New machine build problems.
- jmbradwell
22 Dec 2013 03:33 #41912
by jmbradwell
I hope this is the appropriate forum to post this. I'm a noobe.
Machine: Fireball V90.
X & Y Axis: 5 TPI
Z Axis:12 TPI
Driver: Gecko G540
Stepper: KL23H286-20-8B (200 Steps per Rev)
Ini File created with StepConf is attached. Hope this is the file you need to answer my question.
All axix's move without any stalling, but they only move 10% of what they should if I'm understanding the g-code.
For example. I issue a "G0 X10 Y10 Z-3" results in X moving 1 Inch, Y moving 1 Inch, and Z moving 0.3 inches. With my limited understanding, I would have assumed a move of 10, 10, and -3 inches.
What am I missing, and what did I screw up?
If you need a different file, let me know and I'll upload.
Thanks in advance.
New machine build problems. was created by jmbradwell
X & Y Axis: 5 TPI
Z Axis:12 TPI
Driver: Gecko G540
Thanks in advance.
- Thank you received: 5193
22 Dec 2013 03:37 #41914
Replied by PCW on topic New machine build problems.
G540s like most Gecko drives are 10 uStep/full step drives so you have 2000 steps per turn, not 200
The following user(s) said Thank You: jmbradwell
- jmbradwell
22 Dec 2013 03:56 #41915
by jmbradwell
Replied by jmbradwell on topic New machine build problems.
That got it.
Changed the INI to 10 microsteps and adjusted the speeds and all is working as expected now.
Now for Home and Limit switches.
Thanks for the prompt response.
John.
John.
