Error on 10.04 LTS
03 Jan 2014 18:47 - 03 Jan 2014 19:02 #42316
by flasher
Error on 10.04 LTS was created by flasher
Hi guys,
I've freshly installed 10.04 LTS + Linuxcnc, for the first time.
My computer is quite old: ThinkPad T23, 768MB ram.
Ubuntu works smoothly and I'm very happy about it.
But when I try to run Linuxcnx there is an error & a crash. I can see the first "Select configuration" window, I make the selection and when I confirm it it crashes.
I'm attaching the log.
Can you help me?
It's my first time on linux and would really appreciate the help.
thanks
matej
Can you help me?
thanks
matej
Last edit: 03 Jan 2014 19:02 by flasher.
03 Jan 2014 20:13 #42320
Replied by andypugh on topic Error on 10.04 LTS
The problem is here:
Try the advice here:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
05 Jan 2014 06:18 #42363
by flasher
Replied by flasher on topic Error on 10.04 LTS
Thanks mate.
But it didn't do the trick.
I have made the correction nad changed the line to: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash lapic"
In the error log it still says :
something else I could do?
thanks a lot,
matej
thanks a lot,
matej
05 Jan 2014 07:28 #42364
I don't suppose that the Local APIC is actually disabled in the BIOS?
Otherwise your options are to install the 8.04 version of the LiveCD, which gives you an old (but OK) version of Ubuntu, and a version of LinucxCNC that you can upgrade to at least the current release version, or you could see if the solution lies the other way, with a newer kernel:
thread.gmane.org/gmane.linux.distributions.emc.user/48430
05 Jan 2014 15:08 #42368
by Rick G
Replied by Rick G on topic Error on 10.04 LTS
On an older computer 8.04 might run linuxcnc better than 10.04 anyway.
You can burn an 8.04 disc, boot from it and try the latency test before going much further.
Also keep in mind a notebook may have more issues running linuxcnc than a desktop.
This is a bit dated but take a look here...
wiki.linuxcnc.org/cgi-bin/wiki.pl?Hardware_Requirements
Rick G
Rick G
07 Jan 2014 05:45 #42406
by gww250
Replied by gww250 on topic Error on 10.04 LTS
Just to add my 2-cents I've found that Linuxcnc is extremely 'hardware' sensitive. I've done about 12 installs over the past two years on a variety of computers and some have worked perfectly while others have had no end of problems.
Unfortunately I'm not a computer guy so I can't explain the reasons. I started just buying old used computers since they are cheap and when I get a good solid installation with low latency I'll put it into service. At the present time I'm having very good luck on almost any type of Dell system including the older laptops with a real parallel port on the back. Toshibas and Sony have been non-starters so far. I try to use systems with Intel processors but I've had some good luck on systems with AMD chips. Wish I knew more about the in and outs so I could help out.
Time to create page: 0.121 seconds
