audit(1378469847.275:7): operation="profile_replace" pid=603 name="/usr/lib/connman/scripts/dhclient-script"
[ 30.858337] [drm] Initialized drm 1.1.0 20060810
[ 30.924423] yenta_cardbus 0000:02:06.1: ISA IRQ mask 0x0038, PCI irq 11
[ 30.924432] yenta_cardbus 0000:02:06.1: Socket status: 30000006
[ 30.924440] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #04 to #07
[ 30.924459] yenta_cardbus 0000:02:06.1: pcmcia: parent PCI bridge I/O window: 0x2000 - 0x2fff
[ 30.924467] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x2000-0x2fff: clean.
[ 30.925212] yenta_cardbus 0000:02:06.1: pcmcia: parent PCI bridge Memory window: 0x40000000 - 0x403fffff
[ 30.925219] yenta_cardbus 0000:02:06.1: pcmcia: parent PCI bridge Memory window: 0x30000000 - 0x37ffffff
[ 31.469164] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3af: excluding 0x100-0x107
[ 31.470542] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x3e0-0x4ff: clean.
[ 31.471245] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x820-0x8ff: clean.
[ 31.471729] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcf7: clean.
[ 31.472916] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
[ 31.559205] [drm] radeon defaulting to kernel modesetting.
[ 31.559215] [drm] radeon kernel modesetting enabled.
[ 31.559804] ACPI: PCI Interrupt Link [C0C0] enabled at IRQ 11
[ 31.559813] radeon 0000:01:00.0: PCI INT A -> Link[C0C0] -> GSI 11 (level, low) -> IRQ 11
[ 31.569362] [drm] radeon: Initializing kernel modesetting.
[ 31.570516] [drm] register mmio base: 0x40400000
[ 31.570521] [drm] register mmio size: 65536
[ 31.570895] [drm] GPU reset succeed (RBBM_STATUS=0x00000140)
[ 31.570927] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
[ 31.570952] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 31.570975] radeon 0000:01:00.0: putting AGP V2 device into 4x mode
[ 31.571033] [drm] radeon: VRAM 64M
[ 31.571036] [drm] radeon: VRAM from 0x00000000 to 0x03FFFFFF
[ 31.571040] [drm] radeon: GTT 256M
[ 31.571043] [drm] radeon: GTT from 0x60000000 to 0x6FFFFFFF
[ 31.571077] [drm] radeon: irq initialized.
[ 31.571211] [drm] Detected VRAM RAM=64M, BAR=128M
[ 31.571218] [drm] RAM width 64bits DDR
[ 31.572606] [TTM] Zone kernel: Available graphics memory: 383842 kiB.
[ 31.572636] [drm] radeon: 32M of VRAM memory ready
[ 31.572640] [drm] radeon: 256M of GTT memory ready.
[ 31.572898] [drm] radeon: cp idle (0x00008383)
[ 31.573073] [drm] Loading R100 Microcode
[ 31.573589] platform radeon_cp.0: firmware: requesting radeon/R100_cp.bin
[ 31.586700] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: excluding 0x100-0x107
[ 31.587959] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[ 31.591207] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 31.591687] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 31.592482] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 31.645602] [drm] radeon: ring at 0x0000000060000000
[ 31.645628] [drm] ring test succeeded in 1 usecs
[ 31.659184] [drm] radeon: ib pool ready.
[ 31.659321] [drm] ib test succeeded in 0 usecs
[ 31.661719] [drm] DFP table revision: 2
[ 31.664960] [drm] Panel ID String: AUO B141XG03
[ 31.664967] [drm] Panel Size 1024x768
[ 31.668132] [drm] Default TV standard: NTSC
[ 31.668138] [drm] 27.000000000 MHz TV ref clk
[ 31.668142] [drm] No TV DAC info found in BIOS
[ 31.668150] [drm] Default TV standard: NTSC
[ 31.668153] [drm] 27.000000000 MHz TV ref clk
[ 31.668390] [drm] Radeon Display Connectors
[ 31.668395] [drm] Connector 0:
[ 31.668398] [drm] VGA
[ 31.668403] [drm] DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[ 31.668406] [drm] Encoders:
[ 31.668410] [drm] CRT1: INTERNAL_DAC1
[ 31.668413] [drm] Connector 1:
[ 31.668416] [drm] DVI-D
[ 31.668418] [drm] HPD1
[ 31.668423] [drm] DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[ 31.668426] [drm] Encoders:
[ 31.668429] [drm] DFP1: INTERNAL_TMDS1
[ 31.668432] [drm] Connector 2:
[ 31.668434] [drm] LVDS
[ 31.668438] [drm] DDC: 0x6c 0x6c 0x6c 0x6c 0x6c 0x6c 0x6c 0x6c
[ 31.668441] [drm] Encoders:
[ 31.668444] [drm] LCD1: INTERNAL_LVDS
[ 31.668447] [drm] Connector 3:
[ 31.668450] [drm] S-video
[ 31.668453] [drm] Encoders:
[ 31.668456] [drm] TV1: INTERNAL_DAC2
[ 31.781221] ACPI: PCI Interrupt Link [C0C1] enabled at IRQ 11
[ 31.781231] Intel ICH 0000:00:1f.5: PCI INT B -> Link[C0C1] -> GSI 11 (level, low) -> IRQ 11
[ 31.781257] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 31.890568] [drm] fb mappable at 0x48040000
[ 31.890573] [drm] vram apper at 0x48000000
[ 31.890576] [drm] size 786432
[ 31.890579] [drm] fb depth is 8
[ 31.890583] [drm] pitch is 1024
[ 31.895679] fb0: radeondrmfb frame buffer device
[ 31.895685] registered panic notifier
[ 31.895698] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[ 31.942870] vga16fb: initializing
[ 31.942883] vga16fb: mapped to 0xc00a0000
[ 31.942892] vga16fb: not registering due to another framebuffer present
[ 32.104306] Console: switching to colour frame buffer device 128x48
[ 32.460043] intel8x0_measure_ac97_clock: measured 54229 usecs (2606 samples)
[ 32.460051] intel8x0: clocking to 48000
[ 33.703593] psmouse serio5: ID: 10 00 64
[ 34.061589] Adding 261112k swap on /host/ubuntu/disks/swap.disk. Priority:-1 extents:8 across:552620k
[ 34.973339] type=1505 audit(1378469851.415:8): operation="profile_load" pid=872 name="/usr/share/gdm/guest-session/Xsession"
[ 34.982627] type=1505 audit(1378469851.423:9): operation="profile_replace" pid=877 name="/sbin/dhclient3"
[ 34.983494] type=1505 audit(1378469851.423:10): operation="profile_replace" pid=877 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 34.983969] type=1505 audit(1378469851.423:11): operation="profile_replace" pid=877 name="/usr/lib/connman/scripts/dhclient-script"
[ 35.144211] e100: eth0 NIC Link is Up 100 Mbps Full Duplex
[ 35.145497] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 35.145831] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 36.957946] __ratelimit: 6 callbacks suppressed
[ 36.957954] type=1505 audit(1378469853.399:14): operation="profile_load" pid=881 name="/usr/bin/evince-thumbnailer"
[ 37.023615] type=1505 audit(1378469853.463:15): operation="profile_load" pid=918 name="/usr/lib/cups/backend/cups-pdf"
[ 37.024680] type=1505 audit(1378469853.467:16): operation="profile_load" pid=918 name="/usr/sbin/cupsd"
[ 37.037567] type=1505 audit(1378469853.479:17): operation="profile_load" pid=919 name="/usr/sbin/tcpdump"
[ 38.129636] IBM TrackPoint firmware: 0x0b, buttons: 2/3
[ 38.417081] input: TPPS/2 IBM TrackPoint as /devices/platform/i8042/serio4/serio5/input/input7
[ 45.832024] eth0: no IPv6 routers present
[ 659.317623] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 660.503708] halcmd[1648]: segfault at 8 ip 00de96bc sp bffdedb0 error 6 in liblinuxcnchal.so.0[de4000+8000]
[ 660.590985] halcmd[1649]: segfault at 8 ip 00d946bc sp bfab8950 error 6 in liblinuxcnchal.so.0[d8f000+8000]
[ 660.638439] halcmd[1652]: segfault at 8 ip 00ae66bc sp bff9f240 error 6 in liblinuxcnchal.so.0[ae1000+8000]
[ 660.914906] halcmd[1656]: segfault at 8 ip 003916bc sp bfb8dae0 error 6 in liblinuxcnchal.so.0[38c000+8000]
[ 661.129495] halcmd[1660]: segfault at 8 ip 00e8b6bc sp bfd91a70 error 6 in liblinuxcnchal.so.0[e86000+8000]
[ 661.343926] halcmd[1664]: segfault at 8 ip 00d8d6bc sp bfcc92b0 error 6 in liblinuxcnchal.so.0[d88000+8000]
[ 661.558558] halcmd[1668]: segfault at 8 ip 007ac6bc sp bffbd9e0 error 6 in liblinuxcnchal.so.0[7a7000+8000]
[ 661.774556] halcmd[1672]: segfault at 8 ip 006636bc sp bfdb1cf0 error 6 in liblinuxcnchal.so.0[65e000+8000]
[ 661.989635] halcmd[1676]: segfault at 8 ip 0039d6bc sp bfe51300 error 6 in liblinuxcnchal.so.0[398000+8000]
[ 662.203994] halcmd[1680]: segfault at 8 ip 001bc6bc sp bfc8d490 error 6 in liblinuxcnchal.so.0[1b7000+8000]
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.3
TASK=milltask
HALUI=halui
DISPLAY=axis
Cleanup done
1610
[ 1.449512] sda:
[ 1.487816] sda1
Thanks a lot...
Last edit: 06 Sep 2013 19:51 by Cybermuk.
06 Sep 2013 20:50 - 06 Sep 2013 20:51 #38517
by ArcEye
Replied by ArcEye on topic Have some errors, but dont understand what Problem
Hi
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
Last edit: 06 Sep 2013 20:51 by ArcEye.
Time to create page: 0.304 seconds
