Simulator stopped working
21 Feb 2014 16:50 #44036 by SvenH
Simulator stopped working was created by SvenH
After having it run for quite some time the simulator I run on my laptop for preparation stopped working, just after installing some general updates.
The laptop itself is also getting issues with running hot, maybe this is related somehow?
Here is the error I get:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3-96-g58501b0
Machine configuration directory is '/home/sven/linuxcnc/configs/sim/axis'
Machine configuration file is 'axis-Vee-4-axes.ini'
INIFILE=/home/sven/linuxcnc/configs/sim/axis/axis-Vee-4-axes.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=9323
Killing task milltask, PID=9355
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  153 (GLX)
  Minor opcode of failed request:  19 (X_GLXQueryServerString)
  Serial number of failed request:  749
  Current serial number in output stream:  749
9323
  PID TTY      STAT   TIME COMMAND
9355
Stopping realtime threads
Unloading hal components
Can this be fixed easlily?
21 Feb 2014 21:00 #44042 by ArcEye
Replied by ArcEye on topic Simulator stopped working
Looks like whatever you updated did something to the X server.
You may well have updated xserver-xorg-video-{whatever your video driver is}, that would be the first thing I looked at
As I have no idea what distro you are using, can't assist beyond that
22 Feb 2014 01:01 #44047 by jmelson
Replied by jmelson on topic Simulator stopped working
Try running glxgears. If that doesn't work, then your x server no longer supports
open-gl. That is needed for the 3D preview of Axis. Probably a proprietary
or the wrong generic video driver is conflicting with the 3D operation.
Jon
22 Feb 2014 14:21 #44064 by SvenH
Replied by SvenH on topic Simulator stopped working
Thanks guys, this gives me something to work with.
I'm running xubuntu 12.04 on a lenovo thinkpad edge 11 with AMD cpu
