Errors when trying to run LinuxCNC from LiveCD
- carylwills
16 Jan 2014 20:45 #42874
by carylwills
Errors when trying to run LinuxCNC from LiveCD was created by carylwills
I've created a LiveCD that works correctly on a laptop. I ran both the Latency Test and LinuxCNC successfully. The only problem was that the laptop has about 5,000,000nS latency and is therefore no good for CNC control.
I then booted a Windows XP PC with the LiveCD, but it won't run the Latency Test. It just does nothing. No windows open and there are no error message that I can see. When I run LinuxCNC I get a whole bunch of errors that are shown in the attached file.
Thanks for your help.
16 Jan 2014 23:03 #42875
Replied by PCW on topic Errors when trying to run LinuxCNC from LiveCD
One problem is this
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
to fix, see:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
to fix, see:
The following user(s) said Thank You: carylwills
- carylwills
17 Jan 2014 04:21 #42887
by carylwills
Replied by carylwills on topic Errors when trying to run LinuxCNC from LiveCD
Thank you PCW for the quick reply. That fixed the problem.
Time to create page: 0.065 seconds
