Ubuntu precise 12.04 - Locked memory limit error
- jtc
- Thank you received: 13
10 Feb 2014 19:49 - 10 Feb 2014 20:11 #43698
by jtc
Ubuntu precise 12.04 - Locked memory limit error was created by jtc
Hi.
I was trying the following tutorial to install linuxcnc on ubuntu 12.04:
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
but when I try to run it, I have this error:
I tried to add the "* - memlock 20480" line on the recommended file, but it exists already....
so what I can do to solve this? I'm using the "precise master-rt" version of linuxcnc.
Thanks,
João Tiago
RTAPI: ERROR: failed to map shmem
RTAPI: Locked memory limit is 64KiB, recommended at least 20480KiB.
This can cause the error 'failed to map shmem'.
For more information, see
http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?LockedMemory
Thanks,
João Tiago
Last edit: 10 Feb 2014 20:11 by BigJohnT.
- ArcEye
- Thank you received: 758
10 Feb 2014 21:56 - 10 Feb 2014 23:43 #43703
by ArcEye
Replied by ArcEye on topic Ubuntu precise 12.04 - Locked memory limit error
Hi
Did you also try the rest of the solution?
I would imagine you can read 10.10 as >10.04
EDIT: If that does not work you can always add ulimit -l 20480 to your .bashrc file in your home directory
For Ubuntu Lucid (10.10), also add the following line at the end of /etc/pam.d/common-session
session required pam_limits.so
Log out and log back in.
Last edit: 10 Feb 2014 23:43 by ArcEye.
- jtc
11 Feb 2014 02:01 #43714
by jtc
Replied by jtc on topic Ubuntu precise 12.04 - Locked memory limit error
it works with "session required pam_limits.so"
Time to create page: 0.062 seconds
