MESA Card 6I25 Firmware and LinuxCNC Configuration
- Ozcnc
14 Jan 2014 15:15 #42748
by Ozcnc
MESA Card 6I25 Firmware and LinuxCNC Configuration was created by Ozcnc
I have finally converted to LinuxCNC and have also installed a Mesa 6I25 PCI-E Card.
Linux is up and running and know I want to install the Mesa Card.
I am running stepper motor's without encoders on a High-Z Machine.
How do I go about flashing the Mesa Card and then apply the settings already discussed in this forum.
And then what is next, Pnc.. Hal etc...
Please be patient I have never used Linux before so I might be slow on the take-up.
Oz
Oz
- Thank you received: 2167
14 Jan 2014 16:09 #42751
Replied by cmorley on topic MESA Card 6I25 Firmware and LinuxCNC Configuration
The card should have come with firmware installed.
It may be labelled somewhere eg 7i76x2 or g540x2.
If you really have to flash the card - Peter or Andy could advise you...
Pncconf doesn't cover the 6i25, though you could change all the names from 5i25 to 6i25 in the files after...
Just to try it it may be easier to use a mesa sample config (included in linuxcnc) and change it's names to 6i25.
there is less name changes that way.
Chris M
Chris M
The following user(s) said Thank You: Ozcnc
- Thank you received: 5303
14 Jan 2014 22:54 #42770
Replied by PCW on topic MESA Card 6I25 Firmware and LinuxCNC Configuration
The default 6I25 mode is to emulate a 5I25 and use 5i25 bitfiles
so its is identical to a 5I25 from a software standpoint.
15 Jan 2014 09:25 #42792
Other then I assume it uses 6i25 instead of 5i25 in the pin names?
Chris M
Chris M
15 Jan 2014 09:30 #42794
In emulation mode (normal for 6I25s) it is indistinguishable from a 5I25 so its pin names
will be "5i25" as well
- Ozcnc
15 Jan 2014 12:17 #42801
by Ozcnc
Replied by Ozcnc on topic MESA Card 6I25 Firmware and LinuxCNC Configuration
Lets for discussion ignore that I'm using a 6I25 and pretend its a 5I25.
When would it be necessary to Flash the card.
Oz
Oz
- Thank you received: 5017
15 Jan 2014 21:07 #42818
That depends on the firmware currently on the card.
Open a terminal window and type:
The "show pin" displays all the HAL pins created by the firmware on the card.
the "dmesg" should list the allocation of the physical pins on the card.
From that you can work out if the installed firmware has the step genearators that you need.
Replied by andypugh on topic MESA Card 6I25 Firmware and LinuxCNC Configuration
sudo dmesg -c
halrun
loadrt hostmot2
loadrt hm2_pci
show pin *5i25*
exit
dmesg
Time to create page: 0.082 seconds
