Error in the splah, 2.5.3 version for downlaod
  • JR1050
  • JR1050's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Mar 2014 11:45 #44279 by JR1050
After downloading the image and installing it on a fresh hard drive, I attempted to open linuxcnc and expected to see ver 2.5.3, instead it comes up 2.5.0 on the splash screen. I figured I made an error, picked the wrong version, downloaded the image again ,same thing, ran thru the same thing again. Finally I looked at the installed version in the SPM and saw 2.5.3. . Only after you update does the splash get corrected.
It might be a good idea to fix the splash screen on the image on the download page, this can drive ya nuts....
01 Mar 2014 20:26 #44292 by BigJohnT
Replied by BigJohnT on topic Error in the splah, 2.5.3 version for downlaod
The LiveCD always contains the base version ie 2.5.0. Only after installing and running all the updates do you get the latest version. One thing the LiveCD has wrong is the OS update is still turned on. You can update everything but the OS.
JT
Time to create page: 0.050 seconds
